Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: Extel Telecom . Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks: 83
| again World First! thanks ATF team,X-shadow! Code: Number of Image Files: 3
Processing Image File :
rm827__03.04.mcusw
rm827__03.04.ppm_m4
rm827__03.04.image_m4_059N407
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Sections : 04
Current File : rm827__03.04.mcusw
Compile Name: rm827__03.04.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 27266440 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 43E7
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A82
Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 45C5
Processing Section 04 of 04
FIRMWARE Erase Block: 0x40280000~0x41BBFFFE
Start Erasing...
Block Erase Done...
Data Size: 25952256 bytes
Data Checksum: DCD4
Data Verification Successful...
Sections : 01
Current File : rm827__03.04.ppm_m4
Compile Name: package_m4.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 3675816 Bytes
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x41BC0000~0x421BFFFE
Start Erasing...
Block Erase Done...
Data Size: 3672472 bytes
Data Checksum: 32A4
PPM Data Blocks uploaded to phone...
Sections : 01
Current File : rm827__03.04.image_m4_059N407
Compile Name: package_m4_059N407.image.fls
Image Type : CONTENT Package
Data Size : 14552336 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x421C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 14548992 bytes
Data Checksum: 62ED
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:06:30
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 03.04 20-04-12 RM-827 (c) Nokia
IMEI Plain : 353257058254227
IMEI Spare : A353257058254220
IMEI SV : 33532570582542202F
Phone Model: Nokia 110
Category : Entry Phone
Phone Type : RM-827
Extended Phone Information
Product Serial Number: 2445853BI
Product Code : 059N407
Module Code : 0205081
Basic Production Code: 059K3X3
Long Production SN : 0
PPM SW Version : V 03.04 20-04-12 RM-827 (c) Nokia M4
BT MCM Version : 19b5-22012
MCU SW Version : V 03.04 20-04-12 RM-827 (c) Nokia
HW Version : 2100
RFIC Version : 68
LCD Version : TPO
FWID Version : jV 03.04 20-04-12 RM-827 (c) Nokia V 03.04 20-04-12 RM-827 (c) Nokia M4 059N407 001
Content Pack Version : Content: m4_059N407 V 03.04 20-04-12 RM-827 (c) Nokia
Bluetooth ID : D0:DB:32:DD:96:EB
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : NI00CS0000040C21AC67
DCC Ver: 004032
Status : OK
Selected VPL File:
RM827_059N407_03.04_017.vpl
Variant Details : RM-827 MEA_M4_CYAN_ARABIC_BH
Software Version : 03.04
Product Type : RM-827
Variant Version : 017
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Life timer data is not yet used...
Life timer: ----:-- ![]() ScreenShOt!! ![]() Flash file https://hotfile.com/dl/158450459/1ec...RABIC.rar.html After Flash |
| The Following 26 Users Say Thank You to WAJID PNR For This Useful Post: |
| | #3 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 651945 Status: Offline Thanks: 19
| @ALL Need to click "UPDATE IMPORTANT FILES" so that you will get 110 RM-827 112 RM-837 113 RM-871 Inside your Nokia.ini or just download the Nokia.ini attached on this message. http://174.120.45.27/tmp/Nokia.ini Special Thanks to WAJID who was patient and resourceful enough to TEST the PHONE's USB PINOUTS. The Phone can only be flashed via USB Connection, but NOKIA was too cheap to put an actual USB Port to this Phone. That is why you should use the Phone Pinouts described by Wajid in POST #1. B.R. X-Shadow |
| | #13 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 192810 Status: Offline Thanks: 615
| Nokia 110(RM-827) 100% Flashing Done by ATF box Quote:
![]() Br, Irfan Sheikh | |
| The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
| | #14 (permalink) |
| Here is Indonesian Firmware for 110 RM-827 https://hotfile.com/dl/158655654/543...NESIA.rar.html B.R. |
| The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
