Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-16-2010, 11:16   #1 (permalink)
Registered User
Member: 170026
Thanks Meter: 6
ATF drivers problem
its shows
Usb serial converter a
usb serial converter b
Old 07-16-2010, 11:30   #2 (permalink)
twentyonecell's Avatar
Member: 664744
Thanks Meter: 156
Originally Posted by varunsre123 View Post
its shows
read here
http://forum.gsmhosting.com/vbb/6069303-post1.html
Old 07-16-2010, 12:09   #3 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@varunsre123
This Problem was caused because you click "Update FTDI EEPROM" button and there
were other boxes connected or the ATF driver was overwrite with older drivers.
Here is solution.
Download Latest FTDI Drivers from FTDI Website:
http://www.ftdichip.com/Drivers/CDM/CDM20602.zip
Extract it and use it to "Update" the drivers of
USB to Serial Converter A
and
USB to Serial Converter B
Force windows to use the New Drivers... Select "Specify Drivers"
After you updated both, the driver version of both will be 2009 or 2010.. and this
is OK.
Next is Download MPROG from ftdi website here:
http://www.ftdichip.com/Resources/Ut...s/MProg3.5.zip
Extract it and run it..
Then remove ALL other boxes from the USB Port,, connect only ATF...
Then write the EEPROM File from
C:\AdvanceBox Turbo Flasher\Driver\new abox turboflasher.ept
After successfull write, close MPROG, then disconnect the ATF Box from your USB
Port...
Then reconnect... Done.
B/R
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.18824 seconds with 10 queries
