12-12-2013, 21:10 | #1 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 21987 Status: Offline Thanks Meter: 27 | Alcatel HS-USB Diagnostics 9006 driver kontra LUMIA 710 open! If anyone knows how can I extract this driver from the XP, do not spare me! ALCATEL HS_USB Diagnostics 9006 There is no longer a program on my computer in which it is possible...Sigma box,Nck dongle,Alcatel Android manager....and this driver is still there! Two computer guru working on the problem for two and a half hours and no result....i congratulate Microsoft!!! |
12-13-2013, 06:59 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Probably is Qualcomm HS USB device, due to your phone is rooted - so ... try to read sticky thread about http://forum.gsmhosting.com/vbb/f609...epair-1673102/ P.S. - Use DeviceRemover to delete unneeded driver s from system, about your phone current state - must be seen in Device Manager tab like Qualcomm OSBL ... - so you can change just the driver associated with right one Last edited by debeliamark; 12-13-2013 at 07:04. |
12-13-2013, 13:25 | #4 (permalink) |
Member: 21987 Status: Offline Thanks Meter: 27 | I managed to find a solution but not 100%..... DRIVER GENIUS program I was able to delete the driver Alcatel QC.....i opened the Lumia 710 but it was the third pc rebooted again appeared faulty driver in device manager!! So you always have to be removed from opening 710! It finally just reinstall the operating system can be deleted...I received this information! |
02-02-2014, 01:04 | #5 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Venezuela
Member: 594580 Status: Offline Thanks Meter: 157 | From where can I get Lumia 710 flash drivers?? I always get this "Alcatel HS-USB Diagnostics 9006" when try to flash, then I try to change driver but there are no working drivers inside C:\AdvanceBox Turbo Flasher\Driver folder.. Please sir help.. Windows Phone Flashing Started OSBL File Found: RM809_OSBL_QUALCOMM.esco WARNING: MODEM AMSS File is not Loaded WARNING: MODEM ADSP File is not Loaded WARNING: WPOS File is not Loaded WARNING: UA ERASE File is not Loaded Factory Reset Skipped! ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== ================================================ Basic Phone Information ================================================ SW Version : 1600.3031.8773.12121 IMEI Plain : 359336040537503 HW Version : 112.1402.2.1 Phone Type : RM-809 Product Code : 059N364 Basic Product Code: 059J4H7 Module Code : 0205040 PSN Number : MOL352939 NCSD Version : 1.9 Variant Information: Claro Caribe DO Black V2 ================================================ Extended Phone Information ================================================ Public ID : 626DAB05E0E7A6F3BF85465F80353C7A Wireless Lan ID: 04:5A:95D:19:E7:00:00 Bluetooth ID : 04:5A:95C:7D:B0:00:00:00:00:00:00 Rebooting to OSBL MODE ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED |
04-17-2014, 09:39 | #6 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Bulgaria Age: 44
Member: 1475192 Status: Offline Thanks Meter: 121 | Testet on Nokia Lumia 710 Rm-803 1. Open Device Manager - Windows end right click on ""Alcatel HS-USB Diagnostics 9006"". 2. on menu select "update driver software in window." 3. select "browser my computer driver software end choose browser my computer driver software." 4. then select "let me pick from a list of device drivers on my computer." 5. In new window choose "usb composite device end install" 6. Warning Warning Warning window will appear with " you need to format the disk in drive : before you can use it. " It is important to press Cancel 7. Now in menu ATF select tab eMMC Direct end SP UNLOCK |
