Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Dec 2006 Location: Karachi, Pakistan Age: 22
Member: 643472 Status: Offline Sonork: 100.96901 Thanks: 6
| ATF First In The World Nokia Asha 305 (RM-766) Full Flash Here is the Screenshot: ![]() Here is the Flashing Logs: Code:
Number of Image Files: 3
Processing Image File :
rm766__03.60.mcusw
rm766__03.60.ppm_x
rm766__03.60.image_x_059L4D5
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Sections : 04
Current File : rm766__03.60.mcusw
Compile Name: rm766__03.60.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 29117832 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 1369
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 73CD
Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4011FFFE
Start Erasing...
Block Erase Done...
Data Size: 786432 bytes
Data Checksum: 6A2F
Processing Section 04 of 04
FIRMWARE Erase Block: 0x40120000~0x41BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 28065792 bytes
Data Checksum: DF12
Data Verification Successful...
Sections : 01
Current File : rm766__03.60.ppm_x
Compile Name: package_x.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 7841512 Bytes
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x41C00000~0x423FFFFE
Start Erasing...
Block Erase Done...
Data Size: 7838168 bytes
Data Checksum: 6FEB
PPM Data Blocks uploaded to phone...
Sections : 01
Current File : rm766__03.60.image_x_059L4D5
Compile Name: package_x_059L4D5.image.fls
Image Type : CONTENT Package
Data Size : 14421264 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42400000~0x43EDFFFE
Start Erasing...
Block Erase Done...
Data Size: 14417920 bytes
Data Checksum: 4530
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:03:33
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 03.60 06-06-12 RM-766 (c) Nokia
IMEI Plain : 359059049382669
IMEI Spare : A359059049382660
IMEI SV : 33590590493826614F
Phone Model: Nokia 305
Category : Classic Phone
Phone Type : RM-766
Extended Phone Information
Product Serial Number: A239C6AAH
Product Code : 059L0J0
Module Code : 0204884
Basic Production Code: 059F928
Long Production SN : 0
PPM SW Version : V 03.60 06-06-12 RM-766 (c) Nokia X
BT MCM Version : 19b5-22012
MCU SW Version : V 03.60 06-06-12 RM-766 (c) Nokia
HW Version : 1000
RFIC Version : Dummy RFIC version
LCD Version : TPO
FWID Version : aV 03.60 06-06-12 RM-766 (c) Nokia V 03.60 06-06-12 RM-766 (c) Nokia X 001
Content Pack Version : Content: x_059L4D5 V 03.60 06-06-12 RM-766 (c) Nokia
AHNE Version : 11
Bluetooth ID : E8:CB:A1:D5:BE:65
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000003000B
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 0A350160
DCC Ver: 006015
Status : OK
Selected VPL File:
RM766_059L4D5_03.60_029.vpl
Variant Details : RM-766 SEAP_X_SWHITE_NULL_ID
Software Version : 03.60
Product Type : RM-766
Product Code : 059L4D5
Variant Version : 029
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Life timer data is not yet used...
Life timer: ----:-- Here is the Test Phone: ![]() BR |
| The Following 22 Users Say Thank You to ..::Angel::.. For This Useful Post: |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Dec 2007 Location: AvatorBox HelpDesk
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks: 1,214
| Hi thx for the test report by the way picture is good ![]() Br, |
| The Following User Says Thank You to GsmUniversal For This Useful Post: |
| | #9 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 651945 Status: Offline Thanks: 19
| Use Navifirm+ (needs .NET) or NaviFirmEX (don't require .NET) Search for RM-766 with the following Product codes: 059L0H3 - GRAY 059L1F1 - BLUE 059L0V2 - RED 059L4D5 - WHITE NaviFirmEX 1.6.1 can be downloaded here: Downloads - navifirmex - Nokia firmware downloader - Google Project Hosting Make sure after running NaviFirmEX that you click: Option ----> Server and select Nokia Care Suit B.R. |
| The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: Extel Telecom . Dubai.
Member: 625961 Status: Online Sonork: 100.1590447 Thanks: 83
| here is my flash log! Code: Number of Image Files: 4
(Mass Memory File Detected)
rm766__03.60.mcusw
rm766__03.60.ppm_maj
rm766__03.60.image_maj_059L1J3
rm766__03.60_sd_ssa_maj_2048.fpsimage
2. Insert USB.
Sending PBL...
Sending SBL...
Sections : 04
Start Erasing...
Block Erase Done...
Data Checksum: 1369
Start Erasing...
Block Erase Done...
Data Checksum: 73CD
Start Erasing...
Block Erase Done...
Data Checksum: 6A2F
Start Erasing...
Block Erase Done...
Data Checksum: DF12
Sections : 01
Current File : rm766__03.60.ppm_maj
Compile Name: package_maj.ppm_ebl_psi.fls
Data Size : 5875552 Bytes
Start Erasing...
Block Erase Done...
Data Size: 5872208 bytes
Data Checksum: EB71
Sections : 01
Current File : rm766__03.60.image_maj_059L1J3
Compile Name: package_maj_059L1J3.image.fls
Data Size : 13110544 Bytes
Start Erasing...
Block Erase Done...
Data Size: 13107200 bytes
Data Checksum: E1F7
Sections : 01
Current File : rm766__03.60_sd_ssa_maj_2048.fpsimage
Compile Name: rm766__03.60_sd_ssa_maj_2048.fpsimage.fls
Image Type : MASS Memory
SD Card Size : Use 2 GB Cards Only
Always use the CORRECT SD Card Size!!!
Data Size : 225892 Bytes
MASS MEMORY Certificate Block Sent Successfully...
MASS MEMORY Erase Block: 0x30000000~0xFFFFFFFE
Start Erasing...
Block Erase Done...
Data Size: 414380032 bytes
Data Checksum: 9FCC
MASS MEMORY Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:12:11
IMEI Plain : 359059040344205
IMEI Spare : A359059040344200
IMEI SV : 33590590403442014F
Phone Type : RM-766
Product Serial Number: 2F2C8D2BI
Product Code : 059P7W7
Basic Production Code: 059K4Q4
PPM SW Version : V 03.60 06-06-12 RM-766 (c) Nokia MAJ
HW Version : 2000
LCD Version : TPO
FWID Version : cV 03.60 06-06-12 RM-766 (c) Nokia V 03.60 06-06-12 RM-766 (c) Nokia MAJ 001
Content Pack Version : Content: maj_059L1J3 V 03.60 06-06-12 RM-766 (c) Nokia
AHNE Version : 11
Bluetooth ID : 3C:36:3D:52:C4:96
ASIC : 11
PHONE_MODE : TEST
DCC ID : 06150123
DCC Ver: 003002
Status : OK
Selected VPL File:
RM766_059L1J3_03.60_027.vpl
Variant Details : RM-766 MEA_MAJ_SWHITE_NULL_KE
Product Code : 059L1J3
Variant Version : 027
OK
OK
OK
OK
OK
OK
Life timer: ----:-- |
| | #12 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Pakistan
Member: 116955 Status: Online Sonork: 100.1604268 Thanks: 82
| 305 Firmware rm766__03.60.rar |
| The Following 2 Users Say Thank You to sahassan82 For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
