01-30-2015, 15:15 | #1 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | ATF EMMC Pin Finder v11.92 Update!! Public Discussion Thread: Firmware Version Required : 11.0.10 ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit) ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit) ATF 11.92 *** GET THIS UPDATE VIA AUTO-UPDATE SEVER *** What's Cooking? ALL FIRST-IN-THE-WORLD SOLUTIONS COMING from the INVENTORS of eMMC Test Point Programming. - Find DATA for Qualcomm Based CPU Now Supported - Find CMD for Exynos Based CPU Now Supported Find DATA for Exynos Based CPU Now Supported Find Vcc for Exynos Based CPU Now Supported - Find DATA for Marvell PXA Based CPU Now Supported Find Vcc for Marvell PXA Based CPU Now Supported - Find DATA for Broadcom Based CPU Now Supported Find Vcc for Broadcom Based CPU Now Supported - Added Sampling Rate Multiplier Added "Save Samples" Option The procedure to find eMMC Test Points without physically removing eMMC is a FIRST-IN-THE-WORLD INNOVATION by ATF Team. For More Information about this process, please refer to this link: Discuss Here: You must also click "UPDATE IMPORTANT FILES" so that you will be able to download the latest Files that will be used for 11.92. B.R. X-Shadow Release Date: January 30, 2015 Firmware Version Required : 11.0.10 ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit) ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit) [New ATF Box Firmware] LogiCore 11.0.10 * Added FIRST-IN-THE-WORLD eMMC Test Point Finder/Locator Engine * Improved eMMC Read/Write Speeds * Added more VCCIO Level Adjustments options [ATF Plus] * Added Find eMMC TP - eMMC Test Point Finder 1.0 * Absolutely FIRST-IN-THE-WORLD Feature which allows you to Locate the eMMC Programming Test Points WITH-OUT Removing the eMMC Chip from the PCB. * Supports Qualcomm, Marvell PXA and Broadcom CPU for CMD and CLK Detection * Supports Exynos for CLK Test Point Detection * Other CPUs will be supported soon For More Information, Check here: http://forum.gsmhosting.com/vbb/f609.../#post10829268 [GENERAL UPDATES] --> Added all variants of Microsoft Lumia 330 in Nokia.ini ******************************* ATF JTAG 1.0.13 Build 5935 ******************************* Release Date: January 30, 2015 Firmware Version Required : LogiCore 11.0.10 Change Log --> Uses new ATF Firmware LogiCore 11.0.10 --> Adjusted eMMC Read/Write Timeouts Who will buy this if you can get more in ATF? __________________________________________________ ________________________ Buy only from ATF [Advance Turbo Flasher] authorized resellers: ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List ATF [Advance Turbo Flasher] official web sites: International - http://www.advance-box.com/ ATF [Advance Turbo Flasher] official support forums: World Wide: Advance Turbo Flasher - GSM-Forum Indonesia: ATF (Advance Turbo Flasher)) Philippine: Gsmph Syria: Arabic Support (Syria) GsmVIP Chinese support forum : ATF Box Vietnam: Saigonmobile India: Advance Box - .:: GsmIndia ::. Official Iran Support Forum : ASANGSM FORUM Bangladesh: Advance Box - Dhaka Mobile Chinese Support forum : www.yananliuhuan.com The Master Piece Last edited by Advance-Box; 02-03-2015 at 05:52. |
The Following 32 Users Say Thank You to gsmfun For This Useful Post: |
01-30-2015, 19:13 | #3 (permalink) |
No Life Poster Join Date: May 2005 Location: ((EGYPT)) walid badr Age: 44
Member: 148424 Status: Offline Sonork: 100.93619 Thanks Meter: 111 | need any mirror link coz this one not working with me br |
The Following 2 Users Say Thank You to mr.6630 For This Useful Post: |
01-30-2015, 19:27 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Server Maybe Busy... So you can try other Link Like Here: ATF_v11.90_Full_Installer - Download - 4shared - Linus Hernandez |
The Following 17 Users Say Thank You to Advance-Box For This Useful Post: |
01-31-2015, 03:26 | #7 (permalink) |
No Life Poster Join Date: Feb 2005 Location: tampin malaysia Age: 61
Member: 117956 Status: Offline Thanks Meter: 115 | Is it this ATF v11.90 update use tp , can erase and write emmc data to revive brick phone ? |
The Following 2 Users Say Thank You to tgcommss For This Useful Post: |
01-31-2015, 14:11 | #10 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Here the best thread where show step by step how ceck Point CLK, CMD itc... for find yourself must need only one RJ45 cable, one Needle, (in laboratory sure have a big quantity of this) and a small of wire, here: atf-emmc-test-point-finder-tutorial BR allumts |
01-31-2015, 14:26 | #11 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @X-Shadow or Angel, please, know that is under costruction too, but i not have understand this step: Quote:
BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
01-31-2015, 17:36 | #12 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Allumts I could find clk, cmd in LG E615f. VCC and VCCq got through the multimeter. I'm waiting for the tutorial how to find DATA0 with EMMC pin finder. |
01-31-2015, 18:36 | #13 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Ahh ok now have understand what you have said, yes of course we all are waiting for DATA, VCC, VCCq point, is very good all this from ATF becouse can find points in Phones that any other Jtag Box support yet, for this is Very Good solution this, BR allumts |
