01-16-2013, 12:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | ATF First In The World Asha 206 / 2060 USB Full Flashing! (RM-872, RM-873) Here is the Screenshot: Here is the Flashing Logs: Code: Number of Image Files: 3 Processing Image File : rm872__03.58.mcusw Processing Image File : rm872__03.58.ppm_m4 Processing Image File : rm872__03.58.image_m4_059Q4M1 []: Found 0 active devices. []: Not Found! Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12401407AD102819 Original Product Code: 059Q4M1 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354125050970489\354125050970489_013803.rpl Data Sections : 04 Current File : rm872__03.58.mcusw Compile Name: rm872__03.58.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26480008 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: AFC6 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A66 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 5169 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25165824 bytes Data Checksum: 3E66 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm872__03.58.ppm_m4 Compile Name: package_m4.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5714012 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A80000~0x420FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5710668 bytes Data Checksum: B665 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm872__03.58.image_m4_059Q4M1 Compile Name: package_m4_059Q4M1.image.fls Image Type : CONTENT Package Data Size : 15731984 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42100000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 15728640 bytes Data Checksum: E29A Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:06:40 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.58 05-12-12 RM-872 (c) Nokia IMEI Plain : 354125050970489 IMEI Spare : A354125050970480 IMEI SV : 33541250509704805F IMEI (2nd) : 354125050970497 IMEI Spare : A354125050970490 IMEI SV : 33541250509704905F Phone Model: K 206 Category : Entry Phone Type : RM-872 ================================================ Extended Phone Information ================================================ Product Serial Number: 831BC53BI Product Code : 059Q4M1 Module Code : 0205283 Basic Production Code: 059P6H4 Long Production SN : 0 PPM SW Version : V 03.58 05-12-12 RM-872 (c) Nokia M4 BT MCM Version : 19b5-22012 MCU SW Version : V 03.58 05-12-12 RM-872 (c) Nokia HW Version : 2300 RFIC Version : 68 LCD Version : TPO FWID Version : jV 03.58 05-12-12 RM-872 (c) Nokia V 03.58 05-12-12 RM-872 (c) Nokia M4 059Q4M1 001 Content Pack Version : Content: m4_059Q4M1 V 03.58 05-12-12 RM-872 (c) Nokia Bluetooth ID : 54:79:75:83:95:A0 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01029704 DCC Ver: 008013 Status : OK ====================================================== Selected VPL File: RM872_059Q4M1_03.58_016.vpl ====================================================== Variant Details : RM-872 MEA_M4_WHITE_ARABIC_BH Software Version : 03.58 Product Type : RM-872 Product Code : 059Q4M1 Variant Version : 016 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Life timer data is not yet used... Life timer: ----:-- Here Is Pinout Trust atf... ATF can Do Are You Ready To do??? BR WAJID |
The Following 25 Users Say Thank You to WAJID PNR For This Useful Post: |
