Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 02-18-2012, 13:35   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
✚✚✚✚✚✚✚✚✚✚✚✚✚ ATF First In The World Nokia Asha 2010 (RM-799) USB Flashing
1. Nokia Asha 2010 was originally announced as Nokia Asha 201...
2. You do not have to download any new ATF Sofware...
It will already work with the current ATF Software Release.
3. Since ATF is the First to Flash this phone, and was the First to
Implement Infineon Flashing, then it means that some team
with a super fat and stinky programmer will become just 100% pure
copy pasters if they will flash this phone... heheheh...
4. We are now back from our Long Vacation
Update Season will start soon!
So Here is the Screenshot!
And Here are the Logs!
Number of Image Files: 3
Processing Image File :
 rm799__11.21.mcusw
 rm799__11.21.ppm_c1
 rm799__11.21_002.image_c1_ctv_gb_v2_9n286
[]: Found 1 active devices.
[Nokia USB Phonet]: Opening Connection
[Nokia USB Phonet]: Port opened OK!
SW: V 11.21 16-01-12 RM-799 (c) Nokia
IMEI: 358260040409995
 START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
 FULL PM Backup Saved to:
 C:\AdvanceBox Application_NEW\Nokia\Backup\358260040409995\USB_FULL_BACKUP_V 11.21 16-01-12 RM-799 (c) Nokia_358260040409995__73508.pm
Reading battery value  : 3756 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
 If Flashing DOES NOT Start in 5 Seconds,
 Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Sections         : 04
Current File    : rm799__11.21.mcusw
Compile Name: rm799__11.21.mcusw_ebl_psi.fls
Image Type   : Main Firmware
Data Size       : 26217864 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
 Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: CC39
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
 Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A46
 Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 12B3
 Processing Section 04 of 04
FIRMWARE Erase Block: 0x40280000~0x41A3FFFE
Start Erasing...
Block Erase Done...
Data Size: 24903680 bytes
Data Checksum: 24F2
Data Verification Successful...
Sections         : 01
Current File    : rm799__11.21.ppm_c1
Compile Name: package_c1.ppm_ebl_psi.fls
Image Type   : PPM Image
Data Size       : 5569976 Bytes
PPM Certificate Block Sent Successfully...
 Processing Section 01 of 01
PPM Erase Block: 0x41A40000~0x4217FFFE
Start Erasing...
Block Erase Done...
Data Size: 5566632 bytes
Data Checksum: 0501
PPM Data Blocks uploaded to phone...
Sections         : 01
Current File    : rm799__11.21_002.image_c1_ctv_gb_v2_9n286
Compile Name: /Workarea/rm799_sw_settings/temp/059N286/CONTENT_CONFIG/package_c1_ctv_gb.image.fls
Image Type   : CONTENT Package
Data Size       : 13896976 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42180000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 13893632 bytes
Data Checksum: 239F
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:04:36
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
             Basic Phone Information
MCU Version: V 11.21 16-01-12 RM-799 (c) Nokia
IMEI Plain : 358260040409995
IMEI Spare : A358260040409990
IMEI SV    : 33582600404099903F
Phone Model: Nokia 2010
Category   : Phone
Phone Type : RM-799
            Extended Phone Information
Product Serial Number: 788E29AAH
Product Code         : 059N4D5
Module Code          : 0205022
Basic Production Code: 059J2K2
Long Production SN   : 0
PPM SW Version       : V 11.21 16-01-12 RM-799 (c) Nokia             C1
BT MCM Version       : 19e2-47026
MCU SW Version       : V 11.21 16-01-12 RM-799 (c) Nokia
HW Version           : 1200
RFIC Version         : Dummy RFIC version
LCD Version          : TPO
FWID Version         : jV 11.21 16-01-12 RM-799 (c) Nokia            V 11.21 16-01-12 RM-799 (c) Nokia             C1 059N4D5 003
Content Pack Version : Content: ctv GB v2 V 11.21 16-01-12 RM-799 (c) Nokia
Bluetooth ID         : 04:5A:95:E7:8C:53
CS Type              : GSM900, GSM1800
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 800000000003000B
ASIC         : 11
PROVIDER     : Default Test Operator
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 12345
PHONE_MODE              : TEST
          Dynamic Camera Configuration
DCC ID  : 06150123
DCC Ver: 008027
Status   : OK
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
Life timer data is not yet used...
Life timer: ----:--
Here is our test Phone!
B.R.
X-Shadow
The Following 34 Users Say Thank You to Advance-Box For This Useful Post:
Old 02-18-2012, 13:38   #2 (permalink)
Member: 823633
Thanks Meter: 1,705
bro nice
atf is best tool in market
Old 02-18-2012, 13:41   #3 (permalink)
sheraz_mobiles's Avatar
Member: 724090
Sonork: 100.1601663
Thanks Meter: 88
nice dear..................
Old 02-18-2012, 13:41   #4 (permalink)
Rizwan ch08's Avatar
Member: 637860
Sonork: 100.1605309
Thanks Meter: 996
br nice.............info
Old 02-18-2012, 13:48   #5 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 760
Very hot update and thnx 4 successfull report.................
Old 02-18-2012, 13:56   #6 (permalink)
Dipankor-ctg's Avatar
Member: 1541551
Sonork: +965 99095810
Thanks Meter: 4,698
Thank You Advance-Box nokia Asha mobile support
Old 02-18-2012, 13:56   #7 (permalink)
lasergsm's Avatar
Member: 1594457
Sonork: 100.1646470
Thanks Meter: 145
feel the power......
Old 02-18-2012, 13:57   #8 (permalink)
-=jeovel=-'s Avatar
Member: 1604158
Sonork: 100.1614304
Thanks Meter: 122
i love this tool
than any other tool
i have so many tools for nokia but only ATF
does not let me down...
Old 02-18-2012, 14:14   #9 (permalink)
lasergsm's Avatar
Member: 1594457
Sonork: 100.1646470
Thanks Meter: 145
please shared flash file!!!!!
Old 02-18-2012, 16:28   #10 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,604
Download from the Nokia Data manager.
Thomas
The Following User Says Thank You to gsmfun For This Useful Post:
Old 02-18-2012, 16:44   #11 (permalink)
.::RanjitSinh::.'s Avatar
Member: 517102
Sonork: 100.1601229
Thanks Meter: 199
All
Time
First in the world....
Old 02-19-2012, 05:07   #12 (permalink)
Registered User
Member: 459809
Thanks Meter: 9
feel the power of atf..................
Old 02-19-2012, 05:51   #13 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,247
atf is best tool..............
Old 02-19-2012, 08:14   #14 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
All Time First in the world ATF....
Plz add nokia x2 02 dual sim USB Flashing
Old 02-19-2012, 21:43   #15 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hi,
It is supported already:
http://forum.gsmhosting.com/vbb/f609...world-1413729/
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Page generated in 0.28797 seconds with 10 queries
