Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #47 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Apr 2011 Location: "Official Reseller" Age: 52
Member: 1564612 Status: Offline Thanks Meter: 9,984 ![]() | Quote:
![]() Why not read Sticky thread or use Search Button? Not say if id "Dead", or what's the problem, can only repair, if is Dead Boot" by EMMC TP, and for Flash file just read Here: Nokia Product Code Listing for NaviFirm+ Download - (Nokia 730, 735, 830 Added) HERE FULL LIST of "Big Boot" for repair via EMMC: <<<<<< All Lumia/Android Dead Boot Repair Files -[Added Lumia 540, 1320, 925] >>>>>> How can see if not are Lazy for sure Find all you answer to you question, instead of post in this mode, we all see and listen very good. BR allumts | |
![]() | #49 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2002 Location: Egypt
Member: 17675 Status: Offline Thanks Meter: 18 | i have lumia 640 rm-1067 dead boot i try to repair it and all done after boot done i flash phone all ok but phone always restart what is solution thanks for help |
![]() | #50 (permalink) | |
Member: 17675 Status: Offline Thanks Meter: 18 | here is the log file Quote:
![]() | #51 (permalink) | |
Junior Member Join Date: Jan 2016
Member: 2519291 Status: Offline Thanks Meter: 1 | Quote:
![]() my lumia 640 xl is in infinite boot loop i think that is microsoft's problem and : what is RDC file? i think that is the main problem ! Code: RDC Status: Not Active | |
![]() | #54 (permalink) | |
Junior Member ![]() ![]() Join Date: Dec 2013
Member: 2089529 Status: Offline Thanks Meter: 2 | Quote:
problem with activate my box | |
![]() | #55 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: May 2008
Member: 783356 Status: Offline Sonork: 71047 Thanks Meter: 10 | HI! Bro, I got a lumia 430 DS stop flasing on 37%. i retried and got red screen. I remove battery and reconnected it, only I got is "QHSUSB__BULK..." Please help me to solve the problem via jtag or EMMC TP |
![]() | #56 (permalink) |
Member: 783356 Status: Offline Sonork: 71047 Thanks Meter: 10 | HI! Bro, I got a lumia 430 DS RM-1099 stop flashing on 37%. i retried and got red screen. I remove battery and reconnected it, only I got is "QHSUSB__BULK..." Please help me to solve the problem via jtag or EMMC TP |
![]() | #57 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2008
Member: 835074 Status: Offline Thanks Meter: 28 | my phone is alive.after open blue lcd..hard reset not working. [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Recovery Handle Found! - (Qualcomm) PBL Emergency Download Detected Start Sending Firehose Loader... Firehose Loader Sent! Executing Firehose Loader... Start Processing Firehose Payload... MSG_SIGNATURE Sent.... ERROR: MSG_SIGNATURE Reply Failure! Make Sure you Select the Correct RM-XXX Before Flashing Your Phones! ERROR: Flashing Failed! |
![]() | #58 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2596267 Status: Offline Thanks Meter: 0 | Rm-1062 emmc bin problem Hello all! I read today Microsoft Lumia 640 XL (rm-1062) emmc using of course ATF Nitro box. I got it to 100 % and was going to check what was inside that .bin file. There were tons of partitions. The most interesting partition was named DATA, (User data), but windows did not recognize that partition when trying to mount it via advancebox software. I am not sure, but should that data partition be ntfs? Any way...I just cant find any user data from that .bin file. I found just some os pictures and some txt files so I assume my soldering was good enough. I have done chip off for same kind of phone and then everything showed just fine. Atf box is pretty new and I have not change any setups. Now I would like to know that is there some critical setups that I should change or is there something else wrong? |
![]() | #59 (permalink) | |
Member: 2596267 Status: Offline Thanks Meter: 0 | There were bitlocker enabled Quote:
