07-18-2016, 00:53 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Atf lightning shows dual rs232-hs in device manager I RESTARTED MY PC AND PLUG IN MY ATF LIGHTNING BOX PC NOW SHOWS DRIVERS INSTALLATION AGAIN I WAS SUPPRISE TO SEE ANOTHER DRIVER INSTALLATIONS THEN I CHECKED DEVICE MANAGER IT WAS USB SERIAL CONVERTER A USB SERIAL CONVERTER B SO I WAS CONFUSED SEEING THAT DRIVERS . NOW I UNSTALLED BOTH DRIVERS AND RESTART MY PC NO IF I PLUG-IN BOX IT WILL SHOW DUAL RS232-HS DEVICE SEE PICS BELOW FOR BETTER EXPLAIN PLZ WHAT IS WRONG.. |
07-18-2016, 01:14 | #2 (permalink) |
Member: 2025428 Status: Offline Thanks Meter: 445 | THANKS TO SRINIBAS I FOLLOWED HIS TUTORIALS WHICH IS VERRY SIMPLE ... 1. Download this: http://www.ftdichip.com/Resources/Ut...s/MProg3.5.zip 2. Disconnect all boxes from your PC 3. Connect only ATF Box 4. Run MPROG 3.5 5. Write this eeprom file to the Box: C:\AdvanceBox Turbo Flasher\Driver\new abox turboflasher.ept 6. Close MPROG and Disconnect ATF from USB Port 7. Reconnect ATF and install drivers... Done NOW MY BOX IS BACK AND WORKING AGAIN.. |
