Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 06-02-2014, 21:07   #16 (permalink)
Member: 2141947
Thanks Meter: 17
Please add navifirm tool
Old 06-07-2014, 10:25   #17 (permalink)
Member: 2156130
need flash file lumia610
Old 06-07-2014, 11:02   #18 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Download NaviFirm+ and ceck by p.code if you not want to do small donation of 3€ for all variant Fw and search also by only Model or Rm, cand download from here:
Symbian Toys - Software NaviFirm+ to dowload the firmware of your Symbian smartphone
allumts
Old 06-07-2014, 17:32   #19 (permalink)
Member: 2192869
Sonork: 100.1655095
i want the firmware !
direct link plz
Old 06-07-2014, 17:37   #20 (permalink)
allumts's Avatar
Member: 1564612
direct link plz
want want want...but what's WANT????
Download from my post above, Open your eyes....anythinghs is WANT but PLEASE!!!!!
Old 07-13-2014, 06:35   #21 (permalink)
Member: 2221501
hi , i did everything ,downloaded flash files but still now the software cannot find the flash files plz help
for lumia 520 rm 914
Old 07-13-2014, 07:19   #22 (permalink)
Member: 2221501
Originally Posted by diyong View Post
very fast for flashing atf box is the best for me...
From where did you download the flash files .
Old 07-13-2014, 19:33   #23 (permalink)
allumts's Avatar
Member: 1564612
Must need of ADD Path where you have these folder with all files in Atf Sw, if you not ADD right path Atf Sw where find you downloaded files and Forder with right RM name?
Go in "Setting" then "Right mouse button" and browse right Path directory, after have setted right directory in Nokia Flash Tabulate select right model, ceck "Phoenix" and you will see all you file ready for flash,
allumts
Old 10-01-2014, 23:14   #24 (permalink)
Member: 2249509
Sonork: 100.1658463
Idol where is firmware?
Old 10-02-2014, 15:33   #25 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Here since 1 year ago...
http://forum.gsmhosting.com/vbb/f609...added-1660094/
Also it is in sticky thread.
Next please do not be too lazy to use search button.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 12-07-2014, 15:11   #26 (permalink)
Member: 2047035
Thanks Meter: 41
trust ATF !
Full LOG :
Windows Phone 8/8.1 Flashing Started
Loading Flash Files Please Wait...
          Windows Phone 8/8.1 Lumia Flasher
If the Phone is ALIVE
  1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
  1. Connect Phone to the USB Port
  2. Press and Hold the VOLUME DOWN and POWER Buttons
  3. Wait until the Phone Vibrates Shortly...
  4. Stop Pressing the Buttons...
Nokia Phone Info Mode Initiated...
Please wait upto 15 Seconds for SW Reset
Version: 1.1.1.3
Product Code: 059S3W7
Module Code: 0205435
Continuing Previous Boot...
Please wait upto 30 Seconds for Boot Re-entry
Boot Flash Mode Successful...
Buffers Flushed OK...
Phone Info Query Start...
Blocks Returned: 0x08 Blocks
Block ID 0x01 : 00241000
Block ID 0x02 : 00240000
Block ID 0x03 : 00E74000
Block ID 0x04 : 00EE2000
Block ID 0x05 : Nokia.MSM8227.P6036.1.2
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 0100030000
Checking SD Card Size...
Card Size: 0x00EE2000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
Secure FFU Mode : SYNC + ASYNC
Query Flash App Information...
Flash App Information: 02010C011700
UEFI App: FLASH APP
Flash App Protocol Version: 1.12
Flash App Implementation Version: 1.23
Query ROOT KEY HASH...
ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACECAEF3F808C868FD
Sending Image Signatures...
Image Signatures Accepted!
Erasing Data Partition...
Data Partition Erased Successfully
Preparing Buffers for DATA LOOP...
Allocating System RAM OK!
Start Sending DATA BLOCKS...
Finished Sending all DATA BLOCKS!
Exiting FLASH Mode via REBOOT...
Exit FLASH Mode Successful!
Flashing Done!
Total Flashing Time : 00:06:05
And now... my windows Phone is ALIVE!
Old 01-20-2015, 18:51   #27 (permalink)
Member: 2328683
Sonork: 7867
u see in ATF setup for drivers..
Old 02-03-2015, 22:53   #28 (permalink)
allumts's Avatar
Member: 1564612
@moinahmedmz, where you want find the Nokia Lumia Win 8 if not in Atf Folder?, loock carefully and find alls types of drivers that you have need.
@asmcell, what solution find you?, first of all open you new thread and post with Log or screenshoot which is you problem.
allumts
Old 02-22-2015, 10:21   #29 (permalink)
Member: 2350901
changing RM
Hi
with the box can I flash RM-914 to RM-915 ?
Old 02-22-2015, 12:27   #30 (permalink)
allumts's Avatar
Member: 1564612
@ufo991,
Open you thread when have question, not Hi-Jack other peoples thread.
Yoy cannot flash RM-914 to RM-915, if not want get in the trush you phone.
Page generated in 0.22605 seconds with 8 queries
