11-27-2012, 07:31 | #19 (permalink) |
No Life Poster Join Date: Mar 2008 Location: india Age: 39
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | 20:59:41 : If Phone Booting does not Start in 5 Seconds, 20:59:41 : Then Perform Steps 1, 2, 3 and 4... 20:59:41 : 20:59:41 : 1. Remove USB and Battery... 20:59:41 : 2. Insert USB. 20:59:41 : 3. Insert Battery. (Some phones boot automatically) 20:59:41 : 4. Please Power on phone shortly... 20:59:41 : 21:00:00 : 21:00:00 : Infineon USB Boot: F00A1FB300020503010100FF 21:00:00 : Sending PBL... 21:00:02 : PBL Successfully Sent... 21:00:02 : Sending SBL... 21:00:08 : ERROR: SBL was NOT Accepted halo c2-03 nokia mobile ded phone |
11-27-2012, 10:52 | #21 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | @Shani3 BROTHER WHAT IS THE PHONE CONDITION BEFOR FLASH? WHILE START FLASHING YOU GOT THIS ERROR? I HOPE PROBLEM WITH FBUS CABLE MOSTLY THE BSI LINE YOU CAN CHECK BATTERY CONNECTION WITH FBUS CABLE AND CLEAN COMMNUCATION POINT ON PCB(CLEAN IT) |
11-27-2012, 11:01 | #22 (permalink) | |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
you rehot cpu then try again to power on with battery | |
11-28-2012, 10:47 | #23 (permalink) |
Freak Poster Join Date: Jan 2012 Location: I /\/ D ! /_\
Member: 1713692 Status: Offline Sonork: 1637132, QQ-2486154669 Thanks Meter: 187 | Error:- Critical Error, No Match Also File In Your Flash Folder Reason:- 1-Bad Flash IC 2-ATF Loaders Problem 3-Bad Cable Connection Solution:- 1-HRC (Heat Reball Change) Flash IC 2-Reinstall ATF Setup 3-Check Cable Connectivity Regards: Nainosoft |
11-28-2012, 11:02 | #24 (permalink) |
Member: 1713692 Status: Offline Sonork: 1637132, QQ-2486154669 Thanks Meter: 187 | Error:- Config Key= FFFFFFFFFFFFFFF SP Data Corrupted Reason:- Service Provider Data Corrupt Problem:- 1-Sim Card Not Valid 2-Contact The Retailer Solution:- 1-Config Key Should Be 000000000000 2-Repair Simlocks SL1 & SL2 Regards: Nainosoft |
The Following User Says Thank You to nainosoft For This Useful Post: |
02-28-2013, 13:56 | #25 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Code: AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeded After 0 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 10A00108 ID DWORD 1 : E8D00344 ID DWORD 2 : C96C2100 ID DWORD 3 : 721158F3 ID DWORD 4 : 2D48232D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0068 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0131 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0068 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 40000000 (1024 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA NPC is Corrupted... ERROR: NPC is Corrupted..., 3 RPL Backup is Skipped PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F FlashInfo.RestartMode : Test Mode Process Done... IMEI DAMAGED PHONE WHILE CONNECT THE ATF SHOW THIS ERROR |
