08-20-2016, 11:37 | #61 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mobile Phone Repairing
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | error: eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010038474E443352010B28BC04423D ERROR: EMMC_SET_RELATIVE_ADDRESS FAILED (CMD3) Check your Test Point Soldering! |
08-20-2016, 11:42 | #62 (permalink) |
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010038474E443352010B28BC04423D CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 8GND3R Product Rev : 0.1 Product SN : 0B28BC04 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010038474E443352010B28BC04423D.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
08-31-2016, 01:21 | #63 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2601049 Status: Offline Thanks Meter: 0 | i am trying to repair dead boot lumia 640 rm 1072 please help team Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Recovery Handle Found! - (Qualcomm) PBL Emergency Download Detected Start Sending Firehose Loader... Firehose Loader Sent! Executing Firehose Loader... Start Processing Firehose Payload... MSG_SIGNATURE Sent.... ERROR: MSG_SIGNATURE Reply Failure! Make Sure you Select the Correct RM-XXX Before Flashing Your Phones! ERROR: Flashing Failed! |
01-02-2017, 15:07 | #65 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1253983 Status: Offline Thanks Meter: 1 | need help to repair boot lumia 640 xl ds rm-1067, log repair: 16:50:17 : ================================================== ==== 16:50:17 : Loading ATF MMC File... (Please Wait) 16:50:17 : ================================================== ==== 16:50:17 : 16:50:17 : MMC File Version: v12.31 16:50:17 : MMC File Author: 8A4EB1A9D53D31F59F02EF8F 16:50:17 : Date Created: 03/06/2015 (dd/mm/yyyy) 16:50:17 : Description: Lumia 640 XL - RM-1067 - BOOT= 02166.00000.15103.05001 16:50:17 : 16:51:25 : Current Partition: Partition 1 16:51:25 : Start Writing Blocks... 16:51:25 : Writing Blocks Done! 16:51:25 : Current Partition: Partition 2 16:51:25 : Start Writing Blocks... 16:51:25 : Writing Blocks Done! 16:51:25 : Current Partition: Partition 3 16:51:25 : Start Writing Blocks... 16:51:25 : Writing Blocks Done! 16:51:25 : Current Partition: Partition 4 16:51:25 : Start Writing Blocks... 16:51:26 : Writing Blocks Done! 16:51:26 : Current Partition: Partition 5 16:51:26 : Start Writing Blocks... 16:51:26 : Writing Blocks Done! 16:51:26 : Current Partition: Partition 6 16:51:26 : Start Writing Blocks... 16:51:29 : Writing Blocks Done! 16:51:29 : Current Partition: Partition 7 16:51:29 : Start Writing Blocks... 16:51:30 : Writing Blocks Done! 16:51:30 : Current Partition: Partition 8 16:51:30 : Start Writing Blocks... 16:51:31 : Writing Blocks Done! 16:51:31 : Current Partition: Partition 9 16:51:31 : Start Writing Blocks... 16:51:32 : Writing Blocks Done! 16:51:32 : Current Partition: Partition 10 16:51:32 : Start Writing Blocks... 16:52:00 : Writing Blocks Done! 16:52:00 : Current Partition: Partition 11 16:52:00 : Start Writing Blocks... 16:52:14 : Writing Blocks Done! 16:52:15 : Current Partition: Partition 12 16:52:15 : Start Writing Blocks... 16:53:12 : Writing Blocks Done! 16:53:12 : 16:53:12 : 16:53:12 : Perform Firmware Update via USB Cable. 16:53:12 : 16:53:12 : 16:53:12 : Total Elapsed Time 00:02:54 16:53:12 : Write Success! after repair boot i flash it via usb but cannot flast, here is log flash: ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Recovery Handle Found! - (WinUSB) PBL Emergency Download Detected Start Sending Firehose Loader... Firehose Loader Sent! Executing Firehose Loader... Start Processing Firehose Payload... MSG_SIGNATURE Sent.... help me please, thanks! |
01-03-2017, 03:08 | #66 (permalink) | |
Freak Poster Join Date: Jul 2013
Member: 1987130 Status: Offline Thanks Meter: 6 | Quote:
01-03-2017, 03:09 | #67 (permalink) | |
02-01-2017, 18:58 | #69 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
pls confirm! wbr | |
03-14-2017, 20:26 | #70 (permalink) | |
Junior Member Join Date: Jan 2014 Location: Ghana
Member: 2109110 Status: Offline Thanks Meter: 0 | I Need Help for Lumia RM-1067 Boot Repair!!! Quote:
Hi, I found this thread and have been trying to follow it to repair my dead boot Lumia 640 XL DS. However, it appears that the TP image is no longer on the page. Even though I have tried to get it from google, I only ended up getting a very blurry one, which appears to be a cached version of the real image. I did the soldering somehow but when I try, the ATF software tells me to "check the green wire connection". Please I need your help to get the TP so I can do the soldering well. | |
