05-23-2015, 10:39 | #46 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | first of post becouse not read the D.R.I.V.E. Update and what program you must need for run "DRIVE32/64"?...if you not install Free "exFat Paragon" from where you want take the drivers? I understand you are new user but i think that for Read an Update have need only an little of pacience. BR allumts |
05-23-2015, 11:10 | #49 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Put this Sw and run with D.R.I.V.E., no need of reset any program just "Update Important File". Not import you registraction data, one Atf User that post "EMMC Disk Virtual Driver not found" is new user in Atf or not have read the last Update. Remember that isn't one offensive answere put you in Right way, we all are been New Atf User and no there's nothingh of bad in this. So, try with righ way and you will see that find all you have need Please when ask for help not do Polemic, read and Apply the Help thanked always. For more knowledge read also here: http://forum.gsmhosting.com/vbb/11058620-post1.html BR allumts |
05-23-2015, 12:59 | #50 (permalink) |
No Life Poster Join Date: Sep 2005 Location: London, UK
Member: 178513 Status: Offline Thanks Meter: 109 | Hello, Why my box after i have updated to 2.31, need to do each time the update firmware, otherwise the interface and all the functions are inactive... Regards, Albelektronik |
05-23-2015, 14:37 | #52 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
05-23-2015, 15:44 | #53 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
what I mean is "our country" not "out country". | |
05-23-2015, 17:26 | #57 (permalink) | |
any of configure, tested with New "Drive 32/64 bit" file and one .Bin file (Full dump I9505), - select the .Bin file or EMMC Recovery - press "Mount" button - "UNceck" read from Mounted .Bin or EMMC recovery - "Choise" partition you want read - Drive 32 or 64 show Unit external disk, for example "D" - from Disk Managment you can open and see Partition recovered - Copy/Paste in other Folder you want, (i've renamed one how "Data") - Done, now you have you recovered partition that can open with other Program you choice depending on the format all here nothing of complicate, but remember of "UNceck" read only from "MOUNT" BR allumts | |
05-23-2015, 17:29 | #58 (permalink) |
Freak Poster Join Date: May 2009
Member: 1038939 Status: Offline Thanks Meter: 99 | My problem was solved so set on the clean net 12.30 Win XP, updated, worked, and then copied to a working system. Apparently crooked upgrade to a production system, it is still large files merges constantly freezes, soldering normal tomorrow I will try to lift both Hynix attach. By the way Lumia 920 - Memory Toshiba. More than 50 megabytes problem merge files. |
05-23-2015, 19:44 | #59 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Finally, I got working whit a directly connected board, but I need a clean win 7 install, and also the mount procedure takes almost 10 minutes. The board was lumia 520. After that everything goes as it should. Can copy, write rename, delete. Great. Thanks |
05-23-2015, 20:59 | #60 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | SOLVED Update Firmware continue after install 12.31, now is all working, Mount Disk, Recovery itc.... No need any Clean install of SO, no need nothingh more of install 12.30 setup.exe, Update from "AUTOUPTDATE" button, "Update Important Files", Install "exFAT Paragon" program....IMPORTANT, PUT IN EXCLUSION LIST OF YOU AV and FIREWALL all .exe file of Atf, Paragon sw, Drivers of exFAT Paragon itc... Just connect EMMC press MOUNT button and UNceck Read Only...now can copy/paste you files in any folder you choise renamed, all here. BR allumts |
