03-03-2011, 08:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | ATF Network in Action: How Nokiyo Guys wants you to kill phones... So now I want to expose some VERY important Information to everyone because Nokia is playing some tricks on us again... Nokia stopped using PA_SL3 simlocks since 3 months ago. All new firmwares are now using PA_SIMLOC30 and it is NOT COMPATIBLE with the current phones in the Market. This is because PA_SIMLOC30 uses a different PM 120... So your old PA_SL3 PM 120 cannot work with these new firmwares. If you flash your PA_SL3 phone with PA_SIMLOC30 firmware, then the PA_SIMLOC30 firmware cannot verify your PM 120 and it will give you Simlock problems.... For Demonstration Purposes, I will kill one of my X3-00 RM-540 by flashing it with the Latest Nokeeeya Firmware: Ok, here is Step 1: Check Phone and Show Simlock Versions: So here we a perfectly working X3-00 RM-540 with Firmware version 4.11. A quick check of the simlock version (vis BUSCHECK) shows us the phone is using PA_SL3 simlocks... So now we try to flash the phone with firmware 8.54... If you are using ATF 7.00, then it will ask you if you want to check if this firmware is compatible with your Phone. Click YES and it will show you this ERROR Message... This is because firmware 8.54 is using PA_SIMLOC30 simlocks... And it is not compatible with your phone :O) A note to the other teams who still don't have a clue about this... Tell your programmer that this is the part where he should USB Sniff and copy-paste how we check the firmwares so that your end users will not kill phones using your software. Since I promised you guys that I will kill this phone, let us click "NO" instead of yes :O).... Yey!!! Now it is flashing!!! Crap!!,, NOW the Simlocks are Damaged!!! Why ? Why ? Why ? Because Nokeeyah is now using PA_SIMLOC30 which it is impossible to Brute Force and is not compatible with your old PM 120 from PA_SL3. So the lesson from this story is: 1. PA_SL3 Brute Force is OBSOLETE,, Nokeeyah is now using PA_SIMLOC30 2. Never flash your phone with other tools that do not check Firmware Compatibility. 3. Buy ATF Credits to fix your phone if you damaged it using other tools hehehehhe.... Also, DO NOT WORRY... The SIMLOCKS ARE NOT DAMAGED!!! It is just NOT COMPATIBLE with the Firmware... Watch out for PART 2 of this story where I will fix the phone using The ATF Network Best Regards, X-Shadow Last edited by Advance-Box; 03-03-2011 at 09:05. |
The Following 66 Users Say Thank You to Advance-Box For This Useful Post: |
03-03-2011, 09:01 | #2 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | PART II How to Downgrade PA_SIMLOC30 phones back to a Compatible Firmware PA_SL3 Killing phones is easy, especially because our special friends from Nokeeyah make it very easy for us to make mistakes even when using their original Phoenix, Nokia Care, NSU etc. Service Softwares. In the beginning, they did not want us to DOWNGRADE the Firmware of our Phones... and now, they don't even want us to UPGRADE the Firmware of our phones to the Latest versions!!! Why Nokeeyah? Anyway, here is how we can fix a phone from Nokiyos dirty tricks.... STEP 1: As always, BACKUP RPL Certificates STEP 2: Same as STEP 1 STEP 3: Same as STEP 2 STEP 4: Read Out Full PM 0-400 You can see here, PM 120 is still OK and it is not damaged at all!!! STEP 5: ENABLE SL3 phone FULL ERASE option STEP 6: FULL ERASE PHONE (Click SCAN then select the FLASH CHIP, then click ERASE) STEP 7: Now FULL Flash the Phone with Firmware 4.11 (Or any PA_SL3 Firmware compatible with your Phone) SKIP BACKUP RPL and SKIP BACKUP SIMLOCKS... STEP 8: Write BACK RPL STEP 9: Authorize Phone via the ATF Network (Because phone is NEW HASH) STEP 10: Stand Alone SX-4 and write the FULL PM BACKUP from STEP 4 Now Phone is 100% OK Again and Downgraded Back to version 4.11 :O) Code: MCU: V 04.11 09-12-09 RM-540 (c) Nokia IMEI: 359367031341159 Model : Nokia X3-00 Product Serial Number: 0 Default SN Type : 0 MCU SW Version : V 04.11 09-12-09 RM-540 (c) Nokia T BT MCM Version : 1673-46034 PPM Version : V 04.11 09-12-09 RM-540 (c) Nokia RFIC Version : 0831 DSP Version : ICPR91_09w44_RC LCD Version : SEIKO Content Pack Version : Content: ctv ph V 04.11 09-12-09 RM-540 (c) Nokia AHNE Version : 41 Retu Version : 40 Tahvo Version : 00 ******** Reading SimLock ******** Unable to read SP Data.. ******** Reading SimLock ******** Unable to read SP Data.. SIMLOCK_TEST : FAILED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR030C20C607 DCC Ver: 003003 Status : OK ================================================ SX4 Custom Keys Stand Alone Edition ================================================ *** WARNING: Current Super Dongle Keys are Invalid! *** Attempting to write New Super Dongle Keys... MCU: V 04.11 09-12-09 RM-540 (c) Nokia IMEI: 359367031341159 Model : Nokia X3-00 Product Serial Number: 0 Default SN Type : 0 MCU SW Version : V 04.11 09-12-09 RM-540 (c) Nokia T BT MCM Version : 1673-46034 PPM Version : V 04.11 09-12-09 RM-540 (c) Nokia RFIC Version : 0831 DSP Version : ICPR91_09w44_RC LCD Version : SEIKO Content Pack Version : Content: ctv ph V 04.11 09-12-09 RM-540 (c) Nokia AHNE Version : 41 Retu Version : 40 Tahvo Version : 00 ******** Reading SimLock ******** Unable to read SP Data.. ******** Reading SimLock ******** Unable to read SP Data.. SIMLOCK_TEST : FAILED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR030C20C607 DCC Ver: 003003 Status : OK =================================================== Super Dongle RPL Stand Alone Edition =================================================== Generating Super Dongle RPL... (This may take upto 30 Seconds on New RAPIDO HASH) Sending Superdongle RPL... OK: Super Dongle RPL accepted Successfully done. ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\359367031341159\359367031341159_0-400_32403.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 116 - Ok Field : 1 Sub : 1 Byte(s): 4 - Ok Field : 1 Sub : 2 Byte(s): 88 - Ok Field : 1 Sub : 4 Byte(s): 112 - Ok Field : 1 Sub : 5 Byte(s): 4 - Ok Field : 1 Sub : 6 Byte(s): 88 - Ok Field : 1 Sub : 8 Byte(s): 112 - Ok Field : 1 Sub : 13 Byte(s): 88 - Ok Field : 1 Sub : 15 Byte(s): 4 - Ok Field : 1 Sub : 16 Byte(s): 88 - Ok Field : 1 Sub : 18 Byte(s): 88 - Ok Field : 1 Sub : 20 Byte(s): 88 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 25 Byte(s): 16 - Ok Field : 1 Sub : 29 Byte(s): 8 - Ok Field : 2 Sub : 0 Byte(s): 768 - Ok Field : 4 Sub : 1 Byte(s): 800 - Ok Field : 4 Sub : 3 Byte(s): 12 - Ok Field : 4 Sub : 4 Byte(s): 8 - Ok Field : 4 Sub : 5 Byte(s): 8 - Ok Field : 4 Sub : 6 Byte(s): 8 - Ok Field : 4 Sub : 9 Byte(s): 8 - Ok Field : 4 Sub : 18 Byte(s): 80 - Ok Field : 4 Sub : 19 Byte(s): 4 - Ok Field : 4 Sub : 28 Byte(s): 4 - Ok Field : 8 Sub : 0 Byte(s): 4 - Ok Field : 8 Sub : 3 Byte(s): 128 - Ok Field : 8 Sub : 4 Byte(s): 128 - Ok Field : 8 Sub : 8 Byte(s): 8 - Ok Field : 11 Sub : 0 Byte(s): 4 - Ok Field : 11 Sub : 1 Byte(s): 4 - Ok Field : 11 Sub : 2 Byte(s): 4 - Ok Field : 11 Sub : 3 Byte(s): 4 - Ok Field : 11 Sub : 4 Byte(s): 244 - Ok Field : 12 Sub : 0 Byte(s): 104 - Ok Field : 13 Sub : 0 Byte(s): 4 - Ok Field : 13 Sub : 1 Byte(s): 4 - Ok Field : 13 Sub : 2 Byte(s): 4 - Ok Field : 13 Sub : 3 Byte(s): 4 - Ok Field : 13 Sub : 4 Byte(s): 4 - Ok Field : 13 Sub : 5 Byte(s): 4 - Ok Field : 13 Sub : 6 Byte(s): 4 - Ok Field : 13 Sub : 7 Byte(s): 4 - Ok Field : 13 Sub : 8 Byte(s): 4 - Ok Field : 13 Sub : 9 Byte(s): 4 - Ok Field : 13 Sub : 10 Byte(s): 4 - Ok Field : 13 Sub : 11 Byte(s): 48 - Ok Field : 13 Sub : 12 Byte(s): 4 - Ok Field : 13 Sub : 13 Byte(s): 4 - Ok Field : 13 Sub : 14 Byte(s): 4 - Ok Field : 13 Sub : 15 Byte(s): 888 - Ok Field : 13 Sub : 16 Byte(s): 4 - Ok Field : 13 Sub : 17 Byte(s): 4 - Ok Field : 13 Sub : 18 Byte(s): 4 - Ok Field : 13 Sub : 19 Byte(s): 8 - Ok Field : 13 Sub : 20 Byte(s): 4 - Ok Field : 13 Sub : 21 Byte(s): 4 - Ok Field : 13 Sub : 22 Byte(s): 4 - Ok Field : 13 Sub : 23 Byte(s): 4 - Ok Field : 13 Sub : 24 Byte(s): 4 - Ok Field : 13 Sub : 25 Byte(s): 4 - Ok Field : 13 Sub : 26 Byte(s): 4 - Ok Field : 13 Sub : 27 Byte(s): 4 - Ok Field : 13 Sub : 28 Byte(s): 4 - Ok Field : 13 Sub : 29 Byte(s): 4 - Ok Field : 13 Sub : 30 Byte(s): 4 - Ok Field : 13 Sub : 31 Byte(s): 4 - Ok Field : 13 Sub : 32 Byte(s): 4 - Ok Field : 13 Sub : 33 Byte(s): 4 - Ok Field : 13 Sub : 34 Byte(s): 4 - Ok Field : 13 Sub : 35 Byte(s): 4 - Ok Field : 13 Sub : 36 Byte(s): 4 - Ok Field : 13 Sub : 37 Byte(s): 4 - Ok Field : 13 Sub : 38 Byte(s): 4 - Ok Field : 13 Sub : 39 Byte(s): 4 - Ok Field : 13 Sub : 40 Byte(s): 4 - Ok Field : 13 Sub : 41 Byte(s): 4 - Ok Field : 13 Sub : 42 Byte(s): 4 - Ok Field : 13 Sub : 43 Byte(s): 4 - Ok Field : 13 Sub : 44 Byte(s): 4 - Ok Field : 13 Sub : 45 Byte(s): 4 - Ok Field : 13 Sub : 46 Byte(s): 4 - Ok Field : 13 Sub : 47 Byte(s): 4 - Ok Field : 13 Sub : 48 Byte(s): 4 - Ok Field : 13 Sub : 49 Byte(s): 4 - Ok Field : 13 Sub : 50 Byte(s): 4 - Ok Field : 13 Sub : 51 Byte(s): 4 - Ok Field : 13 Sub : 52 Byte(s): 4 - Ok Field : 13 Sub : 53 Byte(s): 4 - Ok Field : 13 Sub : 54 Byte(s): 4 - Ok Field : 13 Sub : 55 Byte(s): 4 - Ok Field : 13 Sub : 56 Byte(s): 4 - Ok Field : 13 Sub : 57 Byte(s): 4 - Ok Field : 13 Sub : 58 Byte(s): 4 - Ok Field : 13 Sub : 59 Byte(s): 4 - Ok Field : 13 Sub : 60 Byte(s): 4 - Ok Field : 13 Sub : 61 Byte(s): 4 - Ok Field : 13 Sub : 62 Byte(s): 4 - Ok Field : 13 Sub : 63 Byte(s): 4 - Ok Field : 13 Sub : 64 Byte(s): 4 - Ok Field : 13 Sub : 65 Byte(s): 4 - Ok Field : 13 Sub : 66 Byte(s): 4 - Ok Field : 13 Sub : 67 Byte(s): 4 - Ok Field : 13 Sub : 68 Byte(s): 4 - Ok Field : 13 Sub : 69 Byte(s): 4 - Ok Field : 13 Sub : 70 Byte(s): 4 - Ok Field : 13 Sub : 71 Byte(s): 4 - Ok Field : 13 Sub : 72 Byte(s): 4 - Ok Field : 13 Sub : 73 Byte(s): 4 - Ok Field : 13 Sub : 74 Byte(s): 4 - Ok Field : 13 Sub : 75 Byte(s): 4 - Ok Field : 13 Sub : 76 Byte(s): 4 - Ok Field : 13 Sub : 77 Byte(s): 4 - Ok Field : 13 Sub : 78 Byte(s): 4 - Ok Field : 13 Sub : 79 Byte(s): 4 - Ok Field : 13 Sub : 80 Byte(s): 4 - Ok Field : 13 Sub : 81 Byte(s): 4 - Ok Field : 13 Sub : 82 Byte(s): 4 - Ok Field : 13 Sub : 83 Byte(s): 4 - Ok Field : 13 Sub : 84 Byte(s): 4 - Ok Field : 13 Sub : 85 Byte(s): 4 - Ok Field : 13 Sub : 86 Byte(s): 4 - Ok Field : 13 Sub : 87 Byte(s): 4 - Ok Field : 13 Sub : 88 Byte(s): 4 - Ok Field : 13 Sub : 89 Byte(s): 4 - Ok Field : 13 Sub : 90 Byte(s): 4 - Ok Field : 13 Sub : 91 Byte(s): 4 - Ok Field : 13 Sub : 92 Byte(s): 4 - Ok Field : 13 Sub : 93 Byte(s): 4 - Ok Field : 13 Sub : 94 Byte(s): 4 - Ok Field : 13 Sub : 95 Byte(s): 4 - Ok Field : 13 Sub : 96 Byte(s): 4 - Ok Field : 13 Sub : 97 Byte(s): 4 - Ok Field : 13 Sub : 98 Byte(s): 4 - Ok Field : 13 Sub : 99 Byte(s): 4 - Ok Field : 13 Sub : 100 Byte(s): 4 - Ok Field : 13 Sub : 101 Byte(s): 4 - Ok Field : 13 Sub : 102 Byte(s): 4 - Ok Field : 13 Sub : 103 Byte(s): 4 - Ok Field : 13 Sub : 104 Byte(s): 4 - Ok Field : 13 Sub : 105 Byte(s): 4 - Ok Field : 13 Sub : 106 Byte(s): 4 - Ok Field : 13 Sub : 107 Byte(s): 4 - Ok Field : 13 Sub : 108 Byte(s): 4 - Ok Field : 13 Sub : 109 Byte(s): 4 - Ok Field : 13 Sub : 110 Byte(s): 4 - Ok Field : 13 Sub : 111 Byte(s): 4 - Ok Field : 13 Sub : 112 Byte(s): 4 - Ok Field : 13 Sub : 113 Byte(s): 4 - Ok Field : 13 Sub : 114 Byte(s): 4 - Ok Field : 13 Sub : 115 Byte(s): 4 - Ok Field : 13 Sub : 116 Byte(s): 4 - Ok Field : 13 Sub : 117 Byte(s): 4 - Ok Field : 13 Sub : 118 Byte(s): 4 - Ok Field : 13 Sub : 119 Byte(s): 4 - Ok Field : 13 Sub : 120 Byte(s): 4 - Ok Field : 13 Sub : 121 Byte(s): 4 - Ok Field : 13 Sub : 122 Byte(s): 4 - Ok Field : 13 Sub : 123 Byte(s): 8 - Ok Field : 13 Sub : 124 Byte(s): 4 - Ok Field : 13 Sub : 125 Byte(s): 4 - Ok Field : 13 Sub : 126 Byte(s): 4 - Ok Field : 13 Sub : 127 Byte(s): 4 - Ok Field : 13 Sub : 128 Byte(s): 4 - Ok Field : 13 Sub : 129 Byte(s): 4 - Ok Field : 13 Sub : 130 Byte(s): 4 - Ok Field : 13 Sub : 131 Byte(s): 4 - Ok Field : 13 Sub : 132 Byte(s): 4 - Ok Field : 13 Sub : 133 Byte(s): 4 - Ok Field : 13 Sub : 134 Byte(s): 4 - Ok Field : 13 Sub : 135 Byte(s): 4 - Ok Field : 13 Sub : 136 Byte(s): 4 - Ok Field : 13 Sub : 137 Byte(s): 4 - Ok Field : 13 Sub : 138 Byte(s): 4 - Ok Field : 13 Sub : 139 Byte(s): 4 - Ok Field : 13 Sub : 140 Byte(s): 4 - Ok Field : 13 Sub : 141 Byte(s): 4 - Ok Field : 13 Sub : 142 Byte(s): 4 - Ok Field : 13 Sub : 143 Byte(s): 4 - Ok Field : 13 Sub : 144 Byte(s): 4 - Ok Field : 13 Sub : 145 Byte(s): 8 - Ok Field : 13 Sub : 146 Byte(s): 4 - Ok Field : 13 Sub : 147 Byte(s): 4 - Ok Field : 13 Sub : 148 Byte(s): 4 - Ok Field : 13 Sub : 149 Byte(s): 4 - Ok Field : 13 Sub : 150 Byte(s): 4 - Ok Field : 13 Sub : 151 Byte(s): 4 - Ok Field : 13 Sub : 152 Byte(s): 4 - Ok Field : 13 Sub : 153 Byte(s): 4 - Ok Field : 13 Sub : 154 Byte(s): 4 - Ok Field : 13 Sub : 155 Byte(s): 4 - Ok Field : 13 Sub : 156 Byte(s): 4 - Ok Field : 13 Sub : 157 Byte(s): 4 - Ok Field : 13 Sub : 158 Byte(s): 4 - Ok Field : 13 Sub : 159 Byte(s): 4 - Ok Field : 13 Sub : 160 Byte(s): 4 - Ok Field : 13 Sub : 161 Byte(s): 4 - Ok Field : 13 Sub : 162 Byte(s): 4 - Ok Field : 13 Sub : 163 Byte(s): 4 - Ok Field : 13 Sub : 164 Byte(s): 4 - Ok Field : 13 Sub : 165 Byte(s): 4 - Ok Field : 13 Sub : 166 Byte(s): 4 - Ok Field : 31 Sub : 4 Byte(s): 16 - Ok Field : 42 Sub : 0 Byte(s): 4 - Ok Field : 42 Sub : 1 Byte(s): 12 - Ok Field : 42 Sub : 2 Byte(s): 36 - Ok Field : 42 Sub : 3 Byte(s): 36 - Ok Field : 42 Sub : 4 Byte(s): 36 - Ok Field : 42 Sub : 5 Byte(s): 36 - Ok Field : 42 Sub : 6 Byte(s): 36 - Ok Field : 42 Sub : 7 Byte(s): 40 - Ok Field : 42 Sub : 8 Byte(s): 40 - Ok Field : 42 Sub : 9 Byte(s): 40 - Ok Field : 42 Sub : 10 Byte(s): 40 - Ok Field : 42 Sub : 11 Byte(s): 40 - Ok Field : 42 Sub : 12 Byte(s): 40 - Ok Field : 42 Sub : 13 Byte(s): 40 - Ok Field : 42 Sub : 14 Byte(s): 40 - Ok Field : 42 Sub : 15 Byte(s): 40 - Ok Field : 42 Sub : 16 Byte(s): 40 - Ok Field : 42 Sub : 17 Byte(s): 40 - Ok Field : 42 Sub : 18 Byte(s): 40 - Ok Field : 42 Sub : 19 Byte(s): 40 - Ok Field : 42 Sub : 20 Byte(s): 40 - Ok Field : 42 Sub : 21 Byte(s): 40 - Ok Field : 42 Sub : 22 Byte(s): 40 - Ok Field : 42 Sub : 23 Byte(s): 40 - Ok Field : 42 Sub : 24 Byte(s): 40 - Ok Field : 42 Sub : 25 Byte(s): 40 - Ok Field : 42 Sub : 26 Byte(s): 40 - Ok Field : 50 Sub : 0 Byte(s): 4 - Ok Field : 54 Sub : 0 Byte(s): 4 - Ok Field : 88 Sub : 0 Byte(s): 36 - Ok Field : 96 Sub : 0 Byte(s): 4 - Ok Field : 107 Sub : 0 Byte(s): 24 - Ok Field : 107 Sub : 1 Byte(s): 92 - Ok Field : 107 Sub : 2 Byte(s): 72 - Ok Field : 107 Sub : 3 Byte(s): 72 - Ok Field : 107 Sub : 25 Byte(s): 136 - Ok Field : 107 Sub : 26 Byte(s): 12 - Ok Field : 116 Sub : 0 Byte(s): 4 - Ok Field : 116 Sub : 1 Byte(s): 12 - Ok Field : 116 Sub : 2 Byte(s): 36 - Ok Field : 116 Sub : 3 Byte(s): 36 - Ok Field : 116 Sub : 4 Byte(s): 36 - Ok Field : 116 Sub : 5 Byte(s): 36 - Ok Field : 116 Sub : 6 Byte(s): 36 - Ok Field : 116 Sub : 7 Byte(s): 40 - Ok Field : 116 Sub : 8 Byte(s): 40 - Ok Field : 116 Sub : 9 Byte(s): 40 - Ok Field : 116 Sub : 10 Byte(s): 40 - Ok Field : 116 Sub : 11 Byte(s): 40 - Ok Field : 116 Sub : 12 Byte(s): 40 - Ok Field : 116 Sub : 13 Byte(s): 40 - Ok Field : 116 Sub : 14 Byte(s): 40 - Ok Field : 116 Sub : 15 Byte(s): 40 - Ok Field : 116 Sub : 16 Byte(s): 40 - Ok Field : 120 Sub : 0 Byte(s): 944 - Ok Field : 120 Sub : 1 Byte(s): 160 - Ok Field : 120 Sub : 2 Byte(s): 132 - Ok Field : 120 Sub : 3 Byte(s): 112 - Ok Field : 193 Sub : 2 Byte(s): 8 - Ok Field : 193 Sub : 3 Byte(s): 32 - Ok Field : 193 Sub : 4 Byte(s): 32 - Ok Field : 193 Sub : 9 Byte(s): 64 - Ok Field : 218 Sub : 0 Byte(s): 4 - Ok Field : 238 Sub : 1 Byte(s): 4 - Ok Field : 301 Sub : 0 Byte(s): 4 - Ok Field : 301 Sub : 1 Byte(s): 12 - Ok Field : 301 Sub : 2 Byte(s): 36 - Ok Field : 301 Sub : 3 Byte(s): 36 - Ok Field : 301 Sub : 4 Byte(s): 36 - Ok Field : 301 Sub : 5 Byte(s): 36 - Ok Field : 301 Sub : 6 Byte(s): 36 - Ok Field : 301 Sub : 7 Byte(s): 40 - Ok Field : 301 Sub : 8 Byte(s): 40 - Ok Field : 301 Sub : 9 Byte(s): 40 - Ok Field : 301 Sub : 10 Byte(s): 40 - Ok Field : 301 Sub : 11 Byte(s): 40 - Ok Field : 301 Sub : 12 Byte(s): 40 - Ok Field : 301 Sub : 13 Byte(s): 40 - Ok Field : 301 Sub : 14 Byte(s): 40 - Ok Field : 301 Sub : 15 Byte(s): 40 - Ok Field : 301 Sub : 16 Byte(s): 40 - Ok Field : 308 Sub : 0 Byte(s): 4 - Failed Field : 308 Sub : 1 Byte(s): 8192 - Failed Field : 308 Sub : 2 Byte(s): 4 - Failed Field : 308 Sub : 3 Byte(s): 4 - Failed Field : 308 Sub : 4 Byte(s): 4 - Failed Field : 308 Sub : 5 Byte(s): 12 - Failed Field : 308 Sub : 6 Byte(s): 4 - Failed Field : 308 Sub : 7 Byte(s): 4 - Failed Field : 308 Sub : 8 Byte(s): 4 - Failed Field : 308 Sub : 9 Byte(s): 40 - Failed Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 4 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 322 Sub : 0 Byte(s): 4 - Ok Field : 334 Sub : 0 Byte(s): 4 - Ok Field : 339 Sub : 0 Byte(s): 512 - Ok Field : 339 Sub : 1 Byte(s): 512 - Ok Field : 341 Sub : 0 Byte(s): 4 - Ok Field : 341 Sub : 3 Byte(s): 4 - Ok Field : 341 Sub : 4 Byte(s): 4416 - Ok Field : 354 Sub : 0 Byte(s): 4 - Ok Field : 355 Sub : 0 Byte(s): 14608 - Ok Field : 355 Sub : 1 Byte(s): 14608 - Ok Field : 356 Sub : 0 Byte(s): 4 - Ok Field : 362 Sub : 0 Byte(s): 4 - Ok Field : 362 Sub : 1 Byte(s): 144 - Ok PM Upload Done!... Done,, new HASHES TOTALLY PWNED !!! Last edited by Advance-Box; 03-03-2011 at 10:32. |
The Following 101 Users Say Thank You to Advance-Box For This Useful Post: |
03-03-2011, 09:10 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: jamshedpur Age: 38
Member: 59185 Status: Offline Sonork: 100.1593175 Thanks Meter: 4,911 | thanks for the great and very important news . this should be sticky for new users so they will wont kill their phone . |
The Following 2 Users Say Thank You to lalitjsraks For This Useful Post: |
03-03-2011, 09:36 | #7 (permalink) | |||
Freak Poster Join Date: Jul 2009 Location: Inside SoftwaŽe
Member: 1084363 Status: Offline Thanks Meter: 109 | very nice message to them ))= Quote:
@X-shadow. what can you say about this.. Quote:
I'm just wondering why the other teams do not appreciate fbus for new phones..but they are working hard to just add our old interface... | |||
The Following User Says Thank You to -=Meltech09=- For This Useful Post: |
03-03-2011, 09:43 | #8 (permalink) |
Junior Member Join Date: Feb 2008 Location: Philippines
Member: 709751 Status: Offline Sonork: none Thanks Meter: 13 | nice info sir.. now a days ATF is a big help in this business specially in NOKIA PRODUCTS.. BR. |
The Following User Says Thank You to mallowrock17 For This Useful Post: |
03-03-2011, 09:48 | #9 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @-=Meltech09=- Well it is obvious that some teams may not be aware... That NEW Protocol is only compatible with 3 kinds of CPUs (FOR USB FLASHING, RAP3Gv30 new loaders does not work for USB)... RAP3Gv40 RAPUYAMA and BROADCOM That is why these teams who still use other people's box (UFS) and cannot design their own boxes, want you to believe that FBUS is no longer usefull. If FBUS is no longer useful, then why do they still support UFS Interface? If FBUS is no longer useful, why cant they make RPL Backup's using USB cable to the following CPUs; RAP3Gv2 - N70, 6630 RAP3Gv3 - 5130c, 7210c, 2690 RAPIDO - N97, C6-00, X6-00, 5233, 5800, E71, E63 etc... And then what? They tell you "Please use UFS Box to backup RPL for these phones..." How are you suppose to do this when UFS Box does not support New Protocol and phones like C6-00, X6-00, 5233, new 5800 etc etc... cannot support OLD Protocol Loaders? Are they totally out of their minds??? And what, they are selling USB Flashing??? USB flashing is 100% free: 1. Cracked Phoenix 2. Nokia Care 3. NSU 4. Ovi Suite 5. Cracked JAF etc.. etc.. So they are telling you... Please do not waste your money on buying FBUS cables... Instead, waste your money in paying for a NON FREE USB Flasher. And really, we should expect that they can make a better USB flasher than Nokia Engineers? Come on... :O) People in gsm are not that stupid anymore... B/R Last edited by Advance-Box; 03-03-2011 at 09:54. |
The Following 46 Users Say Thank You to Advance-Box For This Useful Post: |
03-03-2011, 10:02 | #14 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 748428 Status: Offline Thanks Meter: 33 | Very Nice ....!!! Info I smiled to myself to see the use of this word "How Nokiyo Guys wants you to kill phones ..." |
The Following User Says Thank You to ocha_vista For This Useful Post: |
03-03-2011, 10:29 | #15 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Saudi Arabia/Philippines Age: 47
Member: 10468 Status: Offline Thanks Meter: 121 | Thanks for this very important information... I have a question, how about if we try to flash it with SL_3 FW to PA_SIMLOC30 using Phoenix crack, does this software will also have a pop up window reminding us "Do you want to test flashfiles bla bla"? or it will continue flashing w/o any reminder? and in result simlocks are also damage? |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Tdb4 emulator wanted | Fk2 | Wanted Products | 0 | 06-01-1999 09:45 |
