06-03-2015, 05:09 | #16 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 11010030303847453000A629D1A622C1 CSD : D05E00320F5903FFFFFFFFEF924000D3 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 008GE0 Product Rev : 0.0 Product SN : A629D1A6 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 800 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 11010030303847453000A629D1A622C1.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ What RM-XXXX is your phone? So I can make the BOOT REPAIR PACKAGE via EMMC NOW. Last edited by Advance-Box; 06-03-2015 at 06:23. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
06-03-2015, 06:44 | #21 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Here you go: LUMIA_640_XL_RM-1067_BIG_BOOT_02166.00000.15103.05001.mmc This came from my phone... so I am 100% sure it will work for repairing the BOOT |
06-03-2015, 10:23 | #25 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Check here: http://forum.gsmhosting.com/vbb/10399850-post2.html When your eMMC is detected, just click WRITE and select that .mmc file. Everything will be automatic |
