08-23-2015, 10:03 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: philippines
Member: 603921 Status: Offline Thanks Meter: 71 | atf lightning cant read sd card <<< SOLVED >>> tried other sd reader still the same, im using 4in1 v2 adaptor. cant use my sdc unbricker ERROR: Failed to Reset Micro SD Card... Total Elapsed Time 00:00:12 ERROR: WRITE FAILED! tia |
08-23-2015, 10:23 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Use only Good and not Fake SD CARD like Samsung, San Disk, itc... ORIGINAL and size must be same or more high of size of Sdc file...if Sdc file require 32GB Sd Card you must need 32gb of ORIGINAL Sd Card...with Fake Cina card you have problem....Adapter work 100% if isn't been damaged. BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
08-23-2015, 14:00 | #3 (permalink) |
Member: 603921 Status: Offline Thanks Meter: 71 | yes im using class 10 sd cards, 16 32 and 64 but the same results over n over,, is it maybe theres a problem with my atf lightning? what possibly the problem? hardware maybe. coz updated restored few times but still the same. |
08-23-2015, 20:21 | #5 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
08-24-2015, 05:35 | #6 (permalink) |
Member: 603921 Status: Offline Thanks Meter: 71 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.40 AdvanceBox SN : ################# Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== ERROR: Failed to Initialize SDC Module ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== ERROR: Failed to Reset Micro SD Card... Total Elapsed Time 00:00:13 ERROR: WRITE FAILED! ================================================== ==== Loading ATF SDC File... (Please Wait) ================================================== ==== SDC File Version: v11.30 SDC File Author: CDD4066FBBCF8B108C0A6EB0 Date Created: 06/05/2014 (dd/mm/yyyy) Description: Samsung SM-N9005 UNBRICK 4.4.2 ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== ERROR: Failed to Reset Micro SD Card... Total Elapsed Time 00:00:13 ERROR: WRITE FAILED! ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== ERROR: Failed to Reset Micro SD Card... Total Elapsed Time 00:00:13 ERROR: WRITE FAILED! used all voltage same result |
08-24-2015, 05:44 | #8 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
If you think socket is OK then SD card defected Br -- srinibas | |
08-24-2015, 08:45 | #9 (permalink) |
Member: 603921 Status: Offline Thanks Meter: 71 | fully working sd card,, the sd cards have been used in some deadboot phones using sdc in other atf from my friend,, the problem is its mine aint workin,, the adpter continusly blink after clicking yes in this log SDC File Version: v11.30 SDC File Author: CDD4066FBBCF8B108C0A6EB0 Date Created: 06/05/2014 (dd/mm/yyyy) Description: Samsung SM-N9005 UNBRICK 4.4.2 then failed |
08-24-2015, 09:33 | #10 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi, this Sdc file above require 16/32GB of Sd card what size are using? Try with other NEW not used Sd Card if you are sure that adapter is fully working, i doubt becouse isn't Atf sw that not see this card but reader or damaged Sd Card... Not import if are used for other phone one sd card can damage. Already try with other Sdc file for test If loock here there are 4/5 Sdc file and if not use right size Sd Card can get error: http://www.4shared.com/folder/w9n0Nu...sortsMode=NAME Last edited by allumts; 08-24-2015 at 09:41. |
08-24-2015, 10:34 | #13 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Sorry but if you have just open this Atf Light and cut cable ask to X-Shadow at this point...if you not had touched nothing can be i can help you with other test but at this point not want any responsability for mistake....sorry P.D. anyway from above logs not was seem that Atf had problem, not understan why have open first of other easy test primary... BR allumts |
