Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-18-2013, 10:09   #1 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
atf failed to flash 6120
today i tray tow phone 6120c rm-243 by usb and fbus atf faiel to flash writ mcu 72% and cant writ
i tray to flash on infiniti best successfully don by best
this is log
card found: A1B5CCE8
registered to: CycloneBox
Connect phone on selected interface...
Core : v1.51 , FlashEngine : v1.8
Selected FlashSettings : FullFlash
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm243_07.20_prd_core.fpsx
PPM : rm243_07.20_prd_vEM90_01_hebrew.fpsx
CNT : rm243_07.20_prd_uda_erase.fpsx
APE : rm243_ENO_A_2009wk15v0.100.fpsx
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
-> Phone not found..
-> Boot fail...
Flashing failed...
Check files done...
-> Boot fail...
Flashing failed...
Check files done...
Connection opened successfully
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID: 000000010000022600010006400C192101031103
CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 10C0001757218B52544770E4958FF18BE7AAA1A9
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP ...
Processing PASUBTOC ...
-> Boot error - device not ready - check Battery/Connection/HW
-> Mostly - Long cable problem (use direct connection to PC)
-> Boot fail...
Flashing failed...
Phone disconected!
Check files done...
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Boot Done!
TIME : Boot time : 00:00:30
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL Server confirm flashmode!
Get req info : empty
ADL : ASIC CMT select Ok
===Flashing [MCU]===
Erase : Processing rm243_07.20_prd_core.fpsx
Found 3 areas to erase
Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
Result: 0000
Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT
Result: 0000
Erasing area 0x00B80000 - 0x04DFFFFF, NAND, CMT
Result: 0000
Partition erase not allowed by loader
Partitioning : Ok [5]
TIME : Erase time : 00:00:01
Write : Processing rm243_07.20_prd_core.fpsx
Total 404 [404/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ADA]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [RAP3NAND]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [SOS*UPDAPP]
CMT : Writing Hash CERT [SOS*DSP0]
CMT : Writing Hash CERT [SOS*ISASW]
CMT : Writing Hash CERT [SOS*CORE]
CMT : Writing Hash CERT [SOS+ROFS]
TIME : Write time : 00:01:07
MCU Write done
===Flashing [PPM]===
Erase : Processing rm243_07.20_prd_vEM90_01_hebrew.fpsx
Found 1 areas to erase
Erasing area 0x03300000 - 0x04DFFFFF, NAND, CMT
Result: 0000
TIME : Erase time : 00:00:00
Write : Processing rm243_07.20_prd_vEM90_01_hebrew.fpsx
Total 204 [204/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFX]
TIME : Write time : 00:00:40
PPM Write done
===Flashing [CNT]===
Erase : Processing rm243_07.20_prd_uda_erase.fpsx
Erasing area 0x04E00000 - 0x07B3FFFF, NAND, CMT
Result: 0000
Write : Processing rm243_07.20_prd_uda_erase.fpsx
No any data for write, skip write
CNT Write done
===Flashing [APE]===
Erase : Processing rm243_ENO_A_2009wk15v0.100.fpsx
Erasing area 0x00880000 - 0x00B7FFFF, NAND, CMT
Result: 0000
Write : Processing rm243_ENO_A_2009wk15v0.100.fpsx
Total 18 [18/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS*ENO]
TIME : Write time : 00:00:02
APE Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:01:52
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia 6120
Software Info: V 07.20 05-10-09 RM-243 (c) Nokia
IMEI: 355201036597149
Ape Version: 07.20
Product code: 0550022
Checking...
SimLock status : Can't get status
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Product code update...
Battery voltage is enough for start
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Elapsed: 00:03:20
Old 04-18-2013, 10:29   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
No problem in flashing , latest example - http://forum.gsmhosting.com/vbb/f609...oblem-1645603/
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 04-18-2013, 10:32   #3 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
sir i tray it tow phone y? failed by aft box and successful by best dongl this is log by atf
Processing Image File :
02:54:43 : rm243_07.20_prd_core.fpsx
02:54:43 : CMT Type : BB5
02:54:43 : CMT Algorithm : XSR 1.5
02:54:43 : Secondary Sending Speed : 650000Hz
02:54:43 : Algorithm Sending Speed : 13000000Hz
02:54:43 : Program Sending Speed : 13000000Hz
02:54:43 : Message Reading Speed : 98000Hz
02:54:43 : Number of Blocks : 404
02:54:43 : Entry Point: 0x217D08
02:54:43 : Page Format : -1
02:54:43 : MAX PAGE : 0x00020000
02:54:43 :
02:54:43 : Processing Image File :
02:54:43 : rm243_07.20_prd_vEM90_01_hebrew.fpsx
02:54:43 : Number of Blocks : 204
02:54:43 : Entry Point: 0x013A
02:54:43 :
02:54:43 : rm243_07.20_prd_uda_erase.fpsx
02:54:43 : Number of Blocks : 0
02:54:43 : Entry Point: 0x0000
02:54:43 : MAX PAGE : 0x00000000
02:54:43 :
02:54:43 : rm243_ENO_A_2009wk15v0.100.fpsx
02:54:43 : Algorithm Sending Speed : 6500000Hz
02:54:43 : Program Sending Speed : 6500000Hz
02:54:43 : Number of Blocks : 18
02:54:44 :
02:54:45 :
02:54:45 :
02:54:45 : AUTO SELECTED DEAD USB FLASHING...
02:54:45 :
02:54:45 : If Phone Booting does not Start in 5 Seconds,
02:54:45 : Then Perform Steps 1, 2, 3 and 4...
02:54:45 :
02:54:45 : 1. Remove USB and Battery...
02:54:45 : 2. Insert USB.
02:54:45 : 3. Insert Battery. (Some phones boot automatically)
02:54:45 : 4. Please Power on phone shortly...
02:54:45 :
02:54:59 : AdvanceFBox SendBootCodeEx
02:54:59 : InitialiseBootstrap_DCT5 DIR
02:54:59 : BootFlashMode_DCT5
02:54:59 : READING BOOTROM
02:54:59 :
02:54:59 : BootFlashModeDCT5Ex Succeeded First Time
02:54:59 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
02:54:59 : Number of Sub Blocks 7 (0x07)
02:54:59 : 1 SYSTEM_ASIC_ID 01
02:54:59 : Block Length : 21 (15)
02:54:59 : BB ASIC Index : 0 (00) CMT
02:55:00 : ID DWORD 0 : 00000001
02:55:00 : ID DWORD 1 : 00000226
02:55:00 : ID DWORD 2 : 00010006
02:55:00 : ID DWORD 3 : 400C1921
02:55:00 : ID DWORD 4 : 01031103
02:55:00 : 2 EM_ASIC_ID 02
02:55:00 : Block Length : 5 (05)
02:55:00 : BB ASIC Index : 0 (00) CMT
02:55:00 : ID DWORD 0 : 00000295
02:55:00 : 3 EM_ASIC_ID 02
02:55:00 : ID DWORD 0 : 00000B22
02:55:00 : 4 PUBLIC_ID 12
02:55:00 : Block Length : 21 (15)
02:55:00 : ID DWORD 0 : 10C00017
02:55:00 : ID DWORD 1 : 57218B52
02:55:00 : ID DWORD 2 : 544770E4
02:55:00 : ID DWORD 3 : 958FF18B
02:55:00 : ID DWORD 4 : E7AAA1A9
02:55:00 : 5 ASIC_MODE_ID 13
02:55:00 : Block Length : 2 (02)
02:55:00 : Mode Id : 00
02:55:00 : 6 ROOT_KEY_HASH 14
02:55:00 : Block Length : 17 (11)
02:55:00 : Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE
02:55:00 : 7 ROM_ID 15
02:55:00 : Block Length : 9 (09)
02:55:00 : CRC 0 : 4B9B7510
02:55:00 : CRC 1 : 3E691FF8
02:55:00 :
02:55:00 : CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_2nd.fg
02:55:01 : Secondary Loader Sent....
02:55:01 :
02:55:01 : MCU_CONFIGURATION_RESPONSE_BB5:
02:55:01 : MessageID : C1
02:55:01 : SubBlocks : 06
02:55:01 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
02:55:01 : Block Length : 0B
02:55:01 : BB ASIC Index : CMT 00
02:55:01 : Device Type : RAM 05
02:55:01 : Device Index : 00
02:55:01 : Manufacturer Code : 0000 -> Flash
02:55:01 : Device ID : 0000 -> Type not in database
02:55:01 : Extended/Fixed ID : 0000
02:55:01 : Revision ID : 0000
02:55:01 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
02:55:01 : Device Type : MMC 04
02:55:01 : Manufacturer Code : FFFF -> Flash
02:55:01 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
02:55:01 : Device Type : NOR 00
02:55:01 : Manufacturer Code : 0020 ->
02:55:01 : Device ID : 0030 -> Type not in database
02:55:01 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
02:55:01 : Device Index : 01
02:55:02 : Manufacturer Code : 0000 -> SPANSION
02:55:02 : Device ID : 0001 -> Type not in database
02:55:02 : Extended/Fixed ID : 0000
02:55:02 : Revision ID : 0000
02:55:02 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
02:55:02 : Block Length : 0B
02:55:02 : BB ASIC Index : CMT 00
02:55:02 : Device Type : MuxOneNAND 03
02:55:02 : Device Index : 00
02:55:02 : Manufacturer Code : 0020 ->
02:55:02 : Device ID : 0030 -> Type not in database
02:55:02 : Revision ID : 0021
02:55:02 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
02:55:02 : Block Length : 09
02:55:02 : Data : XSR 1.5
02:55:02 :
02:55:02 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
02:55:02 : Flash Descriptor
02:55:02 : Size : 08000000 (128 MB)
02:55:02 : VPP Info : 0000
02:55:02 : Erase10s : 1E
02:55:02 : Block1s : 32
02:55:02 : BErase1s : 02
02:55:02 : Reserved0 : 00
02:55:02 : Reserved1 : 00
02:55:02 : Reserved2 : 00
02:55:02 :
02:55:02 : CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_XSR15_a lg.fg
02:55:05 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
02:55:08 : SendCodeStart_NewProtocol
02:55:08 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
02:55:08 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
02:55:08 : FUR control Ok...
02:55:08 : TransmissionTypeRequest_DCT5_NewProtocol
02:55:08 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
02:55:08 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
02:55:08 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5
02:55:08 : VPP Enabled by Software
02:55:09 : Using Internal VPP
02:55:09 : VPP Enabled by Software
02:55:09 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
02:55:09 : PA PUBLIC KEY Request
02:55:09 : PhoneInfoRequest_BB5 (Asic Index 00 )
02:55:09 : PHONE_INFO_RESPONSE_BB5
02:55:09 : PAPUB_KEYS_HASH_RESP_BB5 2A
02:55:09 : BB Asic Index : 00
02:55:09 : CMT PAPUBKEYS HASH:
02:55:09 : 0FE1BA92D924A658E4800780FA6F4868100AC947
02:55:09 :
02:55:09 :
02:55:09 : START READING RPL DATA
02:55:09 : IMEI: 355201036597149
02:55:09 : Reading : NPC... OK!
02:55:09 : Reading : CCC... OK!
02:55:09 : Reading : HWC... OK!
02:55:09 : Reading : R&D... EMPTY
02:55:09 :
02:55:09 : NPC CERTIFICATE INFORMATION (CMT):
02:55:09 : IMEI : 355201036597149
02:55:09 : PRODUCT CODE : 0550022
02:55:09 : BLUETOOTH ID : 00:26:69:6D0:18
02:55:09 : PUBLIC_ID : 10C0001757218B52544770E4958FF18BE7AAA1A9
02:55:09 : PAPUB_KEYS_HASH: 0FE1BA92D924A658E4800780FA6F4868100AC947
02:55:09 : CCC CERTIFICATE INFORMATION (CMT):
02:55:09 : HWC CERTIFICATE INFORMATION (CMT):
02:55:09 :
02:55:09 :
02:55:09 : RPL Backup was Successful...
02:55:09 : Plain RPL saved to:
02:55:09 : C:\AdvanceBox Turbo Flasher\Nokia\Backup\355201036597149\3552010365971 49_25509.rpl
02:55:09 :
02:55:09 : ImagePath: C:\Program Files\Nokia\Phoenix\Products\rm-243\
02:55:09 : ImageFilename: rm243_07.20_prd_core.fpsx
02:55:09 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
02:55:10 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
02:55:10 : Certificate 1
02:55:10 : Name : NPC
02:55:10 : ASIC Index : CMT 0
02:55:10 : Certificate 2
02:55:10 : Name : CCC
02:55:10 : Certificate 3
02:55:10 : Name : HWC
02:55:10 : Certificate 4
02:55:10 : Name : R&D
02:55:10 : STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
02:55:10 : STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
02:55:10 : ProcessPartitionInfo_DCT5...
02:55:10 : Partition Info
02:55:10 : Partition Blocks : 1
02:55:10 : 1 PARTITION_INFO_BB5
02:55:10 : BB ASIC Index : 0x00 CMT
02:55:10 : Device Type : 0x03 MuxOneNAND
02:55:10 : Device Index : 0x00
02:55:10 : Partition Version : 00010000
02:55:10 : Spare : FFFFFFFF
02:55:10 : Num Partitions : 00000004
02:55:10 : Partition 1
02:55:10 : ID : 00000003 COPIEDOS
02:55:10 : Attribute : 00000002 RO
02:55:10 : Start Address : 00080000
02:55:10 : Size : 01480000
02:55:10 : Partition 2
02:55:10 : ID : 00000004 DEMANDONOS
02:55:10 : Start Address : 01500000
02:55:10 : Size : 03900000
02:55:10 : Partition 3
02:55:10 : ID : 00000008 FILESYSTEM
02:55:10 : Attribute : 00000001 RW
02:55:10 : Start Address : 04E00000
02:55:10 : Size : 02D40000
02:55:10 : Partition 4
02:55:10 : ID : 0000000A PMM
02:55:10 : Start Address : 07B40000
02:55:10 : Size : 00160000
02:55:10 : PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 00020008000001480000000000040000000201500000039000 00000000080000000104E0000002D400000000000A00000001 07B40000001600009D
02:55:10 : PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
02:55:10 : StartErase_DCT5...
02:55:10 : BlockLength : 0x4F (79)
02:55:10 : ERASE Blocks : 0x02 (2)
02:55:10 : 0 ERASE_AREA_BB5 0x12
02:55:10 : Block Length : 0x1B (27)
02:55:10 : 0 : 00040000-00082FFF
02:55:10 : 1 : 00083400-0087FFFF
02:55:10 : 2 : 00B80000-04DFFFFF
02:55:10 : 1 FORMAT_PARTITION_BB5 0x19
02:55:10 : Block Length : 0x2F (47)
02:55:10 : Format Info ID : 0x00000000
02:55:10 : Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000
02:55:10 :
02:55:10 : ERASE_REQUEST_BB5 : 5003120B0003000004000000082FFF120B0003000008340000 87FFFF120B00030000B8000004DFFFFF08
02:55:12 :
02:55:12 : FORMAT_REQUEST_BB5 : 5001192F00030000000000000000000000000A000000000000 00020000006400000003000000010000000100000000000000 003E
02:55:12 :
02:55:12 : Successfully Erased...
02:55:12 : Total blocks to write : 404
02:55:12 : >> CMT Rootkey Hash CERT : ADA
02:55:12 : >> CMT Rootkey Hash CERT : KEYS
02:55:12 : >> CMT Rootkey Hash CERT : PRIMAPP
02:55:12 : >> CMT Rootkey Hash CERT : RAP3NAND
02:55:14 : >> CMT Rootkey Hash CERT : PASUBTOC
02:55:15 : >> CMT Rootkey Hash CERT : PAPUBKEYS [0FE1BA92D924A658E4800780FA6F4868100AC947]
02:55:15 : >> CMT Rootkey Hash CERT : SOS*UPDAPP
02:55:33 : >> CMT Rootkey Hash CERT : SOS*DSP0
02:55:49 : >> CMT Rootkey Hash CERT : SOS*ISASW
02:56:28 : >> CMT Rootkey Hash CERT : SOS*CORE
02:59:32 : >> CMT Rootkey Hash CERT : SOS+ROFS
03:02:01 : Flashing FAILED
03:02:01 : Flashing Failed....
03:34:03 : Number of Image Files: 4
Old 04-18-2013, 10:36   #4 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
y i erase pfhne and y best dong success withot erasing just flash phone from first time and phone working done
Old 04-18-2013, 11:30   #5 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
dear do like this...
1.backup ur rpl and full pm
2.erase flash.
3.write flash with v7.20
4.write your backup rpl and pm
all the best...
Old 04-18-2013, 12:14   #6 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
bro i undwerstand you but i tell u y? i erase flash and atf not able to flash and infinity best dot it normaly
Old 04-18-2013, 13:55   #7 (permalink)
Member: 1652269
Sonork: 100.1638989
Thanks Meter: 54
2.erase flash.
all the best...
Old 04-19-2013, 13:01   #8 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
atf cant erase phone and flash it by usb cable but infity best success falsh phone by usb many phone atf cant flash it and infinity best do it
Old 05-31-2014, 13:44   #9 (permalink)
Member: 1755052
I am facing the same problem with ATF , Failed to flash Nokia 6201c RM-243
Page generated in 0.27065 seconds with 8 queries
