07-24-2014, 20:45 | #16 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2212971 Status: Offline Thanks Meter: 0 | ================================================== ==== ================================================== ==== USB Phone BUSCheck Boot ================================================== ==== ================================================== ==== Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ================================================== ==== ERROR: Access violation at address 73F42272 in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: Access violation at address 73F4213B in module 'WINUSB. DLL'. Read of address FFFFFFFF ERROR: BOOTING FAILED... ERROR: Boot Failed! i use Advance Turbo Flasher v11.60, connected with win8 64bit pc and nokia 301 RM-840 connented with usb cable to pc |
07-24-2014, 22:17 | #17 (permalink) |
Member: 2212971 Status: Offline Thanks Meter: 0 | Booting Phone via USB... ================================================== ==== ================================================== ==== USB Phone BUSCheck Boot ================================================== ==== ================================================== ==== Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ================================================== ==== Infineon Boot: F01650A9070100030101E03008121004A23459FA6E34FFFF CPU Type: Intel XG618 <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: E03008121004A234 Original Product Code: 059S6J0 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\Program Files (x86)\AdvanceBox Turbo Flasher\Nokia\Backup\359956055525992\3599560555259 92_231507. rpl Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... Scanning USB Ports... ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ================================================== ==== ERROR: Read Phone Failed! |
10-05-2015, 13:49 | #21 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | https://www.4shared.com/photo/Ddp77jIhba/nokia_301.html nokia 301 flashing error plz help me Number of Image Files: 3 Processing Image File : EA7DF73E_rm840__02.03b.mcusw Processing Image File : 7F6CA453_rm840__02.03b.ppm_e3 Processing Image File : 81A97439_rm840__02.03b.image_e3_059R1S2 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ================================================== ==== Infineon Boot: F01650A9070107030101E030001200080D235AE68636FFFF CPU Type: Intel XG618 <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: E030001200080D23 Current File : EA7DF73E_rm840__02.03b.mcusw Number of Images: 8 psi_flash_unsigned.fls slb_signed.fls main_toc_signed.fls rm840__02.03b.mcusw_signed_mcusw.fls swap_signed.fls s dynsw.fls aeneas_signed.fls s fota_signed.fls s Processing Data Block 0x00 ERROR: ReqSecStart FAILED A 0x4100 |
