ATF J-tag Can Unlock Bootloader (Qualcomm OSBL), not Repair boot Or Unlock, Only Unlock Bootloader (Qualcomm OSBL) Phone is working
Because software ATF Not Work Unlock bootloader Nokia Lumia 900
14:46:56 : eMMC Test Point Connection Module
14:46:56 : ================================================== ====
14:46:56 :
14:46:56 : 1. DO NOT USE THE PHONE"S BATTERY
14:46:56 : 2. Connect the Soldered TP Connections to ATF Box
14:46:56 : 3. Disconnect the USB Cable and Wait until the
14:46:56 : the ATF Software will tell you to Connect the USB.
14:46:56 :
14:46:56 : MMC_TP_SEND_CMD: 0200000000A9FF
14:46:56 : MMC_TP_SEND_CMD: 8202FF010191
14:46:57 : MMC_TP_SEND_CMD: 8202FF010191
14:46:58 : MMC_TP_SEND_CMD: 8202FF010191
14:46:59 : MMC_TP_SEND_CMD: 8202FF010191
14:47:00 : MMC_TP_SEND_CMD: 8202FF010191
14:47:01 : MMC_TP_SEND_CMD: 8202FF010191
14:47:02 : MMC_TP_SEND_CMD: 8202FF010191
14:47:02 : ERROR: EMMC WAS NOT Detected! (CMD1)
14:47:02 : Check your Test Point Soldering!
14:47:02 : CMD1 Reply: 0x5E5E5E5E
14:47:10 : ERROR: Select Correct Phone Type!
14:47:10 :
14:47:10 : Total Elapsed Time 00:00:00
14:47:11 : ERROR: Select Correct Phone Type!
14:47:11 :
14:47:11 : Total Elapsed Time 00:00:00
14:47:12 : ERROR: Select Correct Phone Type!
14:47:12 :
14:47:12 : Total Elapsed Time 00:00:00
14:47:12 :
14:47:12 :
14:47:12 :
14:47:17 : ================================================== ====
14:47:17 : eMMC Test Point Connection Module
14:47:17 :
14:47:17 : 1. DO NOT USE THE PHONE"S BATTERY
14:47:17 : 2. Connect the Soldered TP Connections to ATF Box
14:47:17 : 3. Disconnect the USB Cable and Wait until the
14:47:17 : the ATF Software will tell you to Connect the USB.
14:47:17 :
14:47:17 : MMC_TP_SEND_CMD: 0200000000A9FF
14:47:17 : MMC_TP_SEND_CMD: 8202FF010191
14:47:18 : MMC_TP_SEND_CMD: 8202FF010191
14:47:19 : MMC_TP_SEND_CMD: 8202FF010191
14:47:20 : MMC_TP_SEND_CMD: 8202FF010191
14:47:21 : MMC_TP_SEND_CMD: 8202FF010191
14:47:22 : MMC_TP_SEND_CMD: 8202FF010191
14:47:23 : MMC_TP_SEND_CMD: 8202FF010191
14:47:23 : ERROR: EMMC WAS NOT Detected! (CMD1)
14:47:23 : Check your Test Point Soldering!
14:47:23 : CMD1 Reply: 0x5E5E5E5E
14:47:23 :
14:47:23 : BOOT Images Written Successfully!
14:47:23 :
14:47:23 : Total Elapsed Time 00:00:06
