Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 05-10-2012, 08:42   #1 (permalink)
zakiyyboss's Avatar
Member: 64823
THE ATF network - ALWAYS invalid response !! - (NOW OK)
Here is my info:
Advance Turbo Flasher Found
Driver Version : 00020814
Library Version : 00030204
Box Type : ATF Lightning
Box Firmware : LogiCore 10.3.12
Software Version : v8.70
AdvanceBox SN : 910025A8D1C7C9F1940AC5A0
Box Status : ACTIVATED
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Old 05-10-2012, 09:27   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
What is your problem ? post in detail
ATF Network working ( Just check now )
Br - srinibas ( ATF Team )
Old 05-10-2012, 15:54   #3 (permalink)
frozenice's Avatar
Member: 418852
Sonork: 100:1587670
@zakiyyboss
Actually you get invalid response because you are not activated to ATF network.
even if you can access atf network you can do nothing because
you are not activated.
anyway, what do you need from network?
if you need to Authorize phones you can do so even if you get invalid when login
because auth phones is free and no need to login to atf network..
Frozenice
Old 05-11-2012, 10:00   #4 (permalink)
zakiyyboss's Avatar
Member: 64823
Originally Posted by frozenice View Post
@zakiyyboss
Frozenice
I wanted to unlock a Nokia n95-8G !!
Old 05-11-2012, 10:47   #5 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Heheh,
So, it doesn't require ATF Network.
Just Direct Unlock SL1/SL2 from IMEI and LOCKS tab will do
the Job ...
Old 05-16-2013, 12:10   #6 (permalink)
Member: 621466
i have all ready activated atf network
but now it says invalid responce y?
Driver Version : 00020416
Library Version : 00030118
Box Firmware : LogiCore 10.3.50
Software Version : v9.85
AdvanceBox SN : B58527C9D2F7C8E6FF6D4464
SET BSI Load Done
Old 05-16-2013, 12:41   #7 (permalink)
Member: 643472
Sonork: 100.96901
Hi, looks like problem from server, reported to ATF server admin.
Will be fixed in no time.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 05-16-2013, 13:31   #8 (permalink)
Member: 619957
i have same prob. my atf box is activate and show when log in to atf network invalid responce pl,s help me atf team as soon as possible
Old 05-16-2013, 13:47   #9 (permalink)
unlock.mk's Avatar
Member: 1671934
Sonork: 1612800
INVALID RESPONSE always... please fix it.
Old 05-16-2013, 14:48   #10 (permalink)
Advance-Box's Avatar
Member: 651945
Now is working...
Needed to put new HDD as the old one was getting too hot these days...
Old 05-16-2013, 15:07   #11 (permalink)
Member: 1908388
hello advane team old file nokia care suite new file where ????
Old 05-16-2013, 15:25   #12 (permalink)
Member: 619957
thanks atf team problem solved very fast solution
thanks a lot
Old 05-17-2013, 06:49   #13 (permalink)
Member: 621466
thanks a lot
Old 05-17-2013, 13:49   #14 (permalink)
bhogpurmail's Avatar
Member: 189506
Sonork: 100.1576871
ATF NETWORK ACCOUNT "invalid response" plz fix it
Old 05-17-2013, 14:04   #15 (permalink)
Member: 1404245
atf network invalid response
using latest ve. 9.85
DOES THE CELLNET DIGA HACK STILL WORK??? SP UNLOCKER 2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-04-1999 13:55
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-26-1999 14:31
Ringtones from the charts and new Links GM GSM Mobile Links 0 09-26-1999 13:54
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-20-1999 19:12
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
Page generated in 0.20167 seconds with 11 queries
