Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 08-20-2015, 11:17   #1 (permalink)
Blaze25's Avatar
Member: 554923
Thanks Meter: 73
ATF Installation catastrophic error pls help me!! <<< SOLVED >>>
Hi ATF team please help me how to solve this,fresh format pc then install atf old & latest setup same error found,please help me?
Old 08-20-2015, 11:20   #2 (permalink)
Member: 1328371
Thanks Meter: 62
Check if your computer have local disk C: ,maybe it is local disk D:
The Following User Says Thank You to john kenneth For This Useful Post:
Old 08-20-2015, 11:30   #3 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 1,556
Latest Full installer is v12.40 Mate.
Br,
xerraco
The Following User Says Thank You to xerraco For This Useful Post:
Old 08-20-2015, 11:32   #4 (permalink)
Blaze25's Avatar
Member: 554923
Thanks Meter: 73
2 partitions sir install at my pc,local c and d...
i try also 12.40 but same error sir...
Old 08-20-2015, 11:37   #5 (permalink)
Member: 1328371
Thanks Meter: 62
did you try to change local disk installation folder to D: instead of C: ?
Old 08-21-2015, 01:41   #6 (permalink)
Automatico's Avatar
Member: 2140790
Sonork: 100.1679059
Thanks Meter: 192
Hi...
The Clock. i see 08/20/2015, in my pc is 20/08/2015 (check time clock)
and.. delete all ftdi and folder About JAF and Mx Key. Install Latest FTD ATF Drivers.-
ATF exe is protected with a Paranoid xxx (exclude antivirus atf path)
(install last Installer) with a path excl* for ATF exe in your antivirus.
good luck
aUTo
The Following User Says Thank You to Automatico For This Useful Post:
Old 08-21-2015, 06:13   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,261
Knock me on sonork
Br - srinibas
The Following 2 Users Say Thank You to srinibas For This Useful Post:
Old 08-21-2015, 12:19   #8 (permalink)
Blaze25's Avatar
Member: 554923
Thanks Meter: 73
Originally Posted by srinibas View Post
Knock me on sonork
Br - srinibas
i dont know how to knock you at sonork sir..,eversince i cannot use a sonork so i dont know how sonork work.
this is my 1st time to switch at windows 7 running system,i think there is a problem at windows7 system.
Old 08-22-2015, 04:39   #9 (permalink)
Blaze25's Avatar
Member: 554923
Thanks Meter: 73
Win32/Paite.B virus = found guilty .....
Solutions:
Uninstall smadav and install nod32 v3
Please CLOSED thread..
Problem SOLVE.
Thanks ...
The Following User Says Thank You to Blaze25 For This Useful Post:
Old 08-22-2015, 18:26   #10 (permalink)
Automatico's Avatar
Member: 2140790
Sonork: 100.1679059
Thanks Meter: 192
Solutions:
Problem SOLVE.
Thanks ...
Good Job my friend....
Is just a Paranoid warning. (what for a NOD32?) Use Microsoft Security Essecials, is free and easy for exclude path (directory and exe files)(protection by ATF Team, but is not a Virus) for Non copy paste from other Team.-
Regards
aUTo
Old 10-07-2018, 13:47   #11 (permalink)
Member: 2281888
i too had same problem install k7 total security Anti virus and scan full pc and install it works...
Page generated in 0.64360 seconds with 7 queries
