Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 06-03-2015, 15:22   #31 (permalink)
Member: 1320284
Thanks Meter: 16
so good.pl help me to find right flash files of atf
Old 06-03-2015, 15:41   #32 (permalink)
Member: 1320284
Thanks Meter: 16
I have one ATF box which was not updated yet.what shoud l do upgrade it. w
Old 06-03-2015, 16:01   #33 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Originally Posted by behza_rad View Post
ERROR: EMMC WAS NOT Detected! (CMD1)
Check your Test Point Soldering!
CMD1 Reply: 0x5E5E5E5E
Only you can solve this problem
Solder it properly like what I did.
I already showed you pinout...
I already made repair file from my phone dump.
Nothing else for me to do, all on you now
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 06-03-2015, 16:48   #34 (permalink)
Member: 2402477
tnx abute all of to do sir but,my problem to solider,how many solider can use for this?
how many model,maby this my be diffrent
Old 06-03-2015, 17:01   #35 (permalink)
Member: 651945
We have exaclty the same phone RM-1067
Old 06-03-2015, 17:17   #36 (permalink)
Member: 2402477
no sir my men solder type?
Old 06-03-2015, 17:22   #37 (permalink)
Member: 2402477
thats it
Old 06-03-2015, 18:35   #38 (permalink)
Member: 651945
Man look at pinouts.... You don't need such adapter.
Just connect direct to ATF box.
Pinout already very very very very clear!
Old 06-04-2015, 20:14   #39 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Had understan that you are the first time doing one Jtag or Direct EMMC in this case....
You must need of an enameled copper wire of 0.10mm, one RJ45 cable, (8 pin), not to loock the colours in the cable but loock diagram posted from X-Shadow, use numbers....
with soldering iron a fine tip connect pinout in phone and other side directly in the 4/5 wires of the RJ45 cable...connect in the box...scan eMMc button then press "write" and select the Dump uploaded by X-Shadow...waith that process finish and enjoy....
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 06-05-2015, 15:36   #40 (permalink)
Member: 67450
Thanks Meter: 57
Need lumia 1020 rm-875 .mmc file
Old 06-08-2015, 09:37   #41 (permalink)
Member: 2402477
640 XL dead boot
allumts
i do everything true but how many time long after push "WRITE"?
Old 06-08-2015, 10:25   #42 (permalink)
Member: 651945
When you click "WRITE" it will ask you for FILE.
Select File .mmc and it will show you pinout etc... then when you click OK, it will write to your eMMC>
Old 06-14-2015, 12:56   #43 (permalink)
Member: 2402477
hi sir,i do any thing with my phone but cant detect by software,i think my phone cant ripar
with eMMC,i have any why to repair dead boot ?
thx for all
Old 06-15-2015, 10:39   #44 (permalink)
allumts's Avatar
Member: 1564612
@behza_rad,
the only thing that can help you is to start to have knowledge of what a JTAG, what an EMMC direct, as is welding itc... from the first moment, (have just wrote), have understand you not have any knowledge about these procedure...Not is one Offense all are been newbie...but not start with one nokia of this....use device damaged for starting and understand how is easy and work Atf Box about these repair...
@X-Shadow have explained you in 10 or more mode all tip but you answer if have need of use Adapter V2....sorry but start with good welding manuality ant later you'll see that all rest is very very easy....
Regards
allumts
Old 07-06-2015, 12:29   #45 (permalink)
Cheater -Don't Deal with him-
Member: 488833
Thanks Meter: 52
Hello i have a Lumia 640 RM-1073 that need to repair via EMMC or Jtag can you please create the needed files for it.
Thanks
Page generated in 0.26673 seconds with 8 queries
