atf with mprog i need help i was try to repair my ...... box wit MProg 2.3 while i forget to disconect atf box but now its say usb serial converter what to do? thanx |
C:\AdvanceBox Turbo Flasher\Driver\MProg 3.5 Release\MProg.exe + C:\AdvanceBox Turbo Flasher\Driver\new abox turboflasher.ept = OK |
i tryed but say no box found |
1 Attachment(s) when i scan say 1 device |
@GSM SKILS No it does not say "BOX NOT FOUND" because MPROG is not LOOKING for a BOX. Anyway, 1. Disconnect all other GSM BOXES FROM your PC. 2. Disconnect ATF Box as well. 3. Make sure you disconnect all GSM Boxes from your PC. 4. Repeat STEP 1-2-3 until all GSM Boxes are disconnected from your PC. 5. Run this: C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. Connect ATF Box and go to Device Manager... 7. Update USB to Serial Converter A and B with latest FTDI Drivers from here: http://www.ftdichip.com/Drivers/CDM/CDM20812.zip 8. After you Updated your USB to Serial Converter Drivers... Follow what I posted in POST #2 9. Now after you reprogram your ATF box, disconnect it from the USB Port and Connect it back after 5 seconds... 10. Use Drivers here: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\ |
4 Attachment(s) what i,m wrong not done! |
@GSM SKILS Please follow post #5, it is very very very clear already... Just follow it, that is all you need to do. |
1 Attachment(s) may be my computer problem when i connect it automatic install driver |
@GSM SKILS This is second time I will tell you... Just read and follow post #5 Here is your clue: 7. Update USB to Serial Converter A and B with latest FTDI Drivers from here: http://www.ftdichip.com/Drivers/CDM/CDM20812.zip 8. After you Updated your USB to Serial Converter Drivers... If you do not follow what I say,, then it is up to you... |
oh ...thank you very much ..this is very usefull thread and help my atf box |
This drivers won't work with New atf box....... USB\Vid_0613&Pid_2010&Rev_0700&MI_00 USB\Vid_0613&Pid_2010&MI_00 |
Now work fine! in 1. step I installed the mprog 2.8. With this I deleted the ATF FTDI and in 2. with the Mprog 3.5, I writed the FTDI. Now work well the Box ;) |
sir link is deafd plz post new link Quote:
Atf box i need this file ( new abox turboflasher.ept ):confused: |
