02-04-2014, 08:17 | #1 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | atf nitro box update firmware problem - (SOLVED) http://forum.gsmhosting.com/vbb/f609...nside-1774059/ |
02-04-2014, 10:18 | #4 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | my problem solve with restore box.after restore update Firmware Done |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
03-26-2014, 15:12 | #7 (permalink) |
Major Poster Join Date: Sep 2010
Member: 1388479 Status: Offline Sonork: ntccd60 Thanks Meter: 7 | ============================================== ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ box is not detected in Device Manager |
05-02-2015, 10:15 | #10 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1976478 Status: Offline Thanks Meter: 3 | This is the second box ia have bought!!!!!!!!!!!!atf nitro..and it tells me updat the firmware.i press update and when it finish it tells m again to update.i have done it 4 times!!!!!!!!!!!!!!!!!!!!!!!!! Atf is so unstable!!!!!!!!!!!!!!!!!!!!!!! |
05-02-2015, 11:56 | #11 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL You can only make FIRMWARE UPDATE if ATF Software version last DIGIT is Zero "0". Example. 12.20 12.10 12.00 11.90 etc... You cannot update firmware if the ATF Software Version does not end with "0" Example: 12.12 12.11 11.88 So the correct way to solve this problem is to make FULL INSTALL the latest ATF Software from here: http://atfsupport.com/?dir=file-supp...ll%20Installer Then Immediately After you make full install the LATEST VERSION, you can make FIRMWARE UPDATE etc... |
01-16-2016, 13:41 | #12 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 62
Member: 155699 Status: Offline Sonork: 100.157845 Thanks Meter: 7 | cant update firmware on atf box i have tried every known solution from everywhere,still cant upgrade the firmware with same message(error server connection) |
