12-10-2013, 17:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 21987 Status: Offline Thanks Meter: 27 | Lumia 710 unlock problem... Step 3 Unlock:error.....AMSS Partition Not Found Basic Phone Information ================================================ SW Version : 1600.3031.8773.12121 IMEI Plain : 3...............9 HW Version : 112.1402.2.1 Phone Type : RM-803 Product Code : 059N2Q4 Basic Product Code: 059H4J0 Module Code : 0204985 PSN Number : MQO531364 NCSD Version : 1.9 Variant Information: VAR EU HU T-MOBILE SL BLACK The problem is that you can not join OSBL mode??? The Device Manager shows: ALCATEL HS_USB Diagnostics 9006 /COM11/ When I connect the volume plus pressure.....this is a driver Sigmabox!! Alcatel see why???? What is the solution to this? |
12-10-2013, 21:11 | #3 (permalink) |
Member: 21987 Status: Offline Thanks Meter: 27 | Driver will be a problem..... If I connect OSBL mode /volume + press and connect/....in device manager it appears: ALCATEL HS_USB Diagnostics 9006 /COM11/!!!!! Not a question mark...but see Alcatel! Otherwise DLOAD button inactive in the program for me!! |
12-11-2013, 14:55 | #5 (permalink) |
Member: 21987 Status: Offline Thanks Meter: 27 | It's the same problem: "after flash my lumia 710 with mcu file RM803_OSBL_QUALCOMM.esco flash succeess but now can't found phone as Qualcomm MMC Storage USB Device i device manager i found alcatel hs-usb diagnostics9006 any driver to install or i miss some step" What is the miserable DRIVER THAT THIS CAUSES A PROBLEM????? Windows will automatically install the drivers, but one wrong....Nokia Connectivity Cable driver or other??? Or the driver version is not good??? |
12-11-2013, 15:19 | #6 (permalink) |
Member: 21987 Status: Offline Thanks Meter: 27 | Not the Sigma box driver for this??? alcatel hs-usb diagnostics9006 He would face? When "Qualcomm mode" tuck-away USB...is shown as a question mark:Qualcomm CDMA TECHOLOGIES MSM...will automatically switch to the Alcatel hs-usb driver!!! This is toxin,not cyanide!!!!!!!!!!!!!!!!!!!!!!!! |
12-12-2013, 21:06 | #9 (permalink) |
Member: 21987 Status: Offline Thanks Meter: 27 | If anyone knows how can I extract this driver from the XP, do not spare me! ALCATEL HS_USB Diagnostics 9006 There is no longer a program on my computer in which it is possible...Sigma box,Nck dongle,Alcatel Android manager....and this driver is still there! Two computer guru working on the problem for two and a half hours and no result....i congratulate Microsoft!!! |
12-13-2013, 13:29 | #11 (permalink) |
Member: 21987 Status: Offline Thanks Meter: 27 | Thus, we were able to solve: http://forum.gsmhosting.com/vbb/f609...-open-1751251/ If anyone knows 100% that it be removed from the driver, do not hold himself! |
04-16-2014, 19:26 | #12 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Bulgaria Age: 44
Member: 1475192 Status: Offline Thanks Meter: 121 | 1. Open Device Manager - Windows end right click on Alcatel HS-USB Diagnostics 9006 on menu. 2. select "update driver software in window." 3. select "browser my computer driver software end choose browser my computer driver software." 4. then select "let me pick from a list of device drivers on my computer." 5. In new window choose "usb composite device end install" 6. Warning Warning Warning window will appear with " you need to format the disk in drive : before you can use it. " It is important to press Cancel 7. Now in menu ATF select tab eMMC Direct end SP UNLOCK |
