03-06-2013, 03:20 | #1 (permalink) |
Registered User Join Date: Aug 2010
Member: 1359163 Status: Offline Thanks Meter: 37 | atf light v9.61 lumia800 patch bit not found <<< SOLVED - Solution Inside >>> I have two pieces of nokia lumia 800 to unlock in first one program shows Lumia 800/800C Detected log : ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0014D9D4 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:10:17 and unlock phone But second one log program not recognise lumia 800/800c and log is: ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 10870268 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... WARNING: Patch Bit NOT FOUND! Maybe Phone is already UNLOCKED! Total Elapsed Time 00:28:44 -------- its necessary to reflash this phone in atf v9.61 because navi firm is off. and atf support dont have windows flash file |
The Following User Says Thank You to konaku For This Useful Post: |
03-06-2013, 22:57 | #5 (permalink) | |
Member: 1359163 Status: Offline Thanks Meter: 37 | Quote: Windows Phone Flashing Started ADSP File Found: RM801_12w22_1_prod_generic_adsp.esco AMSS File Found: RM801_12w22_1_prod_generic_amss.esco OSBL File Found: RM801_12w22_1_prod_generic_nokia_osbl.esco USER AREA ERASE File Found: RM801_12w22_1_prod_generic_user_area_erase.esco WPOS File Found: RM801_12221_prod_253_02_boot.esco ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes Status : WRITE OSBL CERTIFICATE SUCCESS Sending OSBL Data Blocks [BLOCK 1 0x00000000~0x000EA227] Data Size: 0x000EA228 Bytes SHA-256 : 9F4677ED1FBE63D145267113655B48FB ---------- : 2E0DCC7376A77735EF0969024D03761B Status : OSBL WRITE SUCCESS Sending AMSS Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 449 Bytes Status : WRITE AMSS CERTIFICATE SUCCESS Sending AMSS Data Blocks (Please Wait for 25 Seconds...) Status : AMSS WRITE SUCCESS Sending ADSP Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 449 Bytes Status : WRITE ADSP CERTIFICATE SUCCESS Sending ADSP Data Blocks (Please Wait for 25 Seconds...) Status : ADSP WRITE SUCCESS Sending WPOS Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 1604 Bytes ERROR: Data Rejected at SEQ 0x188 Status : WRITE WPOS CERTIFICATE FAILED after that try to reflash but have: ERROR: Data Rejected at SEQ 0x1 ERROR: Data Rejected at SEQ 0x2 Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED ------------- I must repair boot , and reflash phone ?? | |
03-06-2013, 23:44 | #6 (permalink) |
Member: 1359163 Status: Offline Thanks Meter: 37 | third try log : Windows Phone Flashing Started OSBL File Found: RM801_12w22_prod_generic_nokia_osbl.esco AMSS File Found: RM801_12w22_prod_generic_amss.esco ADSP File Found: RM801_12w22_prod_generic_adsp.esco WPOS File Found: RM801_12220_prod_490_01_boot.esco USER AREA ERASE File Found: RM801_12w22_prod_generic_user_area_erase.esco ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes Status : WRITE OSBL CERTIFICATE SUCCESS Sending OSBL Data Blocks [BLOCK 1 0x00000000~0x000EA227] Data Size: 0x000EA228 Bytes SHA-256 : 9F4677ED1FBE63D145267113655B48FB ---------- : 2E0DCC7376A77735EF0969024D03761B Status : OSBL WRITE SUCCESS Sending AMSS Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 449 Bytes Status : WRITE AMSS CERTIFICATE SUCCESS Sending AMSS Data Blocks (Please Wait for 25 Seconds...) Status : AMSS WRITE SUCCESS Sending ADSP Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 449 Bytes Status : WRITE ADSP CERTIFICATE SUCCESS Sending ADSP Data Blocks (Please Wait for 25 Seconds...) Status : ADSP WRITE SUCCESS Sending WPOS Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 1604 Bytes Status : WRITE WPOS CERTIFICATE SUCCESS Sending WPOS Data Blocks [BLOCK 1 0x00000000~0x00FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 3AC1592FDFEEAF34A071E0A03C616BA9 ---------- : 7519F1434E6AF233A2D3973FBA9B50FD Status : WPOS WRITE SUCCESS [BLOCK 2 0x01000000~0x016573FF] Data Size: 0x00657400 Bytes SHA-256 : C601E6AD8A05A305D93FB8E15D529441 ---------- : 92472FF6E7C709F1665544D931E39CF8 Status : WPOS WRITE SUCCESS [BLOCK 3 0x01697400~0x01FFFFFF] Data Size: 0x00968C00 Bytes SHA-256 : E04C53BD4EA45F51616BE9F4EEB5D101 ---------- : 8778E6A0FF592D2E93BDB37B4FE5BFD3 Status : WPOS WRITE SUCCESS [BLOCK 4 0x02000000~0x02FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 840331B32935B1E6B48F3AA73A056FA4 ---------- : 673DE23F95DA089D1E7B4D452B73751B Status : WPOS WRITE SUCCESS [BLOCK 5 0x03000000~0x03FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 10D13F69B6E4AD6D94F5F9E136265B58 ---------- : C0CF7FAF48F63483EB9F11FCA6033725 Status : WPOS WRITE SUCCESS [BLOCK 6 0x04000000~0x04FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 5F0EA31C4F7AA32CA823D3527FD1F845 ---------- : 298A11B91A9B78CBDBF4363D14509343 Status : WPOS WRITE SUCCESS [BLOCK 7 0x05000000~0x05FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 4ECF4462A41D6BC66F66537EA2AE0F5B ---------- : 0398DADB9CECAE4C99CB62BF066EBE1C Status : WPOS WRITE SUCCESS [BLOCK 8 0x06000000~0x06FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 16B60F1384EB9486484BCC98C5576CEB ---------- : 5A87B4F40B4B40E47A5DED760BF00A45 Status : WPOS WRITE SUCCESS [BLOCK 9 0x07000000~0x07FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 9E2555F97ECFEDC2A97AA9D7E76EC81D ---------- : 17769AE8C62EDFC59F2F64E84ED3FFF5 Status : WPOS WRITE SUCCESS [BLOCK 10 0x08000000~0x08FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : E4F45FE1DE8BC653BC6F043A6F3F0842 ---------- : A8F020C6920459D84C5EE4A96F40062D Status : WPOS WRITE SUCCESS [BLOCK 11 0x09000000~0x09FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : BB2958160269F49AE0ABEF78EA1666D7 ---------- : 2BBAC7F571E685F01E4B68353F4165E2 Status : WPOS WRITE SUCCESS [BLOCK 12 0x0A000000~0x0AFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 3D0F69A109A94A85D579F8D535965623 ---------- : C1F3ABE36A9F5024DE95848D365761C4 Status : WPOS WRITE SUCCESS [BLOCK 13 0x0B000000~0x0BFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 16F403BAB1A3B696030F76C39F993CC6 ---------- : 61F852E17AA49E0C2798756CB2E7CA91 Status : WPOS WRITE SUCCESS [BLOCK 14 0x0C000000~0x0CFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 31E498E94E289716658BE8FD0EBB69CD ---------- : A24CAA5726BDCF44B2738AC4257D97FC Status : WPOS WRITE SUCCESS [BLOCK 15 0x0D000000~0x0DFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 13DC9B20F455AACE7282E80056FAD4B3 ---------- : F55BD838085190F92316751B0B726173 Status : WPOS WRITE SUCCESS [BLOCK 16 0x0E000000~0x0EFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : E22418861E819BE8874CC23F39A44E7B ---------- : 559821B1BC0C25A3F4BF8BBE7D002D2C Status : WPOS WRITE SUCCESS [BLOCK 17 0x0F000000~0x0FFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 6BFE486CBDE3785CB683D0CE1F3DE100 ---------- : 34B3C774D0D1A8F97C306A34F6CEA70A Status : WPOS WRITE SUCCESS [BLOCK 18 0x10000000~0x10FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : AF343A16EF1A34A6B7A0CC5F84AF3224 ---------- : AA0EB77FFBA8073F77A4F359B5C56ABB Status : WPOS WRITE SUCCESS [BLOCK 19 0x11000000~0x11FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 27FA4B34ECE7744E0B1846CE68408012 ---------- : 3C57BF31275A8B2EDC43C5F584BE06A4 Status : WPOS WRITE SUCCESS [BLOCK 20 0x12000000~0x12FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : D899079C45286805FEB0FD4F6EFF0984 ---------- : 75CC5CD62906A7A92D0C64E0F0B3772E Status : WPOS WRITE SUCCESS [BLOCK 21 0x13000000~0x13FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 266B84980A43162209AED050688A1790 ---------- : 65ADFBD7B345F7CAB67697A947346B68 Status : WPOS WRITE SUCCESS [BLOCK 22 0x14000000~0x14FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 085B2D2B874C6FFC0717B6397B29081B ---------- : 7FC7DF6EFD16A3ED02AA50E7BDDA5DC4 Status : WPOS WRITE SUCCESS [BLOCK 23 0x15000000~0x15FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : E3C504D99751D61C4886F77FF6A050C1 ---------- : C80B1FD1F9623E586061FCC24B9A1EE3 Status : WPOS WRITE SUCCESS [BLOCK 24 0x16000000~0x16FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : F418EE3617DBA510EB2738C67CCC9299 ---------- : 2F1E4C3255D066CC45904A58BC3E6E4F Status : WPOS WRITE SUCCESS [BLOCK 25 0x17000000~0x17FC91FF] Data Size: 0x00FC9200 Bytes SHA-256 : 9E675DD284AEFD91D7DBA34A4C6B67D6 ---------- : AFAA60EC658FED1DAACCEC99002E06C5 Status : WPOS WRITE SUCCESS Sending USER AREA ERASE Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 396 Bytes Status : WRITE ERASE CERTIFICATE SUCCESS Erasing USER AREA Status : ERASE SUCCESS Flashing Done! Total Flashing Time (Erase + Flashing) : 00:06:47 -------------- unlock process: ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 10870268 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:32:03 |
03-17-2013, 21:06 | #7 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Quote: iam trying to flash the phone but it goes in QSb qualcom mode! do i have to do testpoint again to flash DLOAD to phone or i can just flash it thru usb? PLS inform? WBR ReyTech. | |
03-17-2013, 21:13 | #8 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ReyTech You can go back to DLOAD via USB using ATF "eMMC Direct" tab when you select Windows Phone in the ATF Software. You will see there an option " Restore DLOAD". B.R. |
03-17-2013, 23:13 | #9 (permalink) |
Member: 135945 Status: Offline Thanks Meter: 85 | Tks for ur reply, so even without using test points only thru usb cable ican flash Dload to lumia 800 phone, using the emmc tab right? Wbr ReyTech Sent from my GT-N8000 using Tapatalk 2 |
03-19-2013, 18:58 | #10 (permalink) | |||
iam trying to scan partition but it does't! i ve seen the phone when i press (volumne+ and usb) the phone gets recognised as (HID-compliant device)and very strange is that this phone does't even gets connected thru test points as well! all i can do is switch it on and detect it and i get the below info Quote:
pls inform me what could be the problem? WBR ReyTech. | |||
03-22-2013, 10:34 | #11 (permalink) |
Member: 1359163 Status: Offline Thanks Meter: 37 | THIS FIRST MODEL LUMIA 800 [QUOTE=konaku;9245470]Hi brothers I have two pieces of nokia lumia 800 to unlock in first one program shows Lumia 800/800C Detected log : ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0014D9D4 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:10:17 and unlock phone ================================================== ==== ================================================== ==== After Update via microsoft ZUNE, still LOCKED!!!! I repair boot , unlock it , update with ZUNE and phone its still locked !!??! any solution ? |
