05-25-2013, 13:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | ATF First In The World Nokia 301/3018 (XG618) Full Flashing ATF always First, No Matter its new model or not, ATF Ready To do , get ATF work should b more easier !! its Beta Version should release full version as soon as possible! Here is Screen Shot , Here is Flashing Log: Code: Number of Image Files: 3 Processing Image File : rm840__02.03b.mcusw Processing Image File : rm840__02.03b.ppm_e3 Processing Image File : rm840__02.03b.image_e3_059R1S2 []: Found 1 active devices. [Nokia USB Phonet]: Opening Connection [Nokia USB Phonet]: Port opened OK! SW: V 02.03b 08-04-13 RM-840 (c) Nokia IMEI: 355520050408630 START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355520050408630\USB_FULL_BACKUP_V 02.03b 08-04-13 RM-840 (c) Nokia_355520050408630__042301.pm Reading Battery Value : 3728 mV Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F01650A9070100030101A0400809000C8DE4493A90B4FFFF <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: A0400809000C8DE4-493A90B4 Original Product Code: 059R1S2 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355520050408630\355520050408630_042309.rpl Current File : rm840__02.03b.mcusw Number of Images: 8 psi_flash_unsigned.fls slb_signed.fls main_toc_signed.fls rm840__02.03b.mcusw_signed_mcusw.fls swap_signed.fls s dynsw.fls aeneas_signed.fls s fota_signed.fls s Processing Data Block 0x00 Erase Block: 0x00090000~0x000A0FDE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x60000000~0x6003FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x02 Erase Block: 0x60040000~0x600403FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x03 Erase Block: 0x62E00000~0x63D03DCA Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xFFF00000~0xFFF7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Processing Data Block 0x04 Erase Block: 0x80000000~0x80C13E9A Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x05 Erase Block: 0x62080000~0x620C3FFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x06 Erase Block: 0x63F79C00~0x63FF046E Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x07 Erase Block: 0x61F00004~0x62045396 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm840__02.03b.ppm_e3 Number of Images: 1 package_e3.ppm_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x80F00000~0x816340E2 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm840__02.03b.image_e3_059R1S2 Number of Images: 1 package_e3_059R1S2.image.fls Processing Data Block 0x00 Erase Block: 0xA1000000~0xA27597FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xAE000000~0xAE2FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:00:13 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 02.03b 08-04-13 RM-840 (c) Nokia IMEI Plain : 355520050408630 IMEI Spare : A355520050408630 IMEI SV : 33555200504086304F Phone Model: Nokia 301 Category : Phone Phone Type : RM-840 ================================================ Extended Phone Information ================================================ Product Serial Number: FECC7F5AH Product Code : 059R1S2 Module Code : 0205267 Basic Production Code: 059P5R1 Long Production SN : 0 PPM SW Version : V 02.03b 08-04-13 RM-840 (c) Nokia E3 ADSP Version : PMU_MAXIM8939B MCU SW Version : V 02.03b 08-04-13 RM-840 (c) Nokia HW Version : 1000 UPP Version : MFR:0x20,DEV:0x40,REV:0x131 RFIC Version : 152 LCD Version : TPO Content Pack Version : Content: e3_059R1S2 V 02.03b 08-04-13 RM-840 (c) Nokia AHNE Version : 13 RETU Version : PMU_MAXIM8939B Bluetooth ID : BC:C6:DB:F3:1A:3D CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 006004 Status : OK ====================================================== Selected VPL File: RM840_059R1J0_02.03b_031.vpl ====================================================== Variant Details : RM-840 MEA_M3_CYAN_ARABIC_JO Software Version : 02.03b Product Type : RM-840 Product Code : 059R1J0 Variant Version : 031 ====================================================== Selected VPL File: RM840_059R1S2_02.03b_030.vpl ====================================================== Variant Details : RM-840 EURO_E3_WHITE_LATIN_RO Software Version : 02.03b Product Type : RM-840 Product Code : 059R1S2 Variant Version : 030 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Life timer data is not yet used... Life timer: ----:-- Here is the device with my ATF !!! Thanks ATF Team, its beta version so wait for till official release will announce here...... Br WAJID |
The Following 14 Users Say Thank You to WAJID PNR For This Useful Post: |
05-26-2013, 11:40 | #6 (permalink) |
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | |
The Following User Says Thank You to WAJID PNR For This Useful Post: |
05-26-2013, 13:29 | #10 (permalink) |
05-28-2013, 20:30 | #12 (permalink) | |
Junior Member Join Date: Feb 2008 Location: dubai Age: 38
Member: 711832 Status: Offline Thanks Meter: 2 | need v9.90 beta verstion plz Quote:
The Following User Says Thank You to rito_softboy For This Useful Post: |
05-29-2013, 16:01 | #13 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
http://forum.gsmhosting.com/vbb/9461672-post1.html BR | |
