Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-24-2014, 20:45   #16 (permalink)
Member: 2212971
Booting Phone via USB...
USB Phone BUSCheck Boot
Then Perform Steps 1, 2, and 3...
1. Remove USB Cable and Battery...
2. Connect USB Cable.
3. Connect Battery.
***** IF PHONE STARTS CHARGING OR DOES NOT BOOT *****
******* REMOVE BATTERY AND PUT IT BACK AGAIN. *******
ERROR: Access violation at address 73F42272 in module 'WINUSB. DLL'. Read of address FFFFFFFF
ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF
ERROR: BOOTING FAILED...
ERROR: Boot Failed!
i use Advance Turbo Flasher v11.60, connected with win8 64bit pc
and nokia 301 RM-840 connented with usb cable to pc
Old 07-24-2014, 22:17   #17 (permalink)
Member: 2212971
3. Connect Battery.
Infineon Boot: F01650A9070100030101E03008121004A23459FA6E34FFFF
CPU Type: Intel XG618
<<<< Connect Battery Now >>>>
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Unique Data: E03008121004A234
Original Product Code: 059S6J0
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\Program Files (x86)\AdvanceBox Turbo Flasher\Nokia\Backup\359956055525992\3599560555259 92_231507. rpl
Infineon USB Buscheck Done
Phone Restart Mode: TEST MODE
Process Done...
Scanning USB Ports...
ERROR: Active Phone Handle was NOT DETECTED
TIP: Make sure that Phone USB Connection Mode is
OVI Suite Mode
or
PC Suite Mode
ERROR: Read Phone Failed!
Old 07-28-2014, 08:56   #18 (permalink)
Member: 2212971
hello
any idea?
thanks for help
Old 07-30-2014, 14:14   #19 (permalink)
Member: 1740101
Sonork: 100.1641580
Thanks Meter: 11
my atf ver is 10.00..... then y atf is not connecting this phone
Old 03-09-2015, 13:11   #20 (permalink)
Member: 2169218
thannnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnx bro
Old 10-05-2015, 13:49   #21 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 659
https://www.4shared.com/photo/Ddp77jIhba/nokia_301.html
nokia 301 flashing error plz help me
Number of Image Files: 3
Processing Image File :
EA7DF73E_rm840__02.03b.mcusw
7F6CA453_rm840__02.03b.ppm_e3
81A97439_rm840__02.03b.image_e3_059R1S2
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
3. Connect Battery.
Infineon Boot: F01650A9070107030101E030001200080D235AE68636FFFF
Sending PBL...
Sending SBL...
Unique Data: E030001200080D23
Current File : EA7DF73E_rm840__02.03b.mcusw
Number of Images: 8
psi_flash_unsigned.fls
slb_signed.fls
main_toc_signed.fls
rm840__02.03b.mcusw_signed_mcusw.fls
swap_signed.fls s
dynsw.fls
aeneas_signed.fls s
fota_signed.fls s
Processing Data Block 0x00
ERROR: ReqSecStart FAILED A 0x4100
Old 02-28-2017, 10:39   #22 (permalink)
alamtelecom458's Avatar
Member: 2006027
Sonork: 1645658
Thanks Meter: 36
how to unlock this phone 20digit code
rm-840
Page generated in 0.17216 seconds with 8 queries
