Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 11-30-2012, 08:00   #76 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,040
@Alva
I think your PC does not have enough FREE memory.
Try to REBOOT then run ATF only to check.
I am also downloading the exact same flash file as yours now,
but my Lumia 820 is RM-824.
Old 11-30-2012, 08:07   #77 (permalink)
Member: 748456
Thanks Meter: 19
OK, I wll try another PC, but what about the drivers?
Old 11-30-2012, 08:07   #78 (permalink)
Member: 651945
@Alva
It takes 1GB RAM initially to load the flash file into memory... ((
Old 11-30-2012, 08:10   #79 (permalink)
Member: 651945
@Alva
If you FULL Install 9.20, you should get the Latest WinUSB Drivers here:
C:\AdvanceBox Turbo Flasher\Driver\Lumia Phone Drivers\
and the latest Nokia Connectivity Drivers here:
You need to install both of them because it is REQUIRED.
Older WinUSB and older Nokia Connectivity may NOT WORK properly.
Remember to use the 9.21 in the other PC as well.
There are 3 kinds of drivers for the Win8 phones... each time the phone changes is MODE,
then windows will install a new driver again.
If you installed WinUSB and Nokia Connectivity, you will have no problems.
B.R.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 11-30-2012, 11:45   #80 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 341
nokia 5130 is power on come nokia logo &, after come contact service pls give me any solution for this problem.
nokia 5130 sl data corrupted solution?
Old 11-30-2012, 12:08   #81 (permalink)
gerovgsm's Avatar
Member: 52180
Thanks Meter: 27
Originally Posted by Advance-Box View Post
@Alva
I have the same problem.My RAM is 2Gbs.How mach RAM is needed.
Old 11-30-2012, 13:32   #82 (permalink)
haroon454's Avatar
Member: 653398
Sonork: 100.1619594
Thanks Meter: 560
good update............................
Old 11-30-2012, 13:54   #83 (permalink)
Member: 1087145
Thanks Meter: 120
Good Update ATF Team.
thanks
Old 11-30-2012, 14:50   #84 (permalink)
Member: 328688
Thanks Meter: 967
i hve 2 gb ram it working fine
Old 11-30-2012, 16:18   #85 (permalink)
Member: 60039
Thanks Meter: 12
Great Update ATF Team.
Old 11-30-2012, 19:23   #86 (permalink)
Member: 772283
Thanks Meter: 4
thanks ATF TEAM wery good update ................
Old 12-01-2012, 01:20   #87 (permalink)
Ducdung76's Avatar
Member: 731321
Thanks Meter: 52
thanks
Old 12-01-2012, 03:49   #88 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,842
thanks
advence box team
Old 12-01-2012, 04:05   #89 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 1,834
Great & Hot Update Feel The Power
Old 12-01-2012, 04:06   #90 (permalink)
Member: 1093471
Thanks Meter: 25
yeah....... very good update thanks ATF team
Page generated in 0.34431 seconds with 7 queries
