09-03-2013, 19:45 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | ATF First In The World Nokia 208 Full Flashing !! Here is the Screenshot: Here is the Flashing Logs: Code: Number of Image Files: 3 Processing Image File : rm949__03.39.mcusw Processing Image File : rm949__03.39.ppm_m4 Processing Image File : rm949__03.39.image_m4_059S5L0 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F01650A9070100030101E00018090024695348B000B5FFFF <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: E000180900246953-48B000B5 Original Product Code: 059S5L0 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356698053327129\356698053327129_104230.rpl Current File : rm949__03.39.mcusw Number of Images: 8 psi_flash_unsigned.fls slb_signed.fls main_toc_signed.fls rm949__03.39.mcusw_signed_mcusw.fls swap_signed.fls s dynsw.fls aeneas_signed.fls s fota_signed.fls s Processing Data Block 0x00 Erase Block: 0x00090000~0x000A0FAE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x60000000~0x6003FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x02 Erase Block: 0x60040000~0x600403FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x03 Erase Block: 0x62E00000~0x63D3A85A Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xFFF00000~0xFFF7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Processing Data Block 0x04 Erase Block: 0x80000000~0x80C28D22 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x05 Erase Block: 0x62080000~0x620C3FFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x06 Erase Block: 0x63F79C00~0x63FC046E Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x07 Erase Block: 0x61F00004~0x6204566A Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm949__03.39.ppm_m4 Number of Images: 1 package_m4.ppm_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x80F00000~0x815CAE46 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm949__03.39.image_m4_059S5L0 Number of Images: 1 package_m4_059S5L0.image.fls Processing Data Block 0x00 Erase Block: 0xA1000000~0xA2DBA3FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xAE000000~0xAE2FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:00:14 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.39 07-08-13 RM-949 (c) Nokia IMEI Plain : 356698053327129 IMEI Spare : A356698053327120 IMEI SV : 33566980533271219F IMEI (2nd) : 356698053327137 IMEI Spare : A356698053327130 IMEI SV : 33566980533271319F Phone Model: Nokia 208 Dual SIM Category : Phone Phone Type : RM-949 ================================================ Extended Phone Information ================================================ Product Serial Number: C6F5DD4BI Product Code : 059S5L0 Module Code : 0205614 Basic Production Code: 059S0K7 Long Production SN : 0 PPM SW Version : V 03.39 07-08-13 RM-949 (c) Nokia M4 ADSP Version : PMU_MAXIM8939B MCU SW Version : V 03.39 07-08-13 RM-949 (c) Nokia HW Version : 1500 UEM Version : 18 UPP Version : MFR:0x20,DEV:0x40,REV:0x131 RFIC Version : 152 LCD Version : TPO Camera : 0FD00F22006011 Content Pack Version : Content: m4_059S5L0 V 03.39 07-08-13 RM-949 (c) Nokia AHNE Version : 13 RETU Version : PMU_MAXIM8939B Bluetooth ID : 2C:CC:15:A9:49:80 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 0FD00F22 DCC Ver: 006011 Status : OK ====================================================== Selected VPL File: RM949_059S5L0_03.39_018.vpl ====================================================== Variant Details : RM-949 MEA_M4_BLACK_ARABIC_BH Software Version : 03.39 Product Type : RM-949 Product Code : 059S5L0 Variant Version : 018 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Life timer data is not yet used... Life timer: ----:-- @Advance-Box its my b'day gift!! BR, |
The Following 18 Users Say Thank You to WAJID PNR For This Useful Post: |
10-29-2013, 10:55 | #8 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Bahawal Nagar
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | not factory resettings after full flash what kind of drievrs it required ??? just hang on test mod and ask for (nokia 208 dual sim ) drievrs |
