05-24-2015, 07:03 | #62 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Paragon sw only needs is you want mount exfat partitions. If ntfs partitions need mount no need paragon sw. I need clean os install because I can't solve "emmc driver not found" , reinstall 12.30, update to 12.31, update important files, install paragon sw, and error remains. This error comes on two of my computers, others 3 is working. I don't know why. |
05-24-2015, 08:00 | #63 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | @allumts: I not say it needs clean install of win os, I just say a can't solve following your instructions. And also on these computers it was also working, but suddenly comes this error, maybe some antivirus sw kills some important files, or something. |
05-24-2015, 10:06 | #65 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Today i planed to backup all the data exists on lumia 520, but when i try to copy an mp4 file (around 400MB) the middle off the process my last working laptop is freezes (no mouse mooving, no cursor, i cant do anything) and a half hour of wating i need to reset my computer. after this point i cant browse my 520 anymore. It mounts, dismounts, but in drive32 window the block adress hex mooving stops, when "writte operation" displays. and after a minute waiting windows drops an error window: "I/O operatin terminated, or stopped due to some aplication" I do everything i can, maybe something wrong happend inside the lumia 520 emmc? thanx dazexy ps.: perm write protect: NO TMP write protect: NO |
05-24-2015, 10:22 | #66 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | update: I can access other partition, like: MMOS from this lumia 520 (I/O error message also comes) but after that can browse/copy file. But the data partition is not accessible any more. |
05-24-2015, 10:55 | #67 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | update2: after mounting succesfull some other partitions, i go back to data partition, and its working again, not stops at write operation. Takes about 10 minutes to enter, but working again. |
05-24-2015, 14:33 | #69 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | 1. After update to 12.31, click "UPDATE IMPORTANT FILES" Then WTF to you as well for not reading instructions... Clearly written instructions here: http://forum.gsmhosting.com/vbb/f475...015-a-1951323/ |
05-24-2015, 16:15 | #71 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | i finally figure it out Many thanx, after playing with SPEED parameter, i get stable connection: (big files is also can be copied ) here: |
05-25-2015, 08:13 | #72 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Paradise on Earth
Member: 1281866 Status: Offline Thanks Meter: 330 | as i am new releated with emmc i need some clarification 1.some one says 4 wire plus 2 more connection did u mean direct usb cable from system to mobile 2.did we need battery or power supply to mobile 3.can we recover data from china based mobile .if yes that is good if no please support it 4.if the handset is restored and the data in rom is deleted can we recovery deeted data by mount and use any other software to recover deleted data. 5 Also please upload the picture of any samsung mobile by home made jitag cable Thanks in advance also sorry for my bad English |
05-26-2015, 11:09 | #74 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Because you asked too many... Maybe next time ask 1 at a time? 1.some one says 4 wire plus 2 more connection did u mean direct usb cable from system to mobile 4 connections for EMMC Data Communication. Via very thin wires to be soldered directly on the PCB. 2 extra wires for EMMC Power... but you can skip these 2 wires if Phone has Qualcomm CPU inside, then you can just power phone pcb with USB cable only. 2.did we need battery or power supply to mobile Depends on phone. You normally need 1.80v and 3.30v power supply for Vcc and VccQ respectively. But again if phone is qualcomm cpu inside, then you can just use USB cable to power VCC and VCCQ by connecting usb cable to the phone pcb usb port. We will never use battery in any phone. 3.can we recover data from china based mobile .if yes that is good if no please support it If china phone has android inside, then YES. It does not matter who made the phone. Android is Android. 4.if the handset is restored and the data in rom is deleted can we recovery deeted data by mount and use any other software to recover deleted data. It depends. If you restore phone via usb flashing then most times DATA will be securely erased. So there is nothing to recover, entire data partition will be filled with 0x00... If restored via JTAG, and JTAG dump used does not overwrite DATA partition, then there is a chance to recover DATA. However, since DATA is an EXT3 Linux Journaled Partition, you need to make sure your 3rd party tools can support EXT3 and can support Virtual Drives mounted by ATF software. 5 Also please upload the picture of any samsung mobile by home made jitag cable So many already uploaded, just search forum "success ATF JTAG" Thanks in advance also sorry for my bad English |
The Following User Says Thank You to Advance-Box For This Useful Post: |
05-26-2015, 12:40 | #75 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @ X-Shadow 10+ for you pacience....but -0 to All users that NOT read the update and not use search button posting question answered many times. BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
