Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-01-2015, 12:22   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
ATF Lumia 640 XL DS WinPhone 8.1 Full Flashing + EMMC TP !!! - FIRST IN THE WORLD
ATF Lumia 640 XL DS WinPhone 8.1 Full Flashing!
Also check out other Lumia WinPhone 8.0/8.1/10 Phones Flashed by ATF:
Microsoft Lumia 430 DS - Fully Tested
Microsoft Lumia 435 DS - Fully Tested
Nokia Lumia 520 - Fully Tested
Nokia Lumia 530 - Fully Tested
Nokia Lumia 620 - Fully Tested
Nokia Lumia 625 - Fully Tested
Nokia Lumia 630 - Fully Tested
Nokia Lumia 638 - Fully Tested
Nokia Lumia 720 - Fully Tested
Nokia Lumia 735 DS - Fully Tested
Nokia Lumia 810 - Fully Tested
Nokia Lumia 820 - Fully Tested
Nokia Lumia 822 - Fully Tested
Microsoft Lumia 830 - Fully Tested
Nokia Lumia 920 - Fully Tested
Nokia Lumia 925 - Fully Tested
Nokia Lumia 928 - Fully Tested
Microsoft Lumia 929 - Fully Tested
Microsoft Lumia 930 - Fully Tested
Nokia Lumia 1020 - Fully Tested
Nokia Lumia 1320 - Fully Tested
Nokia Lumia 1520 - Fully Tested
You Can Download Flash Files Here:
http://forum.gsmhosting.com/vbb/f609...added-1660094/
Microsoft Lumia 640 XL DS WinPhone 8.1 Flashed Successfully with ATF
Here are the Screenshot:
Here is the Flashing Logs:
 Windows Phone 8/8.1 Flashing Started
Loading Flash Files Please Wait...
Windows Phone 8/8.1 Lumia Flasher
If the Phone is ALIVE
 1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
 1. Connect Phone to the USB Port
 2. Press and Hold the VOLUME DOWN and POWER Buttons
 3. Wait until the Phone Vibrates Shortly...
 4. Stop Pressing the Buttons...
If the Phone is DEAD BOOT
 2. Install Correct Drivers:
 "Nokia Emergency Connectivity"
Basic Phone Information
SW Version : 02166.00000.15103.05001
IMEI Plain : 357158063859909
IMEI2 Plain : 357158063859917
Phone Type : RM-1067
HW Version : 2400
Product Code : 059X1G0
Basic Product Code: 059W080
Module Code : 0206150
PSN Number : 7C555CBAU
Operator Name : 000-PH
Phone Version : BuildDate : Mar 4 2015 , BuildType : Release , HelloString : NCSd for WP8 , Version : 5.0
Manufacturer ID : RM-1067_1009
Security Mode : Restricted
Extended Phone Information
Public ID : E3407008726D21EE8C1A851FB6BF3AEEDF9031A7
Wireless Lan 0 ID: 80:C5:E6:0A:ED:DC
Wireless Lan 1 ID: 80:C5:E6:0A:ED:DD
Wireless Lan 2 ID: 80:C5:E6:0A:ED:DE
Wireless Lan 3 ID: 80:C5:E6:0A:ED:DF
Bluetooth ID : 80:C5:E6:0A:B8:52
Simlock Information
SIMLOCK STATE : Not Locked
Booting Flash Mode Initiated...
Please wait upto 15 Seconds for HW Reset
Boot Flash Mode Successful...
Buffers Flushed OK...
Phone Info Query Start...
Blocks Returned: 0x09 Blocks
Block ID 0x01 : 00241000
Block ID 0x1F : 01
Block ID 0x02 : 00240000
Block ID 0x03 : 00E90000
Block ID 0x05 : Nokia.MSM8226.P6199.2.0
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 01000F0000
Block ID 0x20 : 010000000100000004
Checking SD Card Size...
Card Size: 0x00000000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
Secure FFU Mode :
Query Flash App Information...
Flash App Information: 020225023C00
UEFI App: FLASH APP
Flash App Protocol Version: 2.37
Flash App Implementation Version: 2.60
Query ROOT KEY HASH...
ROOT_KEY_HASH: 682455784C6A1730952BF78A8EB41A4FAA98B4B4828BA1F74C71E21E921C3960
Query PUBLIC ID...
PUBLIC_ID: E3407008726D21EE8C1A851FB6BF3AEEDF9031A7
Query eMMC Info...
EMMC Manufacture ID: TOSHIBA
EMMC Product SN : A629D1A6
EMMC_SIZE: 8 Gigabytes
Query Battery Charge Status...
BATTERY CHARGE_STATUS: 63%
Sending Image Signatures...
Image Signatures Accepted!
Erasing Data Partition...
Data Partition Erased Successfully
Preparing Buffers for DATA LOOP...
Allocating System RAM OK!
Start Sending DATA BLOCKS...
Finished Sending all DATA BLOCKS!
Exiting FLASH Mode via REBOOT...
Exit FLASH Mode Successful!
Flashing Done!
Total Flashing Time : 00:05:19
Here is our Test Phone...
FLASHING The Phone...
BOOT Repair Tests will follow
X-Shadow
The Following 7 Users Say Thank You to Advance-Box For This Useful Post:
Old 05-01-2015, 12:45   #2 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
why you not use ATF Big box? What is difference between Big and Nitro? huh?
Old 05-01-2015, 16:21   #3 (permalink)
naizersky's Avatar
Member: 540512
Thanks Meter: 340
ATF Big box is good and add more hardware...
Old 06-01-2015, 17:43   #4 (permalink)
Member: 2402477
Hi
I have 640 xl rm-1067 dead boot when I want flash with atf log sey use emmc or JTAG but I can't find emm file, please help me for recover boot
Old 06-01-2015, 20:10   #5 (permalink)
Member: 651945
Originally Posted by behza_rad View Post
Hi
Show logs... otherwise we don't have a clue.
Old 06-02-2015, 06:24   #6 (permalink)
Member: 2402477
640 XL dead boot
ok sir show u log few moment leter......tnx
Old 06-02-2015, 15:56   #7 (permalink)
Member: 2402477
640 XL deadboot
Windows Phone 8/8.1/10 Lumia Flasher
Recovery Handle Found! - (WinUSB)
ERROR: NOT Supported for USB BOOT Repair!
Use eMMC or JTAG Method to Repair Boot...
ERROR: Flashing Failed!
please help
Old 06-02-2015, 16:07   #8 (permalink)
Member: 2402477
when i connect my phone in the device manger show me QHSUSB__BULK...it's normaly?
Old 06-02-2015, 16:16   #9 (permalink)
Member: 651945
@behza_rad
For now, 640 XL is not supported for USB boot repair.
I will open my phone now to check if we can do repair via eMMC direct connection (soldering required).
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 06-02-2015, 16:29   #10 (permalink)
Member: 2402477
Tnx I'll be witing tnx again
Old 06-02-2015, 16:34   #11 (permalink)
Member: 651945
Also, you might want to check if battery is just empty....
New Lumia 8.1 like 640, 640XL, 430, 435 etc... They all get detected as QHSUSB__BULK or Nokia Emergency Driver when battery is removed or DEAD.
SO possible,, your battery is just totally empty.
If I connect my 640 XL to the usb port without the battery attached, I also get QHSUSB__BULK...
B.R.
Old 06-02-2015, 16:39   #12 (permalink)
Member: 2402477
Men posble my battery is empty,if my battery full show me what?
Old 06-02-2015, 16:45   #13 (permalink)
Member: 651945
Then we do boot repair via eMMC>..
I have opened my phone and there are eMMC pinouts
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 06-02-2015, 16:50   #14 (permalink)
Member: 2402477
Tnx I'll be witing for file sir tnx
Old 06-02-2015, 18:17   #15 (permalink)
Member: 2402477
How many progress eMMC?
The Following User Says Thank You to behza_rad For This Useful Post:
Page generated in 0.30566 seconds with 9 queries
