Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 04-02-2011, 09:26   #1 (permalink)
GSM SKILS's Avatar
Member: 368697
Thanks Meter: 215
atf with mprog
i need help
i was try to repair my ...... box wit MProg 2.3 while i forget to disconect atf box
but now its say usb serial converter
what to do?
thanx
Old 04-02-2011, 09:34   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,017
C:\AdvanceBox Turbo Flasher\Driver\MProg 3.5 Release\MProg.exe
C:\AdvanceBox Turbo Flasher\Driver\new abox turboflasher.ept
OK
Old 04-02-2011, 09:41   #3 (permalink)
GSM SKILS's Avatar
Member: 368697
Thanks Meter: 215
i tryed but say no box found
Old 04-02-2011, 09:44   #4 (permalink)
GSM SKILS's Avatar
Member: 368697
Thanks Meter: 215
when i scan say 1 device
Old 04-02-2011, 09:48   #5 (permalink)
Member: 651945
@GSM SKILS
No it does not say "BOX NOT FOUND" because MPROG is not LOOKING for a BOX.
Anyway,
1. Disconnect all other GSM BOXES FROM your PC.
2. Disconnect ATF Box as well.
3. Make sure you disconnect all GSM Boxes from your PC.
4. Repeat STEP 1-2-3 until all GSM Boxes are disconnected from your PC.
5. Run this:
C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat
6. Connect ATF Box and go to Device Manager...
7. Update USB to Serial Converter A and B with latest FTDI Drivers from here:
http://www.ftdichip.com/Drivers/CDM/CDM20812.zip
8. After you Updated your USB to Serial Converter Drivers...
Follow what I posted in POST #2
9. Now after you reprogram your ATF box, disconnect it from the USB Port and Connect
it back after 5 seconds...
10. Use Drivers here:
C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\
Old 04-02-2011, 10:16   #6 (permalink)
GSM SKILS's Avatar
Member: 368697
Thanks Meter: 215
what i,m wrong not done!
Old 04-02-2011, 10:30   #7 (permalink)
Member: 651945
@GSM SKILS
Please follow post #5, it is very very very clear already...
Just follow it, that is all you need to do.
Old 04-02-2011, 10:38   #8 (permalink)
GSM SKILS's Avatar
Member: 368697
Thanks Meter: 215
may be my computer problem
when i connect it automatic install driver
Old 04-02-2011, 10:44   #9 (permalink)
Member: 651945
@GSM SKILS
This is second time I will tell you... Just read and follow post #5
Here is your clue:
If you do not follow what I say,, then it is up to you...
Old 04-02-2011, 14:49   #10 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 322
After removing driver.rename folder from where windows automatically install driver.rename or delete all ftdi drivers from c:window\system32 folder.
Old 05-03-2012, 16:28   #11 (permalink)
willydewi's Avatar
Member: 331835
Thanks Meter: 64
oh ...thank you very much ..this is very usefull thread and help my atf box
Old 10-04-2013, 13:46   #12 (permalink)
Rocco's Avatar
Member: 60809
Thanks Meter: 27
This drivers won't work with New atf box.......
USB\Vid_0613&Pid_2010&Rev_0700&MI_00
USB\Vid_0613&Pid_2010&MI_00
Old 10-04-2013, 15:48   #13 (permalink)
Rocco's Avatar
Member: 60809
Thanks Meter: 27
Now work fine!
in 1. step I installed the mprog 2.8. With this I deleted the ATF FTDI
and in 2. with the Mprog 3.5, I writed the FTDI.
Now work well the Box
Old 10-04-2013, 16:03   #14 (permalink)
Member: 1001290
Thanks Meter: 78
sir link is deafd plz post new link
Originally Posted by Advance-Box View Post
@GSM SKILS
Here is your clue:
Old 12-28-2014, 10:49   #15 (permalink)
Member: 1849147
Thanks Meter: 9
Atf box
i need this file ( new abox turboflasher.ept )
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 16:48
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 01:44
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 18:04
Page generated in 0.42697 seconds with 9 queries
