===>>> ATF eMMC Test Point Finder Tutorial <<<=== STEP 1 : How to make TP Cable for eMMC PIN Finder Very Simple TP Cable Schematics (Supports Qualcomm, Exynos, Marvell, Broadcom and Spreadtrum* based Phones) https://s5.postimg.org/8i36enqxj/EMM...SCHEMATICS.jpg * ATF Nitro and Lightning Boxes need additional Adapter for Spreadtrum Based Phones... Sample of Home Made Cable https://s5.postimg.org/86qbfmzvb/EMM...DER_SAMPLE.jpg TP Cable for ATF Nitro / Lightning for Spreadtrum Based Phones https://s5.postimg.org/4oebj8yzb/EMM...SCHEMATICS.jpg Sample of Spreadtrum TP Finder Cable for ATF Nitro and Lightning https://s5.postimg.org/dkp3n6plj/EMM...UM_PICTURE.jpg |
STEP 2 : How to find CLK and CMD Please Take Note of the Following Items before Attempting to Find CLK and CMD: 1. Make sure you connect Positive (+) and Negative (-) Terminals Properly and Correctly. 2. Make sure POWER BUTTON is ALWAYS PRESSED 3. DO NOT Connect USB Cable to Phone 3. Allow at least 2 Tries per possible Location on the PCB 4. DO NOT Exert Too Much Force on the Resistors as they may COME OFF!!! 5. Not all Phones have exposed CLK or CMD Locations on the PCB. 6. Not all Phones are supported with this NEW TP FINDER Method. ATF Team will continue to improve it via UPDATES. STEP 1: Connect Power Positive (+) and Negative (-) to the Phone's Battery Terminal STEP 2: Make Sure Power Button is Always Pressed. Use Rubber Band or Tie Cables. https://s5.postimg.org/rfne5nk0n/EMM...NECT_POWER.jpg STEP 3: Setup ATF Software settings such as REPEAT and INTERVAL for your convenience REPEAT <--- Number of Times TP Finder will Loop Itself Automatically INTERVAL <--- Delay in Seconds before the next TP Finder Operation will Start https://s5.postimg.org/nkk0330uv/EMM...R_SOFTWARE.jpg STEP 4: Start Connecting Test Point PIN to Resistors/TP Pads on the Phone's PCB around the eMMC Area. Wait for Message "Please Check Another Location..." before trying other TP Locations On ATF BIG Chrome Box, change TP Location when GREEN LED will Power OFF On ATF Nitro/Lightning Box, change TP Location when BLUE LED will Power OFF https://s5.postimg.org/qfx39y4uv/EMMC_TP_FIND_TP.jpg In this Example, I tried all the Locations that were marked with RED DO NOT TRY TO TP a CAPACITOR, it is NEVER CORRECT for CLK and CMD Capacitors are BROWN in COLOR Resistors are BLACK in COLOR ONLY TRY TO TP Resistors and Test Point Pads around eMMC Area https://s5.postimg.org/lvawv0l5j/EMMC_FIND_ME.gif When a correct Test Point is Found, you will see similar Message Below. The message also shows you the PINOUT of ATF RJ-45 Socket for the proper connection of the Test Point Found.https://s5.postimg.org/8sfabquxj/EMM...NDER_FOUND.jpg If Test Point is not Found Around the eMMC Area, you can try looking for it around the CPU Area. |
STEP 3 : How to find VccQ Please Take Note of the Following Items before Attempting to Find VccQ: 1. You must FIND CMD Pinout First using STEP 2 Above When you Find the CMD Pinout, the VccQ is ALWAYS on the other side of the CMD Resistor Test Point. https://s5.postimg.org/w7x7h3eon/e_MMC_Finder_Vcc_Q.gif If you want to find a better location for VccQ for easier Soldering Purposes, then you can use a Multitester on Continuity Test and check which Capacitors around the eMMC will "BEEP" when you test it against the VccQ Test Point on the opposite side of the CMD Resistor. Here is an Example of other VccQ Locations Found using Continuity Test Against VccQ Test Point on CMD Resistor. https://s5.postimg.org/d43w0r1uf/e_M...cc_Q_Found.gif For Voltage Value of VccQ, you can use 1.80V or 2.80V. If you want to know the ACCURATE Voltage to use, then you can use multitester DC Voltage TEST to check what is the actual VOLTAGE your VccQ gets when USB Cable is connected to the PCB. Sometimes the voltage will only appear for less than 5 seconds, so be sure to catch it quickly. Ask someone else to connect the USB Cable while you position your multitester's RED and BLACK prongs on the Phone PCB. |
STEP 4 : How to find Vcc <<< FOR QUALCOMM BASED PHONES, YOU DO NOT NEED VccQ and VCC >>> <<< You just need to Connect USB Cable to Phone PCB >>> <<< Proceed to STEP 5 on How to find DATA Test Point >>> DO NOT USE TP CABLE FROM STEP 1 for finding VCC. Finding VCC Requires another TP Cable which you can make using your current External Power Adapter for eMMC. You need to Prepare your External Power Adapter with a TEST POINT PIN on 3.30v Like This: https://s5.postimg.org/mc16ekf87/EMM...SCHEMATICS.jpg 1. Solder CLK Test Point Found from STEP 2 into the Phone PCB 2. Solder CMD Test Point Found from STEP 2 into the Phone PCB 3. Solder VccQ External Power 1.80v~2.80v from STEP 3 into the Phone PCB 4. Solder GROUND Connection from ATF RJ-45 to the Phone PCB. 5. Solder GROUND Connection from External Power Adapter to the Phone PCB. https://s5.postimg.org/8we5p46qf/EMM...ONNECTIONS.jpg On ATF Software, Make the necessary Settings for eMMC Finder Loop: https://s5.postimg.org/d6stkpbtj/TP_...C_SETTINGS.png In this Example, I tried all the Locations that were marked with RED DO NOT TRY TO TP a RESISTOR, it is NEVER CORRECT for VCC Capacitors are BROWN in COLOR Resistors are BLACK in COLOR ONLY TRY TO TP Capacitors https://s5.postimg.org/r1r43668n/e_MMC_Finder_VCC.gif When you have connected the testpoint cable to the correct Vcc Test Point, the ATF Software will announce to you that the VCC Pinout has been located. |
STEP 5: How to find DATA Now for the Last Step, you must already have the correct CLK, CMD, VccQ and VCC from the Previous Steps 2-3-4. 1. Solder CLK Test Point using TP Cable from STEP 1 2. Solder CMD Test Point using TP Cable from STEP 1 3. Solder GND Test Point using TP Cable from STEP 1 (or just connect to VBATT Negative (-)); For Qualcomm Based Phones, Connect USB Cable to Phone PCB For Exynos, Marvel PXA and Broadcom Based Phones, Solder VccQ and Vcc External Power Supply and GROUND. STEP 5 Connection Should Look Like This: https://s5.postimg.org/jzt6gz2mv/EMM...INDER_DATA.jpg Now Setup ATF eMMC Pin Finder Module for Finding DATA Test Point: https://s5.postimg.org/qes7dn9cn/TP_...A_SETTINGS.png In this Example, I tried all the Locations that were marked with RED DO NOT TRY TO TP a CAPACITOR, it is NEVER CORRECT for DATA Capacitors are BROWN in COLOR Resistors are BLACK in COLOR ONLY TRY TO TP Resistors and Test Point Pads around eMMC Area https://s5.postimg.org/lvawv0l5j/EMMC_FIND_ME.gif When the Correct DATA Test Point is Found, ATF Software will show a similar message: https://s5.postimg.org/lhemsj7dj/TP_...DATA_FOUND.png Congratulations, you now have ALL eMMC Test Point Programming PINOUTS!!! |
Thanks to @mtk6572s4clone for providing new links and detailed tutorial. |
