-   Advance-Box (http://forum.gsmhosting.com/vbb/f609/)
-   -   ATF First In The World Asha 210 (RM-924) Full Flashing! (http://forum.gsmhosting.com/vbb/f609/atf-first-world-asha-210-rm-924-full-flashing-1682645/)
WAJID PNR 07-04-2013 13:20
Here is the Screenshot:
https://imageshack.com/scaled/large/163/x6i2.jpg
Here is the Flashing Logs:
Number of Image Files: 3
Processing Image File :
 rm924__04.12.mcusw
 rm924__04.12.ppm_mec
 rm924__04.12.image_mec_059R777
[]: Found 1 active devices.
[Nokia USB Phonet]: Opening Connection
[Nokia USB Phonet]: Port opened OK!
SW: V 04.12 21-05-13 RM-924 (c) Nokia
IMEI: 355514051555283
 START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
 FULL PM Backup Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355514051555283\USB_FULL_BACKUP_V 04.12 21-05-13 RM-924 (c) Nokia_355514051555283__040509.pm
Reading Battery Value  : 3850 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Unique Data: 0250140B2B102829
Original Product Code: 059R777
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355514051555283\355514051555283_040517.rpl
Data Sections : 04
Current File    : rm924__04.12.mcusw
Compile Name: rm924__04.12.mcusw_ebl_psi.fls
Image Type  : Main Firmware
Data Size      : 28839304 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
 Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: C174
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
 Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7AFE
 Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: E927
 Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x41CBFFFE
Start Erasing...
Block Erase Done...
Data Size: 27525120 bytes
Data Checksum: AFD0
 Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File    : rm924__04.12.ppm_mec
Compile Name: package_mec.ppm_ebl_psi.fls
Image Type  : PPM Image
Data Size      : 5696240 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41CC0000~0x422FFFFE
Start Erasing...
Block Erase Done...
Data Size: 5692896 bytes
Data Checksum: CCBC
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File    : rm924__04.12.image_mec_059R777
Compile Name: package_mec_059R777.image.fls
Image Type  : CONTENT Package
Data Size      : 11930896 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42300000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 11927552 bytes
Data Checksum: D7C8
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:03:26
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
            Basic Phone Information
MCU Version: V 04.12 21-05-13 RM-924 (c) Nokia
IMEI Plain : 355514051555283
IMEI Spare : A355514051555280
IMEI SV    : 33555140515552807F
IMEI (2nd) : 355514051555291
IMEI Spare : A355514051555290
IMEI SV    : 33555140515552907F
Phone Model: Nokia 210
Category  : Entry Phone
Phone Type : RM-924
            Extended Phone Information
Product Serial Number: B818AF5BI
Product Code        : 059R777
Module Code          : 0205470
Basic Production Code: 059R080
Long Production SN  : 0
PPM SW Version      : V 04.12 21-05-13 RM-924 (c) Nokia            MEC
BT MCM Version      : 19e2-4702D
MCU SW Version      : V 04.12 21-05-13 RM-924 (c) Nokia
HW Version          : 2000
RFIC Version        : 68
LCD Version          : TPO
Content Pack Version : Content: mec_059R777 V 04.12 21-05-13 RM-924 (c) Nokia
Wireless LAN ID      : EC:F3:5B:11:8F:4C
Bluetooth ID        : EC:F3:5B:11:1A:1C
CS Type              : GSM900, GSM1800
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC        : 11
PROVIDER    : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3,  FBUS 0/10
  Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
  Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
  Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
  Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
  Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
  Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
  Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE            : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST            : PASSED
SECURITY_TEST          : PASSED
SECURITY_CODE          : 12345
PHONE_MODE              : TEST
          Dynamic Camera Configuration
DCC ID  : 115B6002
DCC Ver: 004020
Status  : OK
Selected VPL File:
RM924_059R774_04.12_012.vpl
Variant Details    : RM-924 MEA_MA2_BLACK_ARA_EG
Software Version : 04.12
Product Type      : RM-924
Product Code      : 059R774
Variant Version    : 012
Selected VPL File:
RM924_059R777_04.12_012.vpl
Variant Details    : RM-924 MEA_MEC_BLACK_ARA_BH
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
Life timer data is not yet used...
Life timer: ----:--
Here is My Phone with My ATF
https://imageshack.com/scaled/large/507/msk7.jpg
WAJID
lasergsm 07-04-2013 14:49
share firmware sir...indonesian languange
Advance-Box 07-04-2013 14:51
@WAJID PNR
Bro, please tell me what should I do with my Test Phone now? Heheheh
http://174.120.45.27/tmp/poor_phone.jpg
B.R.
WAJID PNR 07-04-2013 15:22
Originally Posted by Advance-Box (Post 9547829)
@WAJID PNR
B.R.
Your my Hero :)
nothing more to say! :P
WAJID
hadjimi 07-05-2013 16:33
Always Great work from you , and first in the world
thanks wajid and ATF Team
lenteraa 07-05-2013 17:08
good info..............
slim05 07-09-2013 07:46
I need nokia 210 RM-924 frimware
pls help
thanks
saifudheen1 07-09-2013 08:48
Need nokia 210 RM-924 frimware
pls help
thanks
srinibas 07-09-2013 10:53
pls help
thanks
pls help
thanks
Download file from - http://forum.gsmhosting.com/vbb/f609...ifirm-1656869/
Br - srinibas
WAJID PNR 07-09-2013 14:01
pls help
thanks
pls help
thanks
Choose your Product code here ,
http://forum.gsmhosting.com/vbb/f609...ml#post9518122
Follow this to Download Firmware By Product code,
http://forum.gsmhosting.com/vbb/f609...9/#post9417230
Remember, use Search Option, That Should Help You :) If anyone Need Arabic File then Choose this which i have Done 059R777
WAJID
srinibas 07-14-2013 16:12
Br - srinibas
Kuji2013 07-14-2013 16:59
Br nokia 105 rm-908 flash file needed.,.. Please...
srinibas 07-16-2013 06:58
Not available in any where , Even at Nokia server , A S A P we will upload it
Br - srinibas
rahulmishra 07-16-2013 11:25
Always Great work from WAJID sir
thank you for info
kp mobiles 07-26-2013 02:27
advance box is always advance and letest..............
Page generated in 0.35779 seconds with 5 queries
