Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 04-03-2012, 08:45   #1 (permalink)
ashish_gsm's Avatar
Member: 1206156
Sonork: 100.1606768
Thanks Meter: 118
Thumbs up ATF new update good but not work..- [SOLUTION INSIDE POST #32]
in few days atf team release new update..when i conect any handset by usb cable & then scan button my pc restart.i also use other pc but same problem, i use other software like infinity best work good no any problem..plz fixed this prob atf team...
The Following User Says Thank You to ashish_gsm For This Useful Post:
Old 04-03-2012, 08:58   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,207
Follows these steps
1st backup the RPL & PM backups
Uninstall ATF & delete the ATF folder
Install V8.60 > click on Updates Importants files
Restore the box , if not get suscess contact me on messenger
Br - srinibas ( ATF Team )
Old 04-03-2012, 10:02   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,487
Hi,
There's no ANY problem like this. Must be PC / Windows Problem.
Do as said in post # 2 and let us know results.
Old 04-03-2012, 17:17   #4 (permalink)
ashish_gsm's Avatar
Member: 1206156
Sonork: 100.1606768
Thanks Meter: 118
Originally Posted by ..::Angel::.. View Post
Hi,
Sir i found problem..i have two pc.first pc intel processer,2nd amd processer + asus mother board
my first pc intel work fine atf new version & also old
2nd pc amd atf new version not work usb conection, when i conect usb cable & press scan button then pc restart but old version 8.50 work good ..i also today install new window in amd pc for this doubt..
but problem not solve..only problem amd cpu & asus motherboard
plz fix this prob atf team..thx in adv
Old 04-03-2012, 19:41   #5 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
i also have problem with amd cpu & asus motherboard only one time i can flash fone for next phone software stucks then kill processess and start again flash other phone like this way
Old 04-03-2012, 21:34   #6 (permalink)
Member: 643472
Sonork: 100.96901
Hi,
Any screen shot !? You might need install WinUSB drivers from ATF Driver
folder.
Old 04-04-2012, 04:03   #7 (permalink)
ashish_gsm's Avatar
Member: 1206156
Sonork: 100.1606768
Thanks Meter: 118
Hi,
folder.
Sir, i also try install winusb drivers,today i again another amd+asus motherboard pc,but problem same usb bus check,scan & flashing problem system hang & restart,plz fix this problem.........
Old 04-04-2012, 05:36   #8 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Contact me on messenger , i want to check it through Team Viewer
Old 04-04-2012, 07:46   #9 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Yes after check all thing , i feel problem due to your PC type ( AMD processor )
I think New version USB protocol compatibility problem with AMD processor .
I have refer to Main team if any problem there it will Fix soon
Old 04-04-2012, 09:45   #10 (permalink)
Member: 643472
Sonork: 100.96901
Hi,
Paste teamviewer id and password to my sonork.
Old 04-04-2012, 09:53   #11 (permalink)
skytelecom's Avatar
Member: 1074229
Sonork: 100.1605299
Thanks Meter: 64
Hi,
my atf also same problem after update ..
Old 04-04-2012, 09:57   #12 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
It is useless to say " my atf also same problem " without post LOG or screenshot
Old 04-04-2012, 11:57   #13 (permalink)
skytelecom's Avatar
Member: 1074229
Sonork: 100.1605299
Thanks Meter: 64
ATF Box is not in USB 2.0 Mode
* Go to "Product Support" tab and click the
* "Restore Box" Button to fix the Box Firmware
** If Problem is Not Solved...
1. Make Sure you are NOT using USB HUBS
2. Make Sure your USB port is USB 2.0
3. Make Sure you are using the latest Drivers
*** If Problem is STILL Not Solved
1. Use a THICKER USB Cable
2. Connect ATF Directly to the Root USB Port
3. Uninstall Drivers, Reboot PC, Reinstall
**** If you are still Stuck...
1. Search your entire PC for "ftdibus.sys
2. Delete all "ftdibus.sys" files you find
3. Reboot PC...
4. Disconnect ATF Box and all Boxes from PC
5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat
6. ReInstall ATF Software
7. Connect ATF Box Only to your USB Port
8. Install the Correct Drivers
INIT : FAILED , CHECK YOUR BOX FIRMWARE
Please Update Important Files
Old 04-04-2012, 12:21   #14 (permalink)
Member: 1657046
Sonork: i
Thanks Meter: 4
install winusb driver after prob solv
Old 04-04-2012, 17:09   #15 (permalink)
Member: 1713296
Thanks Meter: 66
me facing same problem in atf light.
atf setup 8.50 working fine but backup rpl option not working
istall win usb dirver but no luck following is log
Please update your Box Firmware
* Follow these Instructions
1. Disconnect any phones connected to ATF Box
2. Go to "Product Support Tab"
3. Go to "Box Tools" Section
4. Click "Update Firmware" button
* Make sure you put ATF Software in Windows
FireWall Exclusion List
* Make sure you put ATF Software in your
Virus Scanner Exclusion List
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.41949 seconds with 8 queries
