Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 10-25-2011, 09:27   #1 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,259
****ATF First In the World - Nokia 100 (RH-130) FBUS flashing by End-User****
My first Nokia 100(RH-130) flashing log
VBATT OFF...
VBATT ON
Setting VBATT Done!...
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
                  TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\rh130_003.250
 FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
 Processing Section 01 of 03
FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: CBE9
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
 Processing Section 02 of 03
FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2329984 bytes
Data Checksum: 4ACF
 Processing Section 03 of 03
FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\rh130_003.25mr
 PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
 Processing Section 01 of 01
PPM Erase Block: 0x00210000~0x003FE67E
Start Erasing...
Block Erase Done...
Data Size: 2025088 bytes
Data Checksum: D64C
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\rh1300_nai03.25mr
 CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00EB0000~0x00F044BE
Start Erasing...
Block Erase Done...
Data Size: 345280 bytes
Data Checksum: D9ED
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:02:39
    You must Factory Reset the phone to enable the
   ringtones and other  customized settings to work
 Waiting For Phone to go Online...
 5,  4,  3,  2,  1...
MCU: V 03.25 16-09-11 RH-130 (c) Nokia
IMEI: 357918048374369
Product Serial Number: 4E5F448AH
Product Code         : 059H2K0
Module Code          : 0204875
Basic Production Code: 059F6X3
MCU SW Version       : V 03.25 16-09-11 RH-130 (c) Nokia MR
ADSP Version         : p V 03.25\n16-09-11\nRH-130\n(c) NMP\nmr
PPM Version          : V 03.25 16-09-11 RH-130 (c) Nokia
HW Version           : 1000
UEM Version          : 1328
UPP Version          : 8850
LCD Version          : WIN:BARACOAv95 NT39121
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 0000000000040002
Asic   : 11
Provider  :  Default Test Operator
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST               : PASSED
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
The Following 14 Users Say Thank You to WAJID PNR For This Useful Post:
Old 10-25-2011, 10:15   #2 (permalink)
Gsm_Dr's Avatar
Member: 1164230
Sonork: 100.1585164
Thanks Meter: 139
Nice.......................
Old 10-25-2011, 11:19   #3 (permalink)
Member: 388862
Thanks Meter: 44
good !!!!!!!!!!!!ATFbox!!!!!!!!!!!!!!!!!!!!!
Old 10-26-2011, 08:04   #4 (permalink)
zishanm's Avatar
Member: 1535468
Sonork: 100.161922
Thanks Meter: 160
very nice broooooooooooooas................
Old 10-26-2011, 08:58   #5 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 1,834
nice sharing bro
thanks a lot
Old 11-04-2011, 09:34   #6 (permalink)
mamun_q's Avatar
Member: 844892
Sonork: 100.1618521
Thanks Meter: 147
nice job....................................
thanks
Old 11-04-2011, 09:47   #7 (permalink)
Member: 697987
niceeeeeee sharinggggg bos.....
Old 11-04-2011, 09:54   #8 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 467
Upload flash file plz.
Old 11-04-2011, 21:13   #9 (permalink)
LIEREN's Avatar
Member: 917576
Sonork: QQ:366688456
Thanks Meter: 533
very nice!- supported atf team!
Old 11-29-2011, 11:59   #10 (permalink)
Member: 1623476
Nokia 100 Flash log, but after flashing, the custom themes are not available ??
CABLE HERE
10:56:04 : VBATT Powering Down <<<<
10:56:06 : VBATT Powering Up >>>>
10:56:06 : SET VCCIO Level Done
10:56:06 : SET BSI Load Done
10:56:07 :
10:56:07 : Booting Phone...
10:56:07 : CPU ID Response: A200341100
10:56:07 : CPU Type: XG110 2.1B
10:56:07 : Phone Booted at after First attempt...
10:56:07 :
10:56:07 : ************************************************** ****
10:56:07 : TIME STARTS HERE
10:56:07 :
10:56:07 :
10:56:07 : Sending PBL 19456 bytes...
10:56:09 : PBL Successfully Sent...
10:56:09 :
10:56:09 : Sending SBL 65024 bytes...
10:56:10 : SBL Successfully Sent...
10:56:10 :
10:56:10 : Flash Chip Manufacturer: Samsung Electronics Corp.
10:56:10 : Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
10:56:10 : Extended Information: Multiple Bank / Burst / 1.8v
10:56:10 :
10:56:10 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\rh130_003.250
10:56:10 :
10:56:10 : FIRMWARE Image Found...
10:56:10 : Number of Sections: 03
10:56:10 : FIRMWARE Certificate Block Sent Successfully...
10:56:10 : Processing Section 01 of 03
10:56:10 : FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
10:56:10 : Start Erasing...
10:56:10 : Erasing Please Wait...
10:56:29 : Block Erase Done...
10:56:29 : Preparing Data Blocks...
10:56:29 : Data Size: 2162688 bytes
10:56:29 : Data Checksum: CBE9
10:56:29 : Uploading Data Blocks to phone...
10:57:47 : FIRMWARE Data Blocks uploaded to phone...
10:57:47 : Processing Section 02 of 03
10:57:47 : FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
10:57:47 : Start Erasing...
10:57:47 : Erasing Please Wait...
10:58:08 : Block Erase Done...
10:58:08 : Preparing Data Blocks...
10:58:08 : Data Size: 2329984 bytes
10:58:08 : Data Checksum: 4ACF
10:58:08 : Uploading Data Blocks to phone...
10:59:32 : FIRMWARE Data Blocks uploaded to phone...
10:59:32 : Processing Section 03 of 03
10:59:32 : FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
10:59:32 : Start Erasing...
10:59:32 : Erasing Please Wait...
10:59:33 : Block Erase Done...
10:59:33 : Preparing Data Blocks...
10:59:33 : Data Size: 64 bytes
10:59:33 : Data Checksum: 0000
10:59:33 : Uploading Data Blocks to phone...
10:59:34 : FIRMWARE Data Blocks uploaded to phone...
10:59:34 : Start Data Verification... (Please wait)
10:59:38 : Data Verification Successful...
10:59:38 :
10:59:38 :
10:59:38 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\rh130_003.25ae
10:59:38 :
10:59:38 : PPM Image Found...
10:59:38 : Number of Sections: 01
10:59:38 : PPM Certificate Block Sent Successfully...
10:59:38 : Processing Section 01 of 01
10:59:39 : PPM Erase Block: 0x00210000~0x003DE9BE
10:59:39 : Start Erasing...
10:59:39 : Erasing Please Wait...
10:59:55 : Block Erase Done...
10:59:55 : Preparing Data Blocks...
10:59:55 : Data Size: 1894848 bytes
10:59:55 : Data Checksum: 79A2
10:59:56 : Uploading Data Blocks to phone...
11:01:03 : PPM Data Blocks uploaded to phone...
11:01:03 : Start Data Verification... (Please wait)
11:01:03 : Data Verification Successful...
11:01:03 :
11:01:04 :
11:01:04 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RH-130\rh1300_nai03.25ae
11:01:04 :
11:01:04 : CONTENT Image Found...
11:01:04 : Number of Sections: 01
11:01:04 : CONTENT Certificate Block Sent Successfully...
11:01:04 : Processing Section 01 of 01
11:01:04 : CONTENT Erase Block: 0x00EB0000~0x00F060BE
11:01:04 : Start Erasing...
11:01:04 : Erasing Please Wait...
11:01:08 : Block Erase Done...
11:01:08 : Preparing Data Blocks...
11:01:08 : Data Size: 352448 bytes
11:01:08 : Data Checksum: 89EB
11:01:08 : Uploading Data Blocks to phone...
11:01:21 : CONTENT Data Blocks uploaded to phone...
11:01:21 : Start Data Verification... (Please wait)
11:01:21 : Data Verification Successful...
11:01:21 :
11:01:21 :
11:01:22 : Exit Flash Mode Done...
11:01:22 : Time Elapse : 00:05:14
11:01:22 :
11:01:22 : ************************************************** ****
11:01:22 : You must Factory Reset the phone to enable the
11:01:22 : ringtones and other customized settings to work
11:01:22 :
11:01:22 :
11:01:22 : Waiting For Phone to go Online...
11:01:22 :
11:01:22 : 5,
11:01:22 : 4,
11:01:22 : 3,
11:01:23 : 2,
11:01:23 : 1...
11:01:23 :
11:01:24 : MCU: V 03.25 16-09-11 RH-130 (c) Nokia
11:01:24 : IMEI: 359283043094091
11:01:24 : Product Serial Number: DED0AA0AI
11:01:24 : Product Code : 059M875
11:01:24 : Module Code : 0204875
11:01:25 : Basic Production Code: 059F6X3
11:01:25 : PPM SW Version : V 03.25 16-09-11 RH-130 (c) Nokia AE
11:01:25 : ADSP Version : p V 03.25\n16-09-11\nRH-130\n(c) NMP\nae
11:01:26 : MCU SW Version : V 03.25 16-09-11 RH-130 (c) Nokia
11:01:26 : HW Version : 3051
11:01:26 : UEM Version : 1328
11:01:26 : UPP Version : 8850
11:01:27 : LCD Version : WIN:BARACOAv95 NT39121
11:01:28 : ********** SIMLOCK INFO **********
11:01:28 : CONFIG_DATA : 0010100000000000
11:01:28 : PROFILE_BITS : 0000000000040002
11:01:28 : ASIC : 11
11:01:28 : PROVIDER : Default Test Operator
11:01:28 :
11:01:29 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
11:01:29 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
11:01:29 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
11:01:29 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
11:01:29 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
11:01:29 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
11:01:29 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
11:01:29 : ST_LCD_TEST : PASSED
11:01:30 :
11:01:30 :
11:01:30 : FACTORY SET TO : Full Factory Set
11:01:32 : OK
11:01:32 : FACTORY SET TO : User Data
11:01:32 : OK
11:01:32 : FACTORY SET TO : Leave Factory
11:01:32 : OK
11:01:32 : FACTORY SET TO : Service Center
11:01:32 : OK
11:01:32 : FACTORY SET TO : Software Upgrade
11:01:33 : OK
11:01:33 : FACTORY SET TO : Production Tune
11:01:33 : OK
Old 11-29-2011, 13:24   #11 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,259
try different cnt file,,
br,
WAJID
Old 11-29-2011, 13:37   #12 (permalink)
trmobile2's Avatar
Member: 1483660
Sonork: 100.1601918
Thanks Meter: 155
.....................................Good information ......................................
Old 11-29-2011, 13:51   #13 (permalink)
Member: 715596
Thanks Meter: 244
Old 12-13-2011, 14:02   #14 (permalink)
Member: 1623476
[QUOTE=ktkwajid;7937344]try different cnt file,,
I have tried a different CNt file, Nokia have flashed one phone as a sample and it works perfectly , when i flash it, the flash looks to be ok , but the customizes theme does not take effect
any other ideas
Phil
Old 02-04-2012, 12:09   #15 (permalink)
Member: 91747
UFc cable 6 or 7 ????? Pinout ???? Cyclone ??? More unknown...
Bad Reseller/Bad Manufacturer reported by User GsmMunna HWK 71 01-04-2016 15:55
put in this thread mcu+ppm+cnt files that dont exist in support area aleon HWK 30 12-08-2012 17:27
3350 restarting after flash... xheti Z3X-Team Products 2 10-25-2011 13:28
need flash file tanveer ahmad Dragon Box 1 10-24-2011 10:21
Page generated in 0.41901 seconds with 8 queries
