Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 05-19-2011, 13:41   #1 (permalink)
gulka's Avatar
Member: 276322
ATF Lightning after update, and activate the dead
Hi support.
You can recover from this state?
In Device Manager, is defined as:
Dual RS232-HS
USB Serial Converter A
USB Serial Converter B
Software can not determine its
Old 05-19-2011, 14:17   #2 (permalink)
gulka's Avatar
Member: 276322
Last log entry
13:14:54 : AdvanceBox Turbo Flasher Found
13:14:54 : Driver Version : 00020814
13:14:54 : Library Version : 00030204
13:14:54 : Initialize Device....
13:14:55 : Init TRY : 1
13:14:57 : Box Name : ATF Lightning
13:14:57 : Box Firmware : LogiCore 8.15.10
13:14:57 : Software Version : v7.50
13:14:57 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
13:14:57 :
13:14:57 : ==============================================
13:14:57 :       Please update your Box Firmware
13:14:57 :
13:14:57 : * Follow these Instructions
13:14:57 : 1. Disconnect any phones connected to ATF Box
13:14:57 : 2. Go to "Product Support Tab"
13:14:57 : 3. Go to "Box Tools" Section
13:14:57 : 4. Click "Update Firmware" button
13:14:57 :
13:14:57 :
13:14:57 : * Make sure you put ATF Software in Windows
13:14:57 :   FireWall Exclusion List
13:14:57 :
13:14:57 : * Make sure you put ATF Software in your
13:14:57 :   Virus Scanner Exclusion List
13:14:57 :
13:15:02 :
13:15:02 :
13:15:02 : ************ ATF Box EEPROM Updated ************
13:15:02 : Please Restart ATF Software...
13:15:02 :
13:15:02 : Install NEW ATF Box Drivers if needed...
13:15:30 : No ATF Box Found
13:15:30 :
13:16:00 : No ATF Box Found
13:16:00 :
13:19:24 : AdvanceBox Turbo Flasher Found
13:19:24 : Driver Version : 00020814
13:19:24 : Library Version : 00030204
13:19:24 : Initialize Device....
13:19:24 : Init TRY : 1
13:19:26 : Box Name : ATF Lightning
13:19:26 : Box Firmware : LogiCore 8.15.10
13:19:26 : Software Version : v7.50
13:19:26 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
13:19:26 :
13:19:26 : ==============================================
13:19:26 :       Please update your Box Firmware
13:19:26 :
13:19:26 : * Follow these Instructions
13:19:26 : 1. Disconnect any phones connected to ATF Box
13:19:26 : 2. Go to "Product Support Tab"
13:19:26 : 3. Go to "Box Tools" Section
13:19:26 : 4. Click "Update Firmware" button
13:19:26 :
13:19:26 :
13:19:26 : * Make sure you put ATF Software in Windows
13:19:26 :   FireWall Exclusion List
13:19:26 :
13:19:26 : * Make sure you put ATF Software in your
13:19:26 :   Virus Scanner Exclusion List
13:19:26 :
13:19:26 : INIT : OK
13:19:26 :
13:19:26 : VBATT OFF...
13:19:30 : VBATT ON
13:19:30 : Setting VBATT Done!...
13:21:52 : AdvanceBox Turbo Flasher Found
13:21:52 : Driver Version : 00020814
13:21:52 : Library Version : 00030204
13:21:52 : Initialize Device....
13:21:52 : Init TRY : 1
13:21:54 : Box Name : ATF Lightning
13:21:54 : Box Firmware : LogiCore 8.15.10
13:21:54 : Software Version : v7.50
13:21:54 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
13:21:54 :
13:21:54 : ==============================================
13:21:54 :       Please update your Box Firmware
13:21:54 :
13:21:54 : * Follow these Instructions
13:21:54 : 1. Disconnect any phones connected to ATF Box
13:21:54 : 2. Go to "Product Support Tab"
13:21:54 : 3. Go to "Box Tools" Section
13:21:54 : 4. Click "Update Firmware" button
13:21:54 :
13:21:54 :
13:21:54 : * Make sure you put ATF Software in Windows
13:21:54 :   FireWall Exclusion List
13:21:54 :
13:21:54 : * Make sure you put ATF Software in your
13:21:54 :   Virus Scanner Exclusion List
13:21:54 :
13:21:54 : INIT : OK
13:21:54 :
13:25:06 : AdvanceBox Turbo Flasher Found
13:25:06 : Driver Version : 00020814
13:25:06 : Library Version : 00030204
13:25:06 : Initialize Device....
13:25:06 : Init TRY : 1
13:25:08 : Box Name : ATF Lightning
13:25:08 : Box Firmware : LogiCore 9.02.10
13:25:08 : Software Version : v7.50
13:25:08 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
13:25:08 : BOX Status :  NOT ACTIVATED
13:25:08 :
13:25:08 : INIT : OK
13:25:09 :
13:25:09 : AdvanceBox Turbo Flasher Found
13:25:09 : Driver Version : 00020814
13:25:09 : Library Version : 00030204
13:25:09 : Initialize Device....
13:25:09 : Init TRY : 1
13:25:11 : Box Name : ATF Lightning
13:25:11 : Box Firmware : LogiCore 9.02.10
13:25:11 : Software Version : v7.50
13:25:11 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
13:25:11 : BOX Status :  NOT ACTIVATED
13:25:11 :
13:25:11 : INIT : OK
13:25:11 :
13:27:50 : AdvanceBox Turbo Flasher Found
13:27:50 : Driver Version : 00020814
13:27:50 : Library Version : 00030204
13:27:50 : Initialize Device....
13:27:51 : Init TRY : 1
13:27:53 : Box Name : ATF Lightning
13:27:53 : Box Firmware : LogiCore 9.02.10
13:27:53 : Software Version : v7.50
13:27:53 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
13:27:53 : BOX Status :  NOT ACTIVATED
13:27:53 :
13:27:53 : INIT : OK
13:27:53 :
13:27:53 : VBATT OFF...
13:27:56 : VBATT ON
13:27:57 : Setting VBATT Done!...
13:27:57 :
13:27:57 :
13:27:57 :  ///////// /// /// ///////  ///////   /////////
13:27:57 :    ///    /// /// ///   // ///  /// ///  ///
13:27:57 :   ///    /// /// ///////  ///////  ///  ///
13:27:57 :  ///    /// /// ///  /// ///  /// ///  ///
13:27:57 : ///     /////  ///  /// ///////   //////
13:27:57 :
13:27:57 :      =======================================
13:27:57 :     ///   /// /// ///////// ///////   //////
13:27:57 :    ///// /// ///    ///    ///   // ///  ///
13:27:57 :   /// ///// ///    ///    ///////  ///  ///
13:27:57 :  ///  //// ///    ///    ///  /// ///  ///
13:27:57 : ///   /// ///    ///    ///  ///  //////
13:27:57 :
13:38:23 : VBATT OFF...
13:38:27 : VBATT ON
13:38:28 : Setting VBATT Done!...
13:38:30 : VBATT OFF...
13:38:34 : VBATT ON
13:38:34 : Setting VBATT Done!...
13:38:36 : VBATT OFF...
13:38:40 : VBATT ON
13:38:45 : Setting VBATT Done!...
13:38:46 : BootFlashModeDCT5Ex Failed
13:39:44 : AdvanceBox Turbo Flasher Found
13:39:44 : Driver Version : 00020814
13:39:44 : Library Version : 00030204
13:39:44 : Initialize Device....
13:39:44 : Init TRY : 1
13:39:46 : Box Name : ATF Lightning
13:39:46 : Box Firmware : LogiCore 9.02.10
13:39:46 : Software Version : v7.50
13:39:46 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
13:39:46 : BOX Status :  NOT ACTIVATED
13:39:46 :
13:39:46 : INIT : OK
13:39:46 :
13:39:46 : VBATT OFF...
13:39:50 : VBATT ON
13:39:50 : Setting VBATT Done!...
13:39:50 :
13:39:50 :
13:39:50 :  ///////// /// /// ///////  ///////   /////////
13:39:50 :    ///    /// /// ///   // ///  /// ///  ///
13:39:50 :   ///    /// /// ///////  ///////  ///  ///
13:39:50 :  ///    /// /// ///  /// ///  /// ///  ///
13:39:50 : ///     /////  ///  /// ///////   //////
13:39:50 :
13:39:50 :      =======================================
13:39:50 :     ///   /// /// ///////// ///////   //////
13:39:50 :    ///// /// ///    ///    ///   // ///  ///
13:39:50 :   /// ///// ///    ///    ///////  ///  ///
13:39:50 :  ///  //// ///    ///    ///  /// ///  ///
13:39:50 : ///   /// ///    ///    ///  ///  //////
13:39:50 :
13:41:08 : AdvanceBox Turbo Flasher Found
13:41:08 : Driver Version : 00020814
13:41:08 : Library Version : 00030204
13:41:08 : Initialize Device....
13:41:09 : Init TRY : 1
13:41:10 : Box Name : ATF Lightning
13:41:10 : Box Firmware : LogiCore 9.02.10
13:41:10 : Software Version : v7.50
13:41:10 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
13:41:10 : BOX Status :  NOT ACTIVATED
13:41:10 :
13:41:11 : INIT : OK
13:41:11 :
13:41:52 : AdvanceBox Turbo Flasher Found
13:41:52 : Driver Version : 00020814
13:41:52 : Library Version : 00030204
13:41:52 : Initialize Device....
13:41:53 : Init TRY : 1
13:41:54 : Box Name : ATF Lightning
13:41:54 : Box Firmware : LogiCore 9.02.10
13:41:54 : Software Version : v7.50
13:41:54 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
13:41:54 : BOX Status : ACTIVATED
14:17:59 : AdvanceBox Turbo Flasher Found
14:17:59 : Driver Version : 00020814
14:17:59 : Library Version : 00030204
14:17:59 : Initialize Device....
14:17:59 : Init TRY : 1
14:18:00 : Box Name : =?b?(uYE-u>KIc
14:18:00 : Box Firmware : aLi<
3
?IA0?I?
14:18:00 : Software Version : v7.50
14:18:00 : AdvanceBox SN : 04FC1CE13AC05FFC2631A802
14:18:00 :
14:18:00 : ==============================================
14:18:00 :       ATF Box is not in USB 2.0 Mode
14:18:00 :
14:18:00 : * Go to "Product Support" tab and click the
14:18:00 : * "Restore Box" Button to fix the Box Firmware
14:18:00 :
14:18:00 : ** If Problem is Not Solved...
14:18:00 : 1. Make Sure you are NOT using USB HUBS
14:18:00 : 2. Make Sure your USB port is USB 2.0
14:18:00 : 3. Make Sure you are using the latest Drivers
14:18:00 :
14:18:00 : *** If Problem is STILL Not Solved
14:18:00 : 1. Use a THICKER USB Cable
14:18:00 : 2. Connect ATF Directly to the Root USB Port
14:18:00 : 3. Uninstall Drivers, Reboot PC, Reinstall
14:18:00 :
14:18:00 : **** If you are still Stuck...
14:18:00 : 1. Search your entire PC for "ftdibus.sys
14:18:00 : 2. Delete all "ftdibus.sys" files you find
14:18:00 : 3. Reboot PC...
14:18:00 : 4. Disconnect ATF Box and all Boxes from PC
14:18:00 : 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drivers.bat
14:18:00 : 6. ReInstall ATF Software
14:18:00 : 7. Connect ATF Box Only to your USB Port
14:18:00 : 8. Install the Correct Drivers
14:18:00 :
14:18:01 : Init TRY : 2
14:18:02 : Box Name : ATF Lightning
14:18:02 : Box Firmware : LogiCore 9.02.10
14:18:02 : Software Version : v7.50
14:18:02 : AdvanceBox SN : 92256799AFFF5B56F6FB308A
14:18:02 : BOX Status : ACTIVATED
14:18:04 :
14:18:04 : ************ ATF Box EEPROM Updated ************
14:18:04 : Please Restart ATF Software...
14:18:04 :
Old 05-19-2011, 14:33   #3 (permalink)
gulka's Avatar
Member: 276322
Problem solved AdvanceBox Drivers problem,Plz Help
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.23812 seconds with 11 queries
