10-01-2013, 15:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | ATF First In The World Nokia 515 Full Flashing !!! Here is the Screenshot: Here is Flashing Logs : Code: Number of Image Files: 3 Processing Image File : rm952__05.08.mcusw Processing Image File : rm952__05.08.ppm_m4 Processing Image File : rm952__05.08.image_m4_059T0J1 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F01650A9070100030101E010180900048950495671B5FFFF <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: E010180900048950-495671B5 Original Product Code: 059T0J1 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\357887051115987\357887051115987_62307.rpl Current File : rm952__05.08.mcusw Number of Images: 8 psi_flash_unsigned.fls slb_signed.fls main_toc_signed.fls rm952__05.08.mcusw_signed_mcusw.fls swap_signed.fls s dynsw.fls aeneas_signed.fls s fota_signed.fls s Processing Data Block 0x00 Erase Block: 0x00090000~0x000A0FAE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x60000000~0x6003FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x02 Erase Block: 0x60040000~0x600403FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x03 Erase Block: 0x62E00000~0x63D0CB66 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xFFF00000~0xFFF7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Processing Data Block 0x04 Erase Block: 0x80000000~0x80C2856E Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x05 Erase Block: 0x62080000~0x620C3FFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x06 Erase Block: 0x63F79C00~0x63FC046E Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x07 Erase Block: 0x61F00004~0x6204950A Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm952__05.08.ppm_m4 Number of Images: 1 package_m4.ppm_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x80F00000~0x815CEBB2 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm952__05.08.image_m4_059T0J1 Number of Images: 1 package_m4_059T0J1.image.fls Processing Data Block 0x00 Erase Block: 0xA1000000~0xA30213FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xAE000000~0xAE2FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:00:14 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ Product Serial Number: 271EC9FBH Product Code : 059T0J1 Module Code : 0205689 Basic Production Code: 059S4T1 Long Production SN : 0 PPM SW Version : V 05.08 10-08-13 RM-952 (c) Nokia M4 BT MCM Version : 19e2-4702G12 ADSP Version : PMU_MAXIM8939B MCU SW Version : V 05.08 10-08-13 RM-952 (c) Nokia HW Version : 1000 UEM Version : 18 UPP Version : MFR:0x20,DEV:0x40,REV:0x131 RFIC Version : 152 LCD Version : TPO Camera : 0103B904005005 Content Pack Version : Content: m4_059T0J1 V 05.08 10-08-13 RM-952 (c) Nokia AHNE Version : 13 RETU Version : PMU_MAXIM8939B Bluetooth ID : DC:3E:F8:C9:EE:8F CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 0103B904 DCC Ver: 005005 Status : OK ====================================================== Selected VPL File: RM952_059T0J1_05.08_020.vpl ====================================================== Variant Details : RM-952 MEA_M4_BLACK_ARABIC_BH Software Version : 05.08 Product Type : RM-952 Product Code : 059T0J1 Variant Version : 020 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Life timer data is not yet used... Life timer: ----:-- BR, WAJID Last edited by WAJID PNR; 10-01-2013 at 15:25. |
The Following 16 Users Say Thank You to WAJID PNR For This Useful Post: |
11-22-2013, 17:21 | #5 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1226010 Status: Offline Thanks Meter: 1 | Please help! I have ATF box and I want to flash my NOKIA 515 but when i connect the phone without battery he start to search for "NOKIA USB ROM" driver and i dont have it. I search everywhere to find a solution and nothing!I have already install Nokia Suite, Nokia Conectivity Driver, Nokia Flash Cable Driver and there is no NOKIA USB ROM driver there... |
02-24-2014, 15:14 | #8 (permalink) |
Freak Poster Join Date: Jan 2004 Location: United Arab Emirates Age: 44
Member: 49226 Status: Offline Thanks Meter: 9 | AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ================================================== ==== Unable to detect "Nokia USB Flashing Generic" |
02-24-2014, 15:19 | #9 (permalink) | |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Quote:
03-09-2014, 13:51 | #13 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 550428 Status: Offline Thanks Meter: 25 | nokia 515 phone lock..below is the information i get when i was trying to connect to ATF ================================================== ==== ================================================== ==== USB Phone BUSCheck Boot ================================================== ==== ================================================== ==== Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ================================================== ==== Infineon Boot: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CPU Type: Intel XG618 <<<< Connect Battery Now >>>> Sending PBL... ERROR: PBL was NOT Accepted |
04-12-2014, 12:22 | #15 (permalink) |
Member: 49226 Status: Offline Thanks Meter: 9 | at last I made it!! Number of Image Files: 4 (Mass Memory File Detected) Processing Image File : rm952__09.04.mcusw Processing Image File : rm952__09.04.ppm_m4 Processing Image File : rm952__09.04_sd_empty_4096.fpsimage Processing Image File : rm952__09.04.image_m4_059T0J1 []: Found 1 active devices. [Nokia USB Phonet]: Opening Connection [Nokia USB Phonet]: Port opened OK! START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\\USB_FULL_BACKUP____30403.pm Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ================================================== ==== Infineon Boot: F01650A9070100030101E020081210148B40593060B5FFFF CPU Type: Intel XG618 <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: E020081210148B40 Original Product Code: 059T0J1 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\357887059047323\3578870590473 23_30410.rpl Current File : rm952__09.04.mcusw Number of Images: 8 psi_flash_unsigned.fls slb_signed.fls main_toc_signed.fls rm952__09.04.mcusw_signed_mcusw.fls swap_signed.fls s dynsw.fls aeneas_signed.fls s fota_signed.fls s Processing Data Block 0x00 Erase Block: 0x00090000~0x000A0FAE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x60000000~0x6003FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x02 Erase Block: 0x60040000~0x600403FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x03 Erase Block: 0x62E00000~0x63D0E5FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xFFF00000~0xFFF7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Processing Data Block 0x04 Erase Block: 0x80000000~0x80C2C482 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x05 Erase Block: 0x62080000~0x620C3FFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x06 Erase Block: 0x63F79C00~0x63FC046E Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x07 Erase Block: 0x61F00004~0x620496B2 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm952__09.04.ppm_m4 Number of Images: 1 package_m4.ppm_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x80F00000~0x815CEFA2 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm952__09.04_sd_empty_4096.fpsimage Number of Images: 1 rm952__09.04_sd_empty_4096.fpsimage.fls Processing Data Block 0x00 WARNING: Micro SD Card Not Found! Mass Memory Flashing Skipped... Current File : rm952__09.04.image_m4_059T0J1 Number of Images: 1 package_m4_059T0J1.image.fls Processing Data Block 0x00 Erase Block: 0xA1000000~0xA30331FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xAE000000~0xAE2FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:00:16 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 09.04 03-12-13 RM-952 (c) Nokia IMEI Plain : 357887059047323 IMEI Spare : A357887059047320 IMEI SV : 33578870590473223F IMEI (2nd) : 357887059047331 IMEI Spare : A357887059047330 IMEI SV : 33578870590473323F Phone Model: Nokia 515 Category : Phone Phone Type : RM-952 ================================================ Extended Phone Information ================================================ Product Serial Number: 3AB147DBH Product Code : 059T0J1 Module Code : 0205689 Basic Production Code: 059S4T1 Long Production SN : 0 PPM SW Version : V 09.04 03-12-13 RM-952 (c) Nokia M4 ADSP Version : PMU_MAXIM8939B MCU SW Version : V 09.04 03-12-13 RM-952 (c) Nokia HW Version : 1000 UEM Version : 18 UPP Version : MFR:0xec,DEV:0x40,REV:0x231 RFIC Version : 152 LCD Version : TPO Content Pack Version : Content: m4_059T0J1 V 09.04 10-12-13 RM-952 (c) Nokia AHNE Version : 13 RETU Version : PMU_MAXIM8939B Bluetooth ID : 2C:5A:05:2A:64:A0 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 33377 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 0103B904 DCC Ver: 005005 Status : OK ================================================== ==== Selected VPL File: RM952_059T0J1_09.04_025.vpl ================================================== ==== Variant Details : RM-952 MEA_M4_BLACK_ARABIC_BH Software Version : 09.04 Product Type : RM-952 Product Code : 059T0J1 Variant Version : 025 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
