04-29-2010, 16:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 230911 Status: Offline Thanks Meter: 177 | ATF The Flashing Problems 1- 3110 alive but dead with Atf 2- 7210c alive but dead with Atf DCT4 a lot of problems. both of phones i have flashed with all setting i.e. with or without vpp. with or without turbo but no sucess. So I used cyclone box and made these phones alive again. ATF gives error during flashing and phone becomes dead. ATF Team must rectify this problem. |
04-29-2010, 16:43 | #2 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | Quote:
If you have problem like you said you should have post logs here so that the team could figure the problem out. ATF is working Perfectly alright with all others as you can see the posts in forum. Br | |
The Following User Says Thank You to adnann5 For This Useful Post: |
04-29-2010, 16:59 | #6 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Hahaha The same person says bad words about one product while on the other side the same person says Thank YOu to the person that makes objection to his words. |
04-29-2010, 17:09 | #8 (permalink) | |
Member: 21296 Status: Offline Thanks Meter: 328 | Hahaha The same person says bad words about one product while on the other side the same person says Thank YOu to the person that makes objection to his words. Quote:
04-29-2010, 17:15 | #9 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Romania Age: 37
Member: 607365 Status: Offline Sonork: 100.1590583 Thanks Meter: 294 | All phones that I flashed with ATF were alive, not even one dead |
The Following User Says Thank You to faurionutz For This Useful Post: |
04-29-2010, 17:40 | #10 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | i flash this fone after read this post working 100% ok Code: Processing Image File : D:\flash files\3110\rm237__07.21.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 944 Entry Point: 0x44FC Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0E500117 ID DWORD 1 : B75D7056 ID DWORD 2 : CF083367 ID DWORD 3 : 8711FE59 ID DWORD 4 : 963EC11C 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum AE BootCodeLen : 61 SearchForBootstrap_DCT5.. 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x004E (78) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 4B 0 ERASE_AREA_BB5 0x12 Block Length : 0x4B (75) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00020000-0007FFFF 3 : 00080000-000DFFFF 4 : 00100000-001FFFFF 5 : 00200000-0031FFFF 6 : 00320000-0105FFFF 7 : 01060000-01067FFF 8 : 01068000-0107FFFF ERASE_REQUEST_BB5 : 5009120B00000000000000000006BF120B000000000006C00001FFFF120B000000000200000007FFFF120B00000000080000000DFFFF120B00000000100000001FFFFF120B000000002000000031FFFF120B000000003200000105FFFF120B0000000106000001067FFF120B000000010680000107FFFF82 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds >> Time Elapsed 48 seconds >> Time Elapsed 51 seconds >> Time Elapsed 54 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:57 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 Processing : rm237__07.21.mcusw Total blocks to write : 944 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PMM_CONF >> CMT Rootkey Hash CERT : SBIF_CONF ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:05 Making delay between files for Count 1500ms Processing Image File : D:\flash files\3110\rm237__07.21.ppm_mea1 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 179 Entry Point: 0x00A6 Page Format : -1 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0E500117 ID DWORD 1 : B75D7056 ID DWORD 2 : CF083367 ID DWORD 3 : 8711FE59 ID DWORD 4 : 963EC11C 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum AE BootCodeLen : 61 SearchForBootstrap_DCT5.. 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01080000-0151FFFF ERASE_REQUEST_BB5 : 5001120B000000010800000151FFFF88 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:12 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 Processing : rm237__07.21.ppm_mea1 Total blocks to write : 179 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:12 Making delay between files for Count 1500ms Processing Image File : D:\flash files\3110\rm237__07.21.image_mea1 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 208 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 File detected Not 128K format.... Converting image to 128k bit..... Converted file created : D:\flash files\3110\rm237__07.21.image_mea1_128k CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 208 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 Changing MODE : FLASH AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0E500117 ID DWORD 1 : B75D7056 ID DWORD 2 : CF083367 ID DWORD 3 : 8711FE59 ID DWORD 4 : 963EC11C 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum AE BootCodeLen : 61 SearchForBootstrap_DCT5.. 2ND KEYS 2ND CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg SearchForBootstrap_DCT5 : No Error - 0 (0x00) ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 881C -> M39L0R807 Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0020 DevID :881C ExtID :0000 RevID :6A21 RAP3Gv3_algo.fg First Algo byte : C0 BB5 ALGORITHM phone devicealgo : Flash Descriptor Manufacturer Code : 0020 Device ID : 881C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00200000 (2097152) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01FDFFFF ERASE_REQUEST_BB5 : 5001120B0000000152000001FDFFFF92 >> Time Elapsed 3 seconds >> Time Elapsed 6 seconds >> Time Elapsed 9 seconds >> Time Elapsed 12 seconds >> Time Elapsed 15 seconds >> Time Elapsed 18 seconds >> Time Elapsed 21 seconds >> Time Elapsed 24 seconds >> Time Elapsed 27 seconds >> Time Elapsed 30 seconds >> Time Elapsed 33 seconds >> Time Elapsed 36 seconds >> Time Elapsed 39 seconds >> Time Elapsed 42 seconds >> Time Elapsed 45 seconds Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:47 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 Processing : rm237__07.21.image_mea1_128k Total blocks to write : 208 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:14 Total Flashing Time (Booting + Erase + Flashing) : 00:03:44 |
04-29-2010, 19:56 | #12 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | if you need some step by step info about how to flash with ATF or about any settings please contact us on any messengers |
The Following User Says Thank You to Javajohn For This Useful Post: |
04-30-2010, 04:43 | #13 (permalink) |
Freak Poster Join Date: May 2007 Location: PATTAMUNDAI
Member: 508774 Status: Offline Sonork: 100.1590207 Thanks Meter: 207 | Atf is best flashing box for new nokia. First learn how it work then play with atf . Then u know whats atf power. I FLASHED OVER 75 MOBILE ALL OK WORKING FINE. AFTER 2 DAYES I POST HOW TO FLASH IN ATF VIDEO MANUAL. FOR NEW USER HELP THIS TO FLASH MOBILE. |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
