12-03-2013, 08:55 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | 1. Download Dual RS232-HS Drivers here: http://www.ftdichip.com/Drivers/CDM/...0Certified.zip 2. Install Drivers for Dual RS232-HS from #1 3. When Drivers are all installed, disconnect ALL OTHER GSM BOXES FROM YOUR PC USB PORT. MAKE sure only ATF BOX is connected!!! 4. Goto "Product Support" =====> "Box Tools" =====> click "Restore EEPROM" 5. When it Finishes, disconnect ATF BOX from USB Port then close ATF Software 6. Connect ATF Box to USB port and FORCE WINDOWS to use Drivers from: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\ *** PLEASE DO NOT LET WINDOWS AUTO-INSTALL the DRIVERS AUTOMATICALLY because you will have never ending problems if you do... I really want you to FORCE WINDOWS to use Correct ATF Drivers ****** IF done step by step, your problems will be solved. B.R. |
12-03-2013, 10:59 | #3 (permalink) | |
Freak Poster Join Date: Jul 2012 Location: Kannur,Kerala,India Age: 29
Member: 1779640 Status: Offline Thanks Meter: 16 | Quote:
