Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 11-23-2012, 05:53   #1 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1674275
Thanks Meter: 12,360
Atf error and solution
I Present Error And Solutions With Atf
Who Is Faced Error While Run The Atf,Post Your Problem With Screen ShotI Will Help You
Regards
SHIJILFONOTLY
1)PHONE NOT PROPER TO CONNECT THE FBUS CABLE
2)CHECK FBUS CABLE BATTERY TERMINAL AND CLEAN IT
3)CLEAN THE FBUS CABLE PCB INTERFACE
4)POWER MANAGEMENT IC NOT DETECTED
5)CHECK PHONE PRIMARY POWER SECTIONS
The Following 6 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 11-23-2012, 05:54   #2 (permalink)
Member: 351924
Sonork: 100.1674275
SIMLOCK DAMAGED
PHONE SHOW CONTACT SERVICE OR CONTACT RETAILER
1)SL1 AND SL2 PHONES DIRECT UNLOCK SUPPORTED BY AFT JUST REBUILD SIMLOCK
The Following 5 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 11-23-2012, 05:59   #3 (permalink)
Member: 351924
Sonork: 100.1674275
PHONE SUPER DONGLEKEY DAMAGED
PHONE SHOW NOT CHARGING PROBLEM
PHONE TRUN OFF OR RESTART BEFOR 10 MNIUTES
1)ALL KINDS OF SL1,SL2.SL3 PHONES SD REPAIR POSSIBLE BY ATF
2)AFTER REPAIR SD PHONE SECURITY TEST MUST BE DAMAGED
3)MUST WRITE RF&BB PM(1 AND309) VIA SX4 AUTH
The Following 7 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 11-23-2012, 06:00   #4 (permalink)
Member: 351924
Sonork: 100.1674275
NOKIA DCT4 PHONES INCOMPLETED BOOT
PHONE IS DEAD CONDITION
1)PROBLEM PHONE FLASH IC NOT DETECTED
2)REBALL THE FLASH IC
Old 11-23-2012, 06:04   #5 (permalink)
Member: 351924
Sonork: 100.1674275
NOKIA DCT4 PHONE DEAD
1)PHONE CANT TAKE THE POWER
2)CHECK BATTERY CONNECTOR AND WAYS
3)CHECK UEM(POWER MANAGEMENT IC)
Old 11-23-2012, 06:10   #6 (permalink)
Member: 351924
Sonork: 100.1674275
1)MOSTY THIS ERROR FBUS CABLE CHECK OR CHANGE CABLE
2)PHONE FBUS INTERFACE ON PCB CLEAN AND TYR
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 11-23-2012, 06:12   #7 (permalink)
Member: 351924
Sonork: 100.1674275
CHECK THIS ERROR LOADER FAILED
1)MOSTY THIS PROBLEM WITH FBUS CABLE
2)NEXT CHECK FLASH IC
3)REHOT OR REBALL THE FLASH IC
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 11-23-2012, 07:19   #8 (permalink)
nainosoft's Avatar
Member: 1713692
Sonork: 1637132, QQ-2486154669
Thanks Meter: 187
Thumbs up What About This
What About This BR
I think its flash ic problem !!!
The Following 2 Users Say Thank You to nainosoft For This Useful Post:
Old 11-23-2012, 07:27   #9 (permalink)
Member: 351924
Sonork: 100.1674275
@nainosoft
unknown flash chip
no doubt 100%flash ic problem
reball the chip
post result
Old 11-23-2012, 11:13   #10 (permalink)
Member: 351924
Sonork: 100.1674275
PHONE CONDITION DEAD
WHILE CONNECT ATF SHOW THIS ERROR?
"NO PAPUBKeysHash Returned"
1)FIRST FLASH THE PHONE
2)AFTER ERASE FLASHING NOT START
3)REHOT OR REBALL FLASH IC
Old 11-23-2012, 11:20   #11 (permalink)
Member: 351924
Sonork: 100.1674275
PHONE CAMERA NOT WORK
1)WHILE RUN THE INFO SHOW
"DDC FILE MISMATCHMATCHED"
1)WRITE DCC FILE ON ATF ROOT FOLDER
C:\AdvanceBox Turbo Flasher\Nokia\DCC\Common
Old 11-23-2012, 11:48   #12 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 284
wht is error
http://img35.imageshack.us/img35/347/20121123171752.png
The Following User Says Thank You to tejas243404 For This Useful Post:
Old 11-23-2012, 12:48   #13 (permalink)
Member: 351924
Sonork: 100.1674275
Originally Posted by tejas243404 View Post
wht is error
bro what is the phone condition?
i hope phone is dead
this cause is loader problem
mostly flash ic problem
try to wash whole pcb then try to flash it
post result
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 11-24-2012, 05:50   #14 (permalink)
Member: 351924
Sonork: 100.1674275
PHONE IS CONTACT RETAILER OR CONTACT SERVICE
JUST RUN THE SELF TEST
LOOK THE ERROR
"EAR DATA LOOP TEST"
"SIM CLK LOOP TEST"
"SIM IO CTRL LOOP TEST"
FATAL ERROR
MEANS POWER IC(RETU,AVILMA)PROBLEM
1)REFLOW OR CHANGE THIS IC
Old 11-24-2012, 07:13   #15 (permalink)
Member: 351924
Sonork: 100.1674275
BAD CABLE CONNECTION
Page generated in 0.39493 seconds with 7 queries
