02-27-2014, 12:10 | #1 (permalink) |
Insane Poster Join Date: Jun 2005 Location: uruguy Age: 49
Member: 151288 Status: Offline Thanks Meter: 0 | 11.10 upgrade, no longer recognizes my atf but why? thanks pd: I install new driver and now does not recognize my box please help ( DUAL RS232 HS) SERIAL CONVERTE A Y SERIAL CONVERTER B Last edited by ferch; 02-27-2014 at 12:17. |
02-27-2014, 12:29 | #2 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | Quote:
WBR Kmaxmax | |
02-27-2014, 12:42 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ferch First Install Updated Driver for DUAL RS232 HS) SERIAL CONVERTE A Y SERIAL CONVERTER B You can get it here: http://www.ftdichip.com/Drivers/CDM/...0Certified.zip After you updated the drivers, then disconnect ALL OTHER GSM BOXES from your PC and make sure only ATF BOX is Connected. Go to Product Support ---> Box Tools ---> click "Restore EEPROM" Follow instructions after that... Normally, just disconnect and reconnect ATF Box, then it will ask for Drivers Already... atf drivers |
02-27-2014, 13:04 | #4 (permalink) | |
Member: 151288 Status: Offline Thanks Meter: 0 | Quote:
thank you very much solved Now I have another problem with atf plus to open it tells me this Default language ID 0x380A JTAG Interface ATF Box init failed! what is the problem if I have activated atf plus? | |
