03-11-2014, 06:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: CHINA Zhuhai Age: 40
Member: 760531 Status: Offline Sonork: [email protected] Thanks Meter: 58 | ATF EMMC high speed write n7100 ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056545530304DF144653FCE CSD : D02701320F5903FFF6DBFFFF8E40406D eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 15.1 Product SN : 44653FCE Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056545530304DF144653FCE_0DA2E05A.ext_csd Backup Directory: D:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing 0x00100000 Blocks at 0x00000000 Partition Selected: USER AREA |
