12-04-2014, 04:14 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ahmedhakim This phone can be repaired via SDC Unbricker... So just download this: ATF Offcial Support Area / file-support / Samsung SDC Files / GT-I9200 / GT-I9200_4.4.2_8GB_I9200XXUDNF3.sdc Write it to an 8GB SDHC card via ATF Plus "SDC Tool". Then insert it to your phone and enter download mode. You need to flash phone with 4.4.2 firmware only in ODIN. You cannot flash lower version, it will fail. If SDC Does not work, then you can do eMMC Direct TP method |
12-04-2014, 04:14 | #3 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ahmedhakim This phone can be repaired via SDC Unbricker... So just download this: ATF Offcial Support Area / file-support / Samsung SDC Files / GT-I9200 / GT-I9200_4.4.2_8GB_I9200XXUDNF3.sdc Write it to an 8GB SDHC card via ATF Plus "SDC Tool". Then insert it to your phone and enter download mode. You need to flash phone with 4.4.2 firmware only in ODIN. You cannot flash lower version, it will fail. If SDC Does not work, then you can do eMMC Direct TP method Last edited by Advance-Box; 12-04-2014 at 04:45. |
12-04-2014, 04:58 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Also here is .mmc file for use with ATF Plus ---> eMMC Tool... ATF Offcial Support Area / file-support / Samsung EMMC Repair Files / GT-i9200_8GB_4.4.2_I9200XXUDNF3.mmc B.R. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
08-06-2016, 06:19 | #6 (permalink) |
Junior Member Join Date: Feb 2010 Location: hochiminh city vietnam
Member: 1241627 Status: Offline Thanks Meter: 5 | anyone help me! al testpoit ok but not detect emmc! i need pinout emmc for atf jtag and file via jtag! thank PS:try sdc phone start download mod ok but flash via odin fail, tried many files not ok, atf plus not ok not detect emmc or wrong pinout? |
