10-14-2014, 18:01 | #19 (permalink) |
Junior Member Join Date: Jan 2014 Location: chidambaram
Member: 2106259 Status: Offline Thanks Meter: 0 | damage charging connector pls say charging ways Thanks for your post charging connector totally damage so pls give me charging ways With advance thanks Rajesh |
12-03-2014, 12:47 | #22 (permalink) |
Junior Member Join Date: Jun 2008 Location: pakistan
Member: 802048 Status: Offline Sonork: [email protected] Thanks Meter: 2 | i need nokia 230 usb driver plzz help me???? Sirrr |
12-03-2014, 12:48 | #23 (permalink) |
Member: 802048 Status: Offline Sonork: [email protected] Thanks Meter: 2 | plzzzzzzzz sir help me |
12-21-2014, 18:38 | #24 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1625456 Status: Offline Sonork: zamir Thanks Meter: 0 | Please share the firmware , because every time I try to read the phone tells me that the patch files are missing , and sends me to add the folder settings and firmware support. |
12-24-2014, 07:03 | #26 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | GETTING ERROR Code: Booting Phone via USB... ====================================================== ====================================================== USB Phone BUSCheck Boot ====================================================== ====================================================== Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== ERROR: Cannot Start WinUSB Handler 0x00 |
The Following User Says Thank You to Hafiz ArslanAli For This Useful Post: |
12-30-2014, 10:05 | #29 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Just Install this Driver - Nokia All Driver Your Problem will Solve .. Success Log .. Code: Number of Image Files: 3 Processing Image File : rm986_14.0.4.mcusw.fls Processing Image File : rm986_14.0.4_059V2P0_eu1.rofs.fls Processing Image File : rm986_14.0.4_059V2P0_eu1.image.fls AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ====================================================== Infineon Boot: F016194200021C030101CA8A140982ECE504D35C9500FFFF CPU Type: Intel XG221 Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: CA8A140982ECE504 Original Product Code: 059V7T8 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\353041061044704\353041061044704_15606.rpl Current File : rm986_14.0.4.mcusw.fls Number of Images: 2 rm986_14.0.4.mcusw.fls.fls rm986_14.0.4.mcusw.fls.fls Processing Data Block 0x00 Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x40060000~0x401BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x40340000~0x421A9A66 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x47E00000~0x47E3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Current File : rm986_14.0.4_059V2P0_eu1.rofs.fls Number of Images: 1 rofs_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x42880000~0x430ABEDA Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm986_14.0.4_059V2P0_eu1.image.fls Number of Images: 1 rm986_14.0.4_059V2P0_eu1.image.fls.image.fls Processing Data Block 0x00 Erase Block: 0x43800000~0x461FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0x47E40000~0x47F1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:02:46 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) ====================================================== Selected VPL File: RM986_059V2P0_14.0.4_078.vpl ====================================================== Variant Details : RM-986 NDT EURO EU1 NULL IT W Software Version : 14.0.4 Product Type : RM-986 Product Code : 059V2P0 Variant Version : 078 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK Wbr, AniAXN |
The Following 2 Users Say Thank You to AniAxn For This Useful Post: |
