05-01-2015, 12:22 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | ATF Lumia 640 XL DS WinPhone 8.1 Full Flashing + EMMC TP !!! - FIRST IN THE WORLD Also check out other Lumia WinPhone 8.0/8.1/10 Phones Flashed by ATF: Microsoft Lumia 430 DS - Fully Tested Microsoft Lumia 435 DS - Fully Tested Nokia Lumia 520 - Fully Tested Nokia Lumia 530 - Fully Tested Nokia Lumia 620 - Fully Tested Nokia Lumia 625 - Fully Tested Nokia Lumia 630 - Fully Tested Nokia Lumia 638 - Fully Tested Nokia Lumia 720 - Fully Tested Nokia Lumia 735 DS - Fully Tested Nokia Lumia 810 - Fully Tested Nokia Lumia 820 - Fully Tested Nokia Lumia 822 - Fully Tested Microsoft Lumia 830 - Fully Tested Nokia Lumia 920 - Fully Tested Nokia Lumia 925 - Fully Tested Nokia Lumia 928 - Fully Tested Microsoft Lumia 929 - Fully Tested Microsoft Lumia 930 - Fully Tested Nokia Lumia 1020 - Fully Tested Nokia Lumia 1320 - Fully Tested Nokia Lumia 1520 - Fully Tested You Can Download Flash Files Here: http://forum.gsmhosting.com/vbb/f609...added-1660094/ Microsoft Lumia 640 XL DS WinPhone 8.1 Flashed Successfully with ATF Here are the Screenshot: Here is the Flashing Logs: Code: Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ====================================================== Windows Phone 8/8.1 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ====================================================== ================================================ Basic Phone Information ================================================ SW Version : 02166.00000.15103.05001 IMEI Plain : 357158063859909 IMEI2 Plain : 357158063859917 Phone Type : RM-1067 HW Version : 2400 Product Code : 059X1G0 Basic Product Code: 059W080 Module Code : 0206150 PSN Number : 7C555CBAU Operator Name : 000-PH Phone Version : BuildDate : Mar 4 2015 , BuildType : Release , HelloString : NCSd for WP8 , Version : 5.0 Manufacturer ID : RM-1067_1009 Security Mode : Restricted ================================================ Extended Phone Information ================================================ Public ID : E3407008726D21EE8C1A851FB6BF3AEEDF9031A7 Wireless Lan 0 ID: 80:C5:E6:0A:ED:DC Wireless Lan 1 ID: 80:C5:E6:0A:ED:DD Wireless Lan 2 ID: 80:C5:E6:0A:ED:DE Wireless Lan 3 ID: 80:C5:E6:0A:ED:DF Bluetooth ID : 80:C5:E6:0A:B8:52 ================================================ Simlock Information ================================================ SIMLOCK STATE : Not Locked Booting Flash Mode Initiated... Please wait upto 15 Seconds for HW Reset Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x09 Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8226.P6199.2.0 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01000F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020225023C00 UEFI App: FLASH APP Flash App Protocol Version: 2.37 Flash App Implementation Version: 2.60 Query ROOT KEY HASH... ROOT_KEY_HASH: 682455784C6A1730952BF78A8EB41A4FAA98B4B4828BA1F74C71E21E921C3960 Query PUBLIC ID... PUBLIC_ID: E3407008726D21EE8C1A851FB6BF3AEEDF9031A7 Query eMMC Info... EMMC Manufacture ID: TOSHIBA EMMC Product SN : A629D1A6 EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 63% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:05:19 FLASHING The Phone... BOOT Repair Tests will follow BR X-Shadow |
The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
06-02-2015, 15:56 | #7 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2402477 Status: Offline Thanks Meter: 1 | 640 XL deadboot Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== Recovery Handle Found! - (WinUSB) ERROR: NOT Supported for USB BOOT Repair! Use eMMC or JTAG Method to Repair Boot... ERROR: Flashing Failed! ==================================== please help |
06-02-2015, 16:16 | #9 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @behza_rad For now, 640 XL is not supported for USB boot repair. I will open my phone now to check if we can do repair via eMMC direct connection (soldering required). |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
06-02-2015, 16:34 | #11 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Also, you might want to check if battery is just empty.... New Lumia 8.1 like 640, 640XL, 430, 435 etc... They all get detected as QHSUSB__BULK or Nokia Emergency Driver when battery is removed or DEAD. SO possible,, your battery is just totally empty. If I connect my 640 XL to the usb port without the battery attached, I also get QHSUSB__BULK... B.R. |
