03-09-2013, 19:14 | #85 (permalink) |
Freak Poster Join Date: Mar 2011 Age: 33
Member: 1545783 Status: Offline Sonork: 100.1614080 Thanks Meter: 56 | Lumia 710 Unlock Error by atf plz tell me solution beacuase i have used origional tp cable og GPG 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: Phone WAS NOT Detected! Check the GREEN WIRE Connection |
03-09-2013, 20:51 | #86 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, You no need Test Point unlock for Lumia 710. It can be unlocked via USB cable as well. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
03-10-2013, 14:10 | #87 (permalink) |
Member: 1545783 Status: Offline Sonork: 100.1614080 Thanks Meter: 56 | Lumia 710 Unlock Done by atf Unlock via USB Lumia 710 by ATF FOUND: Qualcomm MMC Storage USB Device Mounted Drive Letter: 1 MBR Entry[0]: Flags : 128 Type : 0x4D - DBL Starting Sector: 0x00000001 Sector Count : 0x000003E8 MBR Entry[1]: Flags : 0 Type : 0x46 - OSBL Starting Sector: 0x000003E9 Sector Count : 0x00000BB8 MBR Entry[2]: Flags : 0 Type : 0x0C - AMSS_ADSP Starting Sector: 0x00000FA1 Sector Count : 0x000493E0 EBR Entry[0]: Flags : 0 Type : 0xEF - PMM Starting Sector: 0x0004A386 Sector Count : 0x00000080 EBR Entry[1]: Flags : 0 Type : 0x58 - ENC_STORAGE_A Starting Sector: 0x0004A406 Sector Count : 0x00001800 EBR Entry[2]: Flags : 0 Type : 0x4A - ENC_STORAGE_B Starting Sector: 0x00060000 Sector Count : 0x00001800 EBR Entry[3]: Flags : 0 Type : 0x4B - ENC_STORAGE_C Starting Sector: 0x00061800 Sector Count : 0x00001800 EBR Entry[4]: Flags : 0 Type : 0x48 - WP_OS Starting Sector: 0x00080000 Sector Count : 0x00E10FFF Dumping AMSS FAT16 Region Please wait for 15-20 Seconds... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... SP Unlock Done! PIN:00000000 PUK: 0000000000 Total Elapsed Time 00:00:33 THANX ATF TEAM |
The Following User Says Thank You to ateebgulzar For This Useful Post: |
03-10-2013, 16:21 | #89 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1897604 Status: Offline Thanks Meter: 0 | Good evening the box to make the process of unlocking the bootloader lumia 900 has to be whether or ATF? or any other right?? one more question, once soldiers cables connects to the USB? wing box for the process or another? from already thank you very much |
03-10-2013, 19:26 | #90 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Lumia 900 boot-loader repair via ATF Box, Test Points (RJ45 cable) and a USB cable. BR | |
