04-02-2016, 05:13 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: unknow location... still seek Age: 43
Member: 178450 Status: Offline Thanks Meter: 54 | atf gold box what type of pcb?? i buy a brand new atf gold box but when i must update fw, asked me what kind of pcb ? what to choose?? i managed to make it work on win7 x64 by disabling driver signature, the box will work ok??? on other laptop sony vaio, the software pop up but not open when box is connected to pc, but atf jtag software work. there is a problem with laptop or box? same happening with atf nitro when i connect to atf jtag, software will se my atf gold box as nitro, there is a problem somewhere? |
04-02-2016, 10:11 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Is obvius there's one conflict with the 2 Boxs installed in you Pc/laptop and Path directory. Try to install each one in 2 HD different or Unistall all in the 2 Pcs then Delete Atf Folder and install in Pc Atf Gold and in Laptop the Nitro. Atf JTAG show becouse sure you have also activated in Nitro. BR allumts |
04-02-2016, 22:28 | #3 (permalink) | |
Member: 178450 Status: Offline Thanks Meter: 54 | Quote:
04-03-2016, 09:07 | #4 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello Quote:
For Jtag just have explained in first answer Why. There's Conflict if you install in same PC and Same directory the 2 Box. Br | |
04-03-2016, 20:56 | #5 (permalink) | |
04-04-2016, 12:09 | #7 (permalink) |
Member: 178450 Status: Offline Thanks Meter: 54 | if you are able to give a good answer, ok, if not, don't try to make more posts. i asked (not spammed) if there are a server error. read again my posts, all was deleted, cleaned, installed again sw and drivers, but in atf jtag show as nitro atf gold box. |
04-04-2016, 14:37 | #8 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | You continue Spamming and will be deleted all usefull you post. Lol lock here how have done solve Easy the Problem of "ERROR SERVER CONNETCTION": http://forum.gsmhosting.com/vbb/11735141-post151.html So, i've repeat Very more times, problem is only from you side, SERVER IS WORKING 100% Perfect!!! |
04-06-2016, 16:41 | #9 (permalink) | |
04-06-2016, 16:41 | #10 (permalink) | |
04-06-2016, 18:58 | #11 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Solving alone. Have just helped enough and you reply me w/o to be greatfull for Help? ok solve you problem alone, there are Sticky Thread and use Search button, Next time learn to be more humble and thanking BR |
04-06-2016, 20:12 | #12 (permalink) | |
b.r | |
