09-24-2012, 11:46 | #227 (permalink) |
No Life Poster Join Date: Nov 2009 Location: sri lankan
Member: 1167260 Status: Offline Sonork: 100.1604772 Thanks Meter: 165 | posible now unlock without flash? i seen now improved unlock stock rom thats mean no need flash with generic firmware? i have lumia 800 orange uk posible now unlock without flash generic firmware ? becasue i have problem flashing i was try many way to flash direct usb drivers get all mode but not start flash so its beetr if possible unlock without flash..... |
The Following User Says Thank You to fazargsm For This Useful Post: |
09-24-2012, 12:16 | #228 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
09-24-2012, 15:47 | #233 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! ERROR: Connection Refused 0x06 Check your Test Point Soldering! I am facing this problem on lumia 800 and its TOSHIBA Flash Chip and check again and again connections are ok and phone get dead during unlock process please help me what to do now .... while a unlock lumia 800 successfully |
09-24-2012, 16:14 | #234 (permalink) |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Before it was giving error like this 09:18:59 : ================================================== ==== 09:18:59 : ================================================== ==== 09:18:59 : Lumia Test Point Connection Module 09:18:59 : ================================================== ==== 09:18:59 : ================================================== ==== 09:18:59 : 09:18:59 : 1. DO NOT USE THE PHONE"S BATTERY 09:18:59 : 2. Connect the Soldered TP Connections to ATF Box 09:18:59 : 3. Disconnect the USB Cable and Wait until the 09:18:59 : the ATF Software will tell you to Connect the USB. 09:18:59 : 09:19:04 : 09:19:04 : Interface Reset OK! 09:19:04 : Reading Platform Information... 09:19:04 : Selecting Active Handle... 09:19:04 : Select Handle OK! 09:19:04 : Sending Ping... 09:19:04 : Ping Reply OK! 09:19:04 : 09:19:04 : 09:19:04 : Storage Device Information 09:19:04 : Manufacturer ID: 03 09:19:04 : Application ID : FFFF 09:19:04 : Product Name : ÿÿÿÿÿÿ 09:19:04 : Product Rev : FF 09:19:04 : Product SN : FFFFFFFF 09:19:04 : 09:19:04 : Protection Information 09:19:04 : Write Protect A: OFF 09:19:04 : Write Protect B: OFF 09:19:04 : 09:19:05 : 09:19:05 : Dumping AMSS FAT16 Region 09:19:05 : Please wait for 2-4 Mintues... |
09-24-2012, 17:38 | #236 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Only the Resistor on the RED/YELLOW TP area can be "United"... Other Resistors CANNOT be "United". If resistor comes off, it is ok as it is not needed by the other TP area | |
09-26-2012, 04:56 | #239 (permalink) | |
Br - srinibas | |
